News
Dyna Beads in Ferrari tires
Discussion in 'Technical Q&A' started by P400, Jul 16, 2009.
  1. P400
    P400 Formula Junior
    Mar 27, 2005
    527
    east coast
    Craig
    Anybody using Dyna Beads in their Ferrari or Lamborghini tires? Seems it balances the entire assembly. Would seem logical to use with dry Nitrogen charge as well.
    http://www.bestrestproducts.com/c-100-dyna-beads.aspx
    i am going to install some in my 23 Model T speedster (50mph max speed). To be honest i had never heard of this product. Only the gooey liquids of past. Slow learner i guess.
    Craig
  3. beast
    beast F1 Veteran
    May 31, 2003
    8,965
    Lewisville, TX
    Rob Guess
    I have seen these used in some motorcycle applications and have not been impressed with them at all. The 3 biggest things I have seen with them is:
    1. When you go to break the bead of the tire they end up on the floor of the shop creating a mess
    2. I have seen the beads get caught in the valve stem when the core was removed preventing you from deflating the tire.
    3. As the bead crash into each other and the wheel it creates a fine dust inside of the tire and wheel.
    As for them truly balancing the wheel??? That is good question as at high speed they may balance the wheel and tire. But at low speed on a balancer it will show the tire out of balance.
  4. Skidkid
    Skidkid F1 Veteran
    Rossa Subscribed Owner
    Aug 25, 2005
    6,654
    Campbell, CA
    John Zornes
    I have a decent understanding of physics but I never understood how this type of thing can move "directly opposite the heavy point". Basically, if you spin these in a centrifuge (tire) they will evenly distribute (more or less) around the outer edge. Unless there is a depression directly opposite the 'heavy point' there won't be any more beads there. In fact, the heavy point should pull the body of the tire out slightly more than a lighter section. The resulting low spot should collect more beads aggravating the situation.
    So tell me, what am I missing here?
    They shouldn't work AND they add unsprung weight out as far as possible on the wheel. Doesn't look like a great choice to me. Why not just buy a good tire that tends to be well balanced? That seams more obvious and clearly more successful.
  5. BigTex
    Dec 6, 2002
    74,279
    Houston, Texas
    Bubba
    Goodyear is #1 in Racing....
    I agree with the comment, about just properly balancing the tire!
  6. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    more snake oil...my 2c
  8. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,192
    Seattle, Washington
    Cliff
    What a bunch of crap.....
  9. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    Not a bunch of crap for Model T guys who do use these effectively. Don't forget that they are running wooden or fairly primitive wire wheels both of which are very hard to properly balance and keep in balance. Some of those Ts in roadster trim can do in excess of 80mph with no shocks, so anything that reduces any bounce is great. I wonder what the beads do to an inner tube over the miles, though?
    Beads in a tire mounted on a Ferrari? If you are properly using your Ferrari, you don't have tires long enough for them to get out of balance ;)
  10. Forexpreneur
    Forexpreneur Formula Junior
    May 11, 2009
    636
    Portland, OR
    Alexander Everhart
    Why not just fill them with liquid nitrogen? Reduce tire heat and the liquid follows path of least resistence, right? LOL.
  11. Skidkid
    Skidkid F1 Veteran
    Aug 25, 2005
    6,654
    Campbell, CA
    John Zornes
    It appears that your assumption is that these work as claimed. I still don't see how the physics of the problem can work. Regardless if it is a Model T or a jet dragster these should settle the the farthest out point in the tire. Unless that happens to be aligned with the light spot (unlikely) it will aggravate the problem not mitigate.
  13. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,496
    Frenchtown NJ
    Wil de Groot
    I just had new front tires mounted on my tow vehicle which has 22.5" wheels that don't take balancing weights too well. The tire guy asked me if I wanted to have some balancing beads in there. I don't really see how they work either but they were cheap enough and I figured "what the F, maybe I'll learn something". It really surprised me when he just threw the whole bag in each tire without breaking the bags open. "After a few miles of bouncing around, the bags will break open" he told me. Well, driving back, I couldn't tell if the bags where whole or broken. It probably is BS. The new tires rode nice and cushy though (for a truck). Big difference between nice new compliant rubber and old hokey-puck-hard tires.
  14. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,341
    Proper balancing requires both "static" and "dynamic" components be addressed.
    This method ---- loose beads / particles in the tire --- simply does not work. Don't waste your time with it, and don't believe the line of BS the sales people are feeding you about this (and similar) product.
  15. cletus
    cletus Karting
    Feb 7, 2006
    249
    I've balanced 40 inch rock crawling tires with bb's, but as mentioned above soth static and dynamic balance are important in passenger vehicles......Dont forget the Turn signal fluid and the muffler bearings when you order!!
  16. wildegroot
    Nov 19, 2003
    1,496
    Frenchtown NJ
    Wil de Groot
    Just wondering: Do you recommend synthetic turn-signal fluid?
  17. cletus
    cletus Karting
    Feb 7, 2006
    249
    Turn signals definately get Synthetic, but the reverse lights only get convertional, as they are used rarely and only for short periods of time!!
