430 - Dumb question: closing gas cap | FerrariChat
430 Dumb question: closing gas cap
Discussion in '360/430' started by iheartf430s, Oct 5, 2024.
  1. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
    Ive had a fuel smell in the garage.
    Closed the cap at a 1/4 turn seems to have improved. Messed with it again yesterday and it will keep turning to the right (clockwise). This morning fuel smell is back.
    Is there a way I should be closing this cap?
  2. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,924
    Weston, FL
    Scott
    Close it until it’s tight. Put a little umph into it if you have to.
  3. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    That cap should stop after 1/4 turn so either the inner part is spinning inside the cap or the stops on neck are bent etc
  5. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
    Thanks Dominick. I'll inspect this evening!
  6. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
    I feel like I live on this forum, since I've gotten this car :D
  7. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    Be sure to check your Fuel pumps. If they have not been replaced it may be the source of your fuel "smell". Common problem and also a serious one in respect to fire hazard.
  8. Pete Schweaty
    Pete Schweaty Formula Junior
    May 21, 2014
    281
    Check your fuel pumps ASAP. You are describing classic fuel pump failure smell. They crack at the top letting fuel drip out. The fuel drips down on to the exhaust and sets the car on fire. The circle part on top with the X in it. See if there is gas puddling in there. If so, stop driving it immediately.
    kestrou, efg2014 and f355spider like this.
  9. Pete Schweaty
    May 21, 2014
    281
    Adding this point too. If your fuel pump is all white like the ring around mine, and not almond like the one in the picture, you have the original pumps that were prone to failure.
    kestrou likes this.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    FYI OP had the fuel pumps changed a few days ago - he is now still smelling gas and was wondering if the cap is the issue
    Pete Schweaty likes this.
  11. Pete Schweaty
    May 21, 2014
    281
    Ahh. Good to know. Maybe it’s some fuel that got splashed or dripped during the change? I guess that’s the best case scenario. Worst case is they didn’t connect something when reinstalling. I would pull the side engine covers just to be 100%. Unless he already did that.
  12. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,924
    Weston, FL
    Scott
    I misread your initial post and thought you had a 360 - different setup.
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    I always close mine with two clicks.
  14. efg2014
    efg2014 Formula Junior
    Sep 14, 2014
    657
    Northern California
    I have never had an issue with the gas cap on my F430. I did have the gasoline smell which turned out to be the fuel pump leaking issue.
