Driving with hand on shifter...mythbuster question? | FerrariChat
Discussion in 'Technical Q&A' started by Sandy Eggo, Jul 20, 2010.
  1. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    I was once told (forget who) that it was a bad idea to drive around with your hand on the shifter. In other words, only put your hand on the shifter when you need to shift. The theory was that if you rested your hand on there, you were transmitting vibrations down the shaft that could ultimately lead to premature wear, etc.
    What I want to know is if this was BS or is there something to this advice.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    If you apply any pressure forward or back you are potentially causing a bit of wear to the shift forks.
    Probably pretty negligible in a modern transmission.
  3. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    +1
    Interesting though, the owner's manual for my Lotus Esprit (2003) states a clear caution NOT to do it ---- so, it may also depend on the particular gearbox / linkage design.
  4. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,331
    Seattle Area
    Dave
    That's what my F-wrench says, so I just don't do it.
    Jedi
  5. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    Put your hand on the shifter while driving then relax your arm. Any pressure in any direction can be felt. I did it on my 3.2 Mondi and you can feel the gears working in there. I find a better place to put my hand is on the steering wheel. :)
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    If you've seen the inside of an Esprit gearbox you'll respect their warnings.
  7. finnerty
    May 18, 2004
    10,406
    LOL --- true 'dat!
    They certainly could never be described as "robust" ;)
  8. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    The "transmitting vibrations" is false, the rest is true!
  9. Dr Tommy Cosgrove
    36,599
    Birmingham, AL
    Tommy
    You will kill a transmission - given enough time - on the front wheel drive WV's if you do this.
  10. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,775
    Indy
    Bill S.
    +1. Rather you are preloading components that dont need that kind of fun. Let the shift forks and syncro find thier own happy running positions.
  11. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    The engine vibrates, your hand dampens and there are plastic bushings in between the two. Three fingers on the knob only to shift and then get it back on the wheel where it belongs.
  12. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    #12 NW328GTS, Jul 21, 2010
    Those things called "synchro's" are mini clutches inside the transmisson, usually made of brass. When shifting, the synchro's match the speeds of the gears to make it easier for the gears to mesh without grinding. Pressure against the shifter can make fingers of the shift fork and those synchro's rub against each other and you can cause premature wear of both the fingers and the synchro's.
    Sort of like driving around with your foot pressing on the clutch pedal.
    If you are not actually shifting, there is no reason to do it and if you press hard enough you are causing parts to rub against each other that dont need to.
    In the photo, pressure on the shifter can cause the friction cone (synchro) and the shifter forks to wear.
  13. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    Nuff sed
  14. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Ain't that the truth!
  15. DGS
    DGS Seven Time F1 World Champ
    73,031
    MidTN
    DGS
    FTW. ;)
    But then, I've spent the last 40 years with the "Italian driving postion" -- based on the premise that elbows were a mistake. ;)
  16. deluboz
    deluboz Formula Junior
    Dec 9, 2008
    298
    Plano,Texas
    John C. Lin
    :eek: for past 23 years been driving with my hand on the shifter all time, Time to change driving habit :)
  17. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    Everyone knows that your shifting hand goes between the legs of the babe in the passenger seat when you are not shifting.
    Sheesh
  18. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    I don't buy either side of the transmision arguments. But what I do buy is the fact that you have so much greater control over the car when both hands are on the steering wheel, that having both hands on the steering wheel is the only place for them to be excepting for brief interruptions.
  19. deluboz
    Dec 9, 2008
    298
    Plano,Texas
    John C. Lin
    Thats too much excitement for LOL
  20. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    Only if done properly.
  21. Shaide
    Shaide Formula Junior
    613
    Las Colinas, DFW TX
    Jason
    Heh... this seems to be a long standing statement then. This is stated in my Lotus Esprit (1989) manual as well, lol!
    Sadly (or maybe not! >.> ), I've never seen the inside of the Lotus gearbox, so I'm not exactly sure what I've been missing. That said though... I was a hair under 100k miles on that car when I sold it, and never had any issues with the gearbox. No shortage of other issues, but from my experience, I thought the gearbox was one of the stronger points of the car. Was I just lucky? Anyway, I knew way less then than I do now about mechanical things, and I just now consider myself to be in "newb" territory, so take that as you will. I can honestly say after my current restoration efforts, I have more knowledge on my Fcar than all my previous cars combined. Then again, ten times nothing is still nothing, no?
    Well, sorry for the meandering babble... point was this was pointed out in the 1989 Esprit owner's manual as well.
