Dumb question re flashing side marker lights | FerrariChat
Discussion in '308/328' started by rufus, May 13, 2007.
  1. rufus
    rufus Karting
    151
    Toronto & St PetesFL
    Pete Gorrell
    beautiful day, so I pulled a job out of the Ferrari jar... it's a writeup by mike328 on how to modify the side marker lights so they flash w/ the turn indicators. Easy. Except no matter how many times I read it it looks as tho I am putting two lamps (resistors) in sequence, one (the front turn light) with much more resistance than the side bulb. Which should reduce the brightness of the side marker to glowworm level. What am I missing, please?
    Rufus
  2. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    If you go to Mikes profile & look at all his posts to find this particular subject, proceed to it, read it again, and at the bottom he included a link that contains another one's describtion on how this works........the idea being that when the positive signal wire to the bulb does not have 12v, ground is present. Hope this helps you out, my car has independent fixtures to carry these functions out.
