360 - DYI Help -Replace rear seal and Cluch | Page 2 | FerrariChat
360 DYI Help -Replace rear seal and Cluch
Discussion in '360/430' started by Neil22, Nov 4, 2019.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
  2. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,759
    Western Mass
    Raimondo
    I meant the actual dripping with the car off, not that the seal wouldn’t be capable of leaking a bunch through on/off cycles.
    That pic to me shows a oily wet mess, was it actively leaking briskly with the car off as compared to with the engine running?
  3. Neil22
    Neil22 Karting
    209
    Oxford CT
    Neil Silberkleit
    wow that looks like a mess -
    I think mime will be similar
  4. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Thar was a Challenge Stradale that sat for +6 months.
  5. Neil22
    Neil22 Karting
    209
    Oxford CT
    Neil Silberkleit
    They need to be driven not museum pieces !!
  6. Neil22
    Neil22 Karting
    209
    Oxford CT
    Neil Silberkleit
    Update on my leaking seal - so this is very hard to tell how much since the oil sits in the Belly pan before leaking on the floor - but it seem the leak has gotten better I am not seeing oil on the ground - I find this very puzzling seals normally don't fix themselves -
    I have driven the car several times in the last few weeks - road are still snow and salt free but not for much longer.
    Anyone have any thoughts ?
    The clutch is still good and the car runs really good?
    One note the car will soon be sitting for several months winter is coming!
  7. BrettC
    BrettC Formula 3
    Aug 13, 2012
    1,978
    Calif
    Brett
    I am lost here, the throw out bearing is a bearing yes? no fluid to leak...you must be referring to the slave cylinder activating the bearing yes? I would be a little hesitant running bars stop leaking in the brake system but if you only bled the clutch...all fluids should head to the distribution block in the rear of the car and possibly not enter the braking systems....shared with the clutch...or is it different with the F1? are you F1? can't remember and too lazy to look back in the thread...cheers!
  8. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Since the 348, Ferrari has a very unique design where the slave cylinder and the throw out bearing are integrated as one unit.
  9. 24000rpm
    24000rpm F1 Rookie
    just like the e-differential actuation
  10. Neil22
    Neil22 Karting
    209
    Oxford CT
    Neil Silberkleit
    I did an inspection after I noticed the pool on the ground - after removal of the belly pan the leak was between the engine and the transaxle - the clutch and pressure plate looked clean which would eliminate the slave as the leak -
  11. 360+Volt=Prius
    1,759
    Western Mass
    Raimondo
    Clutch release bearing (aka commonly called throw out bearing) for these cars has a hydraulic slave built in.
    I believe the F1 & 3pdl parts are technically similar except different seals because of different fluid (f1 vs dot 3 brake fluid).
    Mine is a three pedal. Sorry forgot to mention that.
    My macgyver method wouldn’t work for a F1. I also wouldn’t put bars leaks into a F1 tranny, that would be a recipe for disaster for you and a new boat for your mechanic.
    Remainder of your points are valid and I believe addressed them in my post.
  12. Kevin R
    Kevin R Rookie
    26
    San Clemente, CA,USA
    Kevin Reynolds
    Neil22 I’ve got the same leak on my 360. Seeps oil out of the main seal. Have ordered the rear mail seal and rear crankcase housing gasket and will replace when time comes to change clutch.
  13. Rifledriver
    34,074
    Austin TX
    That is often, actually more often a leak at the rear edge of the oil pan. The sealing surface there is very narrow and if it was one of the cars that used silicone to seal it instead of anerobic sealant, leakage there is very common.
    Kevin R and imahorse like this.
  14. Rifledriver
    34,074
    Austin TX
    Hardly unique. Been used by a lot of cars for a lot of years and predating Ferrari's use as well.
    2NA likes this.
  15. Kevin R
    Kevin R Rookie
    26
    Kevin Reynolds
    Well I’d much rather it be that then the rear main. I’ll drop the pan and reseal. Thanks for the heads up on the possible pan leakage Riverdriver! Do you have a preferred anerobic sealant you use for the sump pan?
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,675
    Central NJ
    Dominick
    I will let Brian answer since he is the expert but I thought this was the perferred sealant ..at a few years ago on a TR
    Loctite 37394 Anaerobic Gasket Maker - 1.69 oz. https://www.amazon.com/dp/B007XB4R80/ref=cm_sw_r_sms_apa_i_gRS8DbTC34MZY
    Sent from my moto g(7) using Tapatalk
    Kevin R likes this.
  17. Rifledriver
    34,074
    Austin TX
    Yea, 518.
    Get a good look in there first. You should be able to see it before taking it all apart but the oil pan is easy to get off.
    Kevin R likes this.
  18. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    I don't disagree with Brian that it can be the oil pan. That oil pan is easy to get to. In the case of this 360 whose picture is shown here, it was definitely the rear main seal. The repair of that seal requires the gear box to be removed, the clutch, pressure plate and flywheel also had to come out to access the RMS. It was a pretty big job.
  19. Neil22
    Neil22 Karting
    209
    Oxford CT
    Neil Silberkleit
    Mine seems to be weeping - drove the car a last week and no oil appeared under the car.
    I pulled the belly pan down mid summer and there was oil between the engine and the trans axle.
    I am getting ready to change the oil and do the annual service - will re-inspect and check the oil pan.
    if the seal is leaking I am of the mind set to wait until the car needs a clutch unless the leak gets much worse -
    have been checking the oil there is no sign of loosing any oil over the last 500 - 600 miles.
    Kevin R likes this.
  20. Rifledriver
    34,074
    Austin TX
    Some of these cars are 20 years old. Rear seal failures should be a surprise to no one.
  21. Neil22
    Neil22 Karting
    209
    Oxford CT
    Neil Silberkleit
    #46 Neil22, Dec 17, 2019
    Advice - here - I pulled the belly pan and pulled the inspection cover very little oil there I would would say if its leaking at the seal its very little. I had cleaned this the last time I took the cover off.
    What i did find is the back of the valve cover is leaking pretty good not sure if its running down the side of the engine to the oil pan or if the oil pan is leaking as well. it the back of the valve cover just a gasket or is there additional seals necessary?
    Below are some pictures i took
  22. 360+Volt=Prius
    1,759
    Western Mass
    Raimondo
    In The second pic looks like it’s the cam inspection cover that’s leaking.
  23. Neil22
    Neil22 Karting
    209
    Oxford CT
    Neil Silberkleit
    yes - that just a gasket or is there something else?
    there was oil dripping from the oil pan bolt in the photo as well
  24. albkid
    albkid Formula Junior
    Jul 1, 2016
    318
    Jim
    Had a leak here as well. Torqued the 10 mm nuts to proper value and eliminated the leak.
  25. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Just a gasket.
