Dry sump GTB basket case on Fleabay | FerrariChat
Discussion in '308/328' started by Hannibal308, Nov 29, 2015.
  1. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    No affiliation but 2 days to go...in Houston.
  2. JAM1
    JAM1 F1 Veteran
    8,639
    FL, NY, and MA
    Joe
    Definitely a worth while project. My eyes lit up when I saw it was a dry sump / Euro car. I gather the owner doesn't know or he'd have mentioned it!
  3. rickyrybo
    rickyrybo Rookie
    Feb 4, 2009
    32
    Bellport, NY
    Rick
    Thanks for the post.
    With all due respect, may we dispense with the stupid contractions?
    Regaining civility one post at a time.
    Rick.
  4. Steve Magnusson
    26,765
  5. JasonMiller
    JasonMiller F1 Rookie
    3,647
    Co Springs/ Texas
    Jason Miller
  6. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    When you use the word stupid after "with all due respect", you are either being completely disrespectful or implying that I am not due any respect whatsoever. So, I have some contractions in mind regarding you, which out of respect for everyone else, I will keep to myself. So much for civility.
  7. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
  8. Jdubbya
    Jdubbya The $10 Trillion Man
    43,115
    PNW
    30K for an "i" with an apparently grenaded motor?
  9. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    huh??
  10. Jdubbya
    43,115
    PNW
    It's listed as a 1980 which should be an injected car but they say it's a carb car. They also say..."AS FAR AS I KNOW THE ENGINE WAS DAMAGED BY NOT CLOCKING TIMING BELT PROPERLY AND CAUSING VALVE PROBLEMS."
  11. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    Euro, drysump cars can be carb cars till the end of 1980.
    I'm not sure, what this auctioned car is.
    It wears US side markers and US speedometer, but has a dry sump engine, what never was a US-thing. On the other hand it has an Euro engine lid and mirrors, small gauges and a fasten seat belts warning light. Strange mix of things.
    And the VIN seems too low to be a 1980 car. It more fits into 1978.
    Looking closer onto the engine pictures I almost suspect, that they quickly threw in that engine, which doesn't belong to the car.
    Coolant hose missing, engine torque bar missing. A/C compressor thrown into a place, where the coolant header tank should be :)
    Looks like halfway through a dirty reinstallation job.
    Best Regards from Germany
    Martin
  12. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    #12 Hannibal308, Nov 30, 2015
    Martin is correct, it is a 1978. But it is an original dry sump car. All of the sump reservoir and oil cooler mounting points are correct and the ID plate is also correct for a Euro GTB. Someone threw in a US speedo and added a seatbelt light to get it in the country. Clearly, it will be a box of surprises to anyone, either good or bad. If I didn't already have one going through a full restoration at the moment, I would be in Texas already, checking this one out, and not writing about it. Might make a great donor to send to MAT or just pace yourself and restore it locally. I hope someone here gets a shot at it if it is up their alley. "Do you have what it takes to take on a fixer upper?" (Sorry, I had to steal that from HGTV)
  13. adesalos
    adesalos Formula Junior
    Mar 19, 2003
    252
    Texas
    for what it is worth; I had a 1979 carb GTB with a S/N starting in 37xxx. 25031 is an earlier model, and is carb as well.
    The real question is why would the dealer not research and advertise the car properly?
  14. adesalos
    Mar 19, 2003
    252
    Texas
    a great buy at 30k, considering that it may cost 20 or 30 more to restore it mechanically completely (I did it on mine about 10 years ago for ~24k) , and then you have a 100k car... a great project car; I wish I had the room and the time to buy it
  15. 4right
    4right F1 Rookie
    I don't think that car in good mechanical condition will fetch $100K.
  16. adesalos
    Mar 19, 2003
    252
    Texas
    even at 60k... you are in the money, and have the adventure of a lifetime restoring a masterpiece of automotive. What is not to like?
    Remember it is about the journey, not only the destination...
  17. Steve Magnusson
    26,765
    #17 Steve Magnusson, Nov 30, 2015
    The side US-legal side markers and speedometer are a couple of things that do get added/changed on almost all euro brought to the US (even if the rest of the "importation modification" is done poorly) -- so those make sense. It wouldn't be easy to "quickly" put that engine in a US chassis as a lot of the chassis fittings in the engine bay are different so I'll go with it being a euro. Agree that the SN seems lowish, but a car made in 1978 that sat unsold for a long time and final got sent to the US could wind up with "1980" euro papers since "model year" for euros didn't really exist until 1980.
    I usually don't like the body-colored rocker panels, but the body-colored belt line on this one just makes it way worse -- looks naked and fat with no pants on ;) -- JMO...
  18. gt4me
    gt4me F1 Veteran
    Sep 10, 2005
    5,671
    Lewis Mitchell
    I wouldn't call that a basket case.
  19. BigTex
    79,368
    Houston, Texas
    Bubba
    Definately a Euro car.....
    Definately broken motor.
    He knows what he has, I just talked on the phone.....
    :D :D :D :D
  20. BigTex
    79,368
    Houston, Texas
    Bubba
    A dry sump Euro GTB is definately past the $100K mark...well past it.
    Someone is going to get this in the last 10 seconds of bidding........the only question is "who and how much"???
  21. BigTex
    79,368
    Houston, Texas
    Bubba
    I think that's the "I give up" presentation...:D :D
    I say "original" motor based upon the rare air box, uninsulated with the Firing Order plate, those are rare here and have not been on North American cars since 1976!!!
    Also note, the correct 8 plug single distributor, for a Euro dry sump version.
    Lots of positive indicators, all the dash vents are there!!
    :D :D :D
  22. BigTex
    79,368
    Houston, Texas
    Bubba
    He doesn't know the finer points of the model, it seemed to me....still, lots of people do not!
  23. myronx19
    myronx19 Formula Junior
    May 27, 2012
    653
    Toronto, ON Canada
    Myron Samila
    Italian gauges (less the speedo).. love it.
  24. BigTex
    79,368
    Houston, Texas
    Bubba
    I like how the lightweight Euro rear bumper has been "pushed out"!!
    Someone went thru the paces to get this thing legal....
    Interior looks pretty nice really.....seats and rugs.
    I wonder if the Parking Brake handle light comes on??
  25. BigTex
    79,368
    Houston, Texas
    Bubba
    Yep......
    If you look closely that's actually a dual range speedo, it does have the KpH scale on the inside of the MPH markings.
    I had one of those, in my #20405 (an "in period" failure replacement).
