Dumb battery orientation question | FerrariChat
Discussion in '308/328' started by KickinTheTires, Oct 25, 2008.
  1. KickinTheTires
    Jan 30, 2005
    39
    Along 495 (MA)
    OK folks, I know this probably takes the cake for the dumbest question on record:
    I took the battery out of my '79 308 so I could put it on a charger...a week ago (it hasn't been sitting on the charger for the week, I just took it out a week ago). Now that I have a chance to put it back in, I forget which cable is positive and which is negative. They are both black cables. So which is the positive....right cable or left cable as I stand at the front of the car and look into the spare tire bay?
    I know, I know...but with my luck I'll guess incorrectly and blow the whole thing to pieces.
    Thanks in advance.........
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Often the pos lug on the battery is larger diameter than the neg lug. Look to see if there is any difference in size. If so, then just reconnect the appropriate connector.
    If you have a multimeter, check for continuity between the terminal of each cable and a good ground (chassis). The cable that has continuity is the neg cable.
  3. masonfamliy04
    masonfamliy04 Karting
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
    On my 308 qv left is - right is +
  4. ferraricare
    ferraricare Rookie
    Oct 25, 2008
    6
    Follow the cables: the ground goes to frame where its bolted down! Any more help, just drop me a line! Visit my car blog for more great cat talk:http://autotechtalk.blogspot.com/
  5. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,809
    Cerritos, CA.
    To be safe use a multimeter and check terminal for ground continuity.
  6. Papa Duck
    Papa Duck Formula Junior
    Jan 16, 2006
    351
    Las Vegas, NV
    Carl
    +1 because my 1981 GTSi has the + on the driver's side.
  7. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Some really smart people decided a long time ago, that all directions are referenced to sitting in the car. Front, right, left, rear, just like when your behind the wheel. In an early 308, the negative is on the right side. The negative is short, only about a foot long, and bolted down right next to the battery. DO NOT trust a VOM to indicate the cables, as connections in the electrical system could give you a false indication. You should visually inspect the negative is in fact bolted directly to the chassis. The positive goes down and into a chassis tube that runs rearward to the engine starter.
  8. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Easiest way is knowing that the disconnect is on battery ground.
  9. miketuason
    Feb 24, 2006
    15,809
    Cerritos, CA.
    Kick, have you figure it out yet?
  10. KickinTheTires
    Jan 30, 2005
    39
    Along 495 (MA)
    Thanks to all who took the time to answer. I am officially up and running! Thanks again............
