Drooping mirror | FerrariChat
Drooping mirror
Discussion in '308/328' started by bigdreamer, Jan 18, 2008.
  1. bigdreamer
    bigdreamer Karting
    Jan 24, 2005
    203
    Wash. DC area
    Wayne
    The Vitolini? mirror on my car has no resistance and keeps drooping. How do I fix/tighten it?
  2. Jerry Fisher
    Jerry Fisher Karting
    Nov 1, 2003
    75
    there is a screw in lower forward portion (toward door handle) of base--just tighten it and it will not droop
  3. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    on my 85qv on the passenger side it has the same problem,it has a adjestment srcew in the front of the base plate,it needs a hex bit driver to tighten the screw,it holds for a while until someone slams the door close,good luck
  4. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,307
    OnTheSerpentMound
    Aaron
    If you have the rectangular mirrors like my car has you can remove the offending screw(s) - be careful that the mirror doesn't 'flop' down and ding the door when you remove the set screw - and put some Loctite on the threads. Put the screw back in and adjust then tighten and you're all set!
    Cheers;
    Aaron
    '82 GTSi
