Drove another 355 today, same spec as mine and..... | FerrariChat
Discussion in '348/355' started by Lfpontes, Mar 3, 2015.
  1. Lfpontes
    Lfpontes Karting
    Nov 1, 2010
    141
    São Paulo
    Luiz.
    And it felt significantly faster than my car, more responsive, torquey, and overall faster.
    Also, steering wheel felt heavier and more precise, even in non sport mode.
    Any guess why my car feels slower? Mine shows around 17k km, and this one has around 40 or 50. Both are gated, mine a 99 and this one a 97.
    Any particular service, or engine tuning might "fix" this?
    My car feels like a VTEC car, being quite slow on early RPM,s and waking up after 4/4.5k rpm.
    This 97 car that I drove felt a lot stronger and more keen to move down the bottom of the RPM band.
    Also, my car does not seem to change in "behavior" when in sport mode. Even though the light pops on. Any ideas on that?
    Appeciate any inputs.
  2. WATSON
    WATSON Two Time F1 World Champ Owner Rossa Subscribed
    Sep 9, 2010
    23,712
    WI
    What exhaust do you have...and what exhaust was on the car you drove?
  3. SoCal1
    SoCal1 F1 Veteran Owner Silver Subscribed
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Cam timing during the belt service makes quite the difference
  4. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,586
    San Carlos, CA
    Mitchell Le
    Cam timing is off.
  5. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    There are NO changes (that I know of) with "Sport mode". It only stiffens the shocks a little bit. Listen to the others here about power differences.
  6. GTSNJ
    GTSNJ Formula Junior
    Jan 18, 2015
    478
    Sometimes odometers are not indicative of mechanical conditions. I would say to check cam timing, general tune up items such as spark plugs airfilter fuel filter. Also dirty maf. 02 sensors (check for obd codes.) Etc.
    The suspension sounds like it could have a different ecu or your shocks are weak. It should tighten up in sport. Does ur suspension light work . (separate from sport light )
  7. GTSNJ
    Jan 18, 2015
    478
    My 99 f1 was night and day regular from sport. 95, not so much but it is stiffer by default and softer when button cycled.
  8. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Honolulu - Seattle - Okinawa
    Steve
    Cam timing and general tune up are most likely the differences. The F355 has ITB's as well and synchronizing them at a major service is important. I don't know your service records but many low mile cars have gone a long duration between important services compared to cars regularly driven and with more miles.
  9. Garvin
    Garvin Rookie
    Jul 15, 2012
    34
    Cambridgeshire
    Perhaps you should get a compression test or leak down test performed on yours. If that comes up OK then get a full engine out service and, as stated previously, the cam timing set up properly at the same time.
  10. INTMD8
    INTMD8 F1 Veteran Owner Silver Subscribed
    Jun 10, 2007
    6,776
    Lake Villa IL
    Is your bypass valve functioning? Also check to see if you are getting wide open throttle. (When I received my previous 355 it was only getting 3/4 throttle due to cable adjustment)
  11. Capt
    Capt Karting
    Nov 9, 2003
    222
    North of Boston
    Michael
    Can't repeat cam timing enough, the procedure is complicated and often I'm told you can end up with each bank slightly different than each other and it's critical to get them to synchronized.
    -Michael
  12. GTSNJ
    Jan 18, 2015
    478
    Some engines dyno more power than others regardless of what the factory numbers are. In Aston martin v12 it is not uncommon to see large variation in performance by two otherwise well running cars.
  13. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,242
    CT
    John Kreskovsky
    If you really think there is a problem, take the car somewhere and have it properly diagnosed. Otherwise, dive it and enjoy it and don't worry about what the seat of your pants tells you.
  14. brettb
    brettb Karting
    Jan 13, 2011
    57
    My car was underperforming and I found the throttle linkage had shifted and it was only giving 75% travel..
  15. cuneo
    cuneo Formula 3 Silver Subscribed
    Nov 20, 2006
    2,472
    Bad gas?
  16. jochem00
    jochem00 Formula Junior
    Jun 19, 2014
    344
    Netherlands
    fouled injectors with plenty gunk inside due to low mileage.
  17. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    424
    Carolinas
    Ken
    Maybe clean out the combustion chambers with a double-dose of BG44k or Techron?
    Newer tires will make a ~big~ difference in overall handling. To a lesser degree, also refreshed bushings.
    +1 on checking the throttle travel. That is a 30 second job with the Mrs. in the passenger seat. Just reach under the coolant tank when the pedal is on the floor and try to rotate the bell crank further counter-clockwise. If it moves at all, it needs adjustment (they also commonly stick on WOT but that is another thread).
    For a change in behavior, the difference may be faulty (re: 15 year-old) dampers which need oil and nitrogen replacement and shaft refurbishment (see Bilstein or Delta-Vee rebuild services).
    Good luck.
    Ken
  18. tres55
    tres55 F1 Rookie Rossa Subscribed
    Sep 18, 2012
    3,572
    Canada
    Have you had your engines compression tested recently?
    From what I've seen with the inspections I've done on some low mile cars, it really doesn't matter if the cars been beat and not operated properly. 115psi across the board with 35% leak down on a 16k mile car...try and figure that one out.
  19. phrogs
    phrogs F1 Veteran Silver Subscribed
    Apr 13, 2004
    7,348
    Kzoo Michigan
    Can you say valve guides. Not much to figure out. My car with 15,000 miles needed the guides done, but I budgeted that into my purchase price and once done I know its done.
  20. Eric C
    Eric C F1 World Champ Silver Subscribed
    Mar 20, 2009
    11,089
    St. Louis, MO
    Eric
    Might want to adjust your Vtec controller.
  21. tres55
    Sep 18, 2012
    3,572
    Canada
    The car I mentioned had the valve guides done at 11k miles...5k miles later same problem. Previous owner used bronze guides. Probably why it was for sale...owner didn't want to fork out another 20k.
  22. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,734
    In order of likelihood::
    Compression
    Injectors
    Ignition
    Cam Timing
  23. StanT
    StanT Formula Junior Silver Subscribed
    Oct 10, 2007
    356
    Vienna, VA
    Could be clutch pressure, wear. My 98 355F1 GTS was feeling sluggish, even at highway speeds. Clutch adjustment by Competizione made a world of difference.
  24. st4rk
    st4rk Formula Junior BANNED
    Dec 7, 2011
    447
    That, or change the VTEC fluids.
  25. WATSON
    Sep 9, 2010
    23,712
    WI
    How often do I need to change the VTEC belt?
