458 - DTC - P0128 (Thermostat) | FerrariChat
458 DTC - P0128 (Thermostat)
Discussion in '458 Italia/488/F8' started by hgoodwiniii, Jan 7, 2024.
  1. hgoodwiniii
    hgoodwiniii Formula Junior
    279
    Hi everyone, the check engine light in my 2011 Italia is on. I had my car scanned and the DTC that is kicking off is P0128 indicating a thermostat issue. I'm not seeing very much in the forum related to this code. I'm wanting to check if anyone in the 458488/F8 forum may have experienced this one and the end result. Thanks.
  2. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,977
    St. Louis, MO
    Eric
    Any temp issues with engine or heater?
  3. hgoodwiniii
    279
    So far, no. I only drove about 5 miles to home after the check engine light came on.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,701
    Central NJ
    Dominick
    Pretty common on f430 ..takes too long to heat up ..most likely a lazy spring or slightly stuck(open) thermostat. Does the coolant take a long time to get to normal range..does it go down as soon as you drive ?
  5. hgoodwiniii
    279
    #5 hgoodwiniii, Jan 8, 2024
    Thanks flas32, that's good feedback. I will check it out once the weather clears up. I'm thinking to just change the thermostat. Looks like it comes from Ferrari with the housing and not just the thermostat. Your thoughts? Thanks.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,701
    Central NJ
    Dominick
    I would see how the temp gauge looks like on your next start up and drive .. eventually probably beat to change it along with sensor. Not a cheap job ..part is mid 200s and sensor is like 30 .. most places will charge over 3 hours of labor.
    hgoodwiniii likes this.
  7. Kent Adams
    Kent Adams F1 Rookie
    3,054
    I've learned not to trust any dashboard warning light from any European automaker unless I actually experience a driving difference. If I check my oil and other fluids routinely and they're good....and the car is driving normally otherwise, I just ignore the lights because the warning lights typically go away the next time I start the car up. From my 50 years of experience driving Euro makes, their sensors are nearly always TOO sensitive or broken. Right now I have a coolant light on my 2022 Audi RSQ8. The coolant is fine, it's not low or gone bad. Nothing wrong with it. I'm quite certain the light will go away in a few days. Faulty electronics/sensors etc. seem to be endemic to European makes. I've seen it since 1972 across all types of European makes.
    Eric C likes this.
  8. hgoodwiniii
    279
    Got it; Ok, I will do some testing and checking, as suggested.
  9. hgoodwiniii
    279
    Hi everyone, I'm just getting to look into the P0128 (Thermostat) DTC with my car. I checked the coolant reservoir bottle and noticed that it was empty. I filled it with water (I'm planning a coolant flush as soon as the DTC problem is figured out) and let the car run about 10 minutes.
    The temperature reached about 170 degrees (F). I noticed water leaking out of the side of the coolant reservoir bottle. It has a hole in it.
    I'm thinking this may have been caused by the thermostat not opening up and maybe causing pressure to build up and caused the reservoir bottle to burst.
    Does that sound reasonable? I appreciate any thoughts. Thanks.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,701
    Central NJ
    Dominick
    If the thermostat was stuck you would have been overheating not under temp
    I will say it is possible the low temp was caused by the low coolant .. coolant not sufficient to cover sensor ..but doubt it
    I would fix leak ..fill and observe again ..I am still thinking you need a thermostat but an easy test
  11. hgoodwiniii
    279
    Yea, good point - Thanks. The water was not moving in the reservoir bottle that should be an indication that the thermostat is closed, as well..
    flash32 likes this.
  12. triathgeek
    triathgeek Karting
    Jul 25, 2010
    122
    Santa Clarita, CA
    My inde caught my bottle delaminating/disintegrating and replaced it before it failed. I hope yours gets sorted out soon.
  13. hgoodwiniii
    279
    Hi triathgeek,it was only your bottle and nothing else that caused it?
    Thanks. It'll work out.
  14. triathgeek
    triathgeek Karting
    Jul 25, 2010
    122
    Santa Clarita, CA
    There was a slight leak and replaced the cap. Later on there was still a slight leak and that’s when the deteriorating tank was replaced. It never had a dash warning light or overheating; wasn’t a thermostat in my case.
    My NSX tank had the same issue and a used Miata we had for a few years also had a failing tank replaced. Both were caught before things going south. They were kind of chalky/flakey.
    We may have had different issues but check your tank and cap anyway. They weren’t terribly expensive. Hope this helps.
  15. hgoodwiniii
    279
    It helps. Thanks very much triathgeek. I think I am going to go ahead and just replace the thermostat along with the tank and cap.
    flash32 likes this.
  16. hgoodwiniii
    279
    Hi everyone, I have the old coolant tank out of my 2011 Italia. I am ready to change the thermostat and hose that runs from the coolant tank to the water pump on my 2011.
    I am looking through the 458 service manual and it is giving instruction to remove interior panels (section E4.04) and the engine inspection hatch (section E4.06). I really don't want to get into removing interior panels if I don't have to.
    Anyone, know if the thermostat and coolant tank/water pump hose can be changed from underneath the car by removing the main under body tray instead of messing around with the interior panels and engine inspection hatch? Thanks.
  17. hgoodwiniii
    279
    Anyone on this? Looks like I'm going to be the guinea pig here. LOL!
  18. hgoodwiniii
    279
    Anyone, know if the thermostat and coolant tank/water pump hose can be changed from underneath the car by removing the main under body tray instead of messing around with the interior panels and engine inspection hatch? Thanks.[/QUOTE]
    Hi everyone, for the record, I am done with coolant tank and cap, thermostat and temperature sensor on my 458. I want to confirm that I was not able to do so without
    Hi everyone, I am done with coolant tank and cap, thermostat and temperature sensor on my 458.
    For future reference, I saw a video by Normal Guy Supercar that he was able to change the thermostat from underneath the car on a F430. I was not able to do so from underneath my 458. My hands were to big. I had to remove the engine inspection hatch like the fsm instructed.
    While I was at it, I went ahead and changed hoses (part #s 262476, 86091700, 266873 and 268188) since they were accessible with the engine inspection hatch removed.
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,701
    Central NJ
    Dominick
    I am glad it all worked out and I could be of assistance
  20. hgoodwiniii
    279
    Yes, thanks for your help
    flash32 likes this.
