Driving Mode Switch Failure | FerrariChat
Discussion in '360/430' started by Bill ochrane, Dec 2, 2018.
  1. Bill ochrane
    Bill ochrane Karting
    Oct 26, 2018
    202
    Galveston, Texas
    William Cochrane
    I have an intermittent problem with the Driving Mode Switch Failure logo appearing on the instrument panel.
    I did a search and there seem to be not much about it, and pretty old posts.
    When the symbol appears the little lights on the switch area are out and the horn does not work.
    When the symbol goes away, everything works normally. I'm not against taking it to the local Ferrari service place but don't want to if there is a DIY fix.
    Any help would be appreciated.
  2. Bwtyler85
    Bwtyler85 Karting
    Oct 25, 2015
    149
    Perth, Australia
    Ben Tyler
    No idea what would be but my guess is the clockspring has issues behind the steering wheel.
    Sent from my SM-N950F using Tapatalk
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,459
    Charleston, SC
    Curt
    If you're proficient you can remove the steering wheel and check for loose cables and/or a wire that might be disengaging before you bring it in to Ferrari Service.
    If you ask us "how do you do that?" ... bring it in to Ferrari Service. :)
  4. sakodik
    sakodik Karting
    Jun 2, 2016
    169
    Santa Clara
    Dan
    Mine was a wheel bearing right front. Did the easy cheap DIY stuff first then but the light was still going off and on. Check and secure ABS connection, cleaned, then replaced. Did as Curt mentioned as well checking wiring there. Mechanic replaced the wheel bearing and the light has been off since. My horn was functional the entire time and the driving mode light was stuck in rain/wet/ice during error time. Because of that, I do suspect you have a loose cable as your horn and light did not work.
  5. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,754
    England
    Mark
    I was just going to post about a possible wheel bearing issue.
  6. Bill ochrane
    Oct 26, 2018
    202
    Galveston, Texas
    William Cochrane
    I just finished taking the steering wheel off and checked connections. All looked good. I did not remove the clock spring but did check the connections there too. All looked good. The horn wires do come from the mode switch box. I'm starting to wonder if I'm losing power to the switch box? Is there a wiring diagram for the switch anywhere? Besides the dealership - LOL
  7. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,754
    England
    Mark
    Ignore me - skim read and missed the horn & lights issue.
  8. Bill ochrane
    Oct 26, 2018
    202
    Galveston, Texas
    William Cochrane
    UPDATE:
    Fixed! Bwtyler85 had it right. Thanks.
    The problem has been taken care of by Eurocar-Werk in Houston.
    The clock-spring was replaced.
    whatheheck likes this.
  9. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Hi Bill & everyone,
    I now have this driving mode switch fault symbol popping up once in a while.
    I'm thinking I too have the clock-spring going bad.
    I checked my Workshop Manual, it covers how to safely disable & remove the air bag but it doesn't really go into detail on how to properly & safely remove the center of steering wheel so I can check / replace the clock-spring.
    Can you or someone kindly tell me please how to properly remove the center of steering wheel?
    Do I just simply pull it towards me and not worry about breaking anything?
    Many thanks in advance.
    Dan
  10. Bill ochrane
    Oct 26, 2018
    202
    Galveston, Texas
    William Cochrane
    This video is for the switch label but shows how to remove center that holds mode switch.
  11. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Got it.
    Thanks Bill!
    Dan
