Dynamat- yes/no - component vs coaxial speakers?? | FerrariChat
Discussion in '308/328' started by Banzairacer, Nov 3, 2019.
  1. Banzairacer
    Banzairacer Formula Junior
    486
    San Diego, CA
    Sanjeev Thohan
    I’m debating adding Dynamat or some other sound/thermal insulation when the carpets are updated - what are the thoughts from owners who have done this or thought it through.
    Also — component speakers vs coaxial in our 3x8 sound imaging. - of course it’s not Carnegie hall or anywhere near. i don’t have any illusions of an audiophile ride. And I get the engine is a wonderful soundtrack - but every once in a while you have to blast the Magnum PI soundtrack.
  2. vraa
    vraa F1 Rookie
    4,595
    Texas
    Mr. A
    I did second skin it was easier to apply and it worked for me
    I did on my IS-F when I added 2 JL 12" subs
    Banzairacer likes this.
  3. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I've done a lot of reading on dynamat. The impression I've come away with is that it does well for sound dampening, but not so much for heat insulation.
    JCR likes this.
  4. Banzairacer
    486
    San Diego, CA
    Sanjeev Thohan
    That’s what I saw also. There are some products that have heat dampening up to 400 F but not sure whether it’s real. That’s why I was asking - someone has to have done or read in this on this it another forum. Better to learn from experiences than fail one’s self.
  5. vraa
    vraa F1 Rookie
    4,595
    Texas
    Mr. A
    Correct, you need a completely different material for heat insulation
    I believe it's called closed cell foam? I might be wrong, it's been a few years
  6. Banzairacer
    486
    San Diego, CA
    Sanjeev Thohan
    Thanks.
    Ive seen
    Dynamat extreme
    Hushmat
    Noico
    FatMat
    Kilmat.
    Most of these are 80mil thick.
    claims are 24-20db reductions. Dunno if this will make a difference with the noise in the 3x8 GTS
  7. vraa
    vraa F1 Rookie
    4,595
    Texas
    Mr. A
    Are you doing to do the install yourself or have a shop do it?
    It is NO fun to cut the material and the smell and the heat and all of it sucks
    Have a shop do it and help them out by using second skin it's easier on the hands / gloves when it comes to cutting
    Try to buy from amazon.com so if you have any issues amazon will just refund/reship
  8. Banzairacer
    486
    San Diego, CA
    Sanjeev Thohan
    Cool thanks Vraa. Will do.
  9. JCR
    JCR F1 World Champ
    10,973
    H-Town, Tejas
  10. Banzairacer
    486
    San Diego, CA
    Sanjeev Thohan
    Awesome will check them out. These look like a great addition to the google searches I’ve been doing.
  11. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,338
    I have dynamat in my car - on the floor & some in the doors & it definitely removes some resonant frequencies & vibration noise. I'd probably do that again.
    Some years ago I also spent some money on audio (including, replacement door speakers, tweeters, constructing rear speakers & installing a sub in the footwell driven by an amp up front.)
    I wouldn't do any of that again because you have to play music so loud to overcome the noise of the car. For me the whole lot turned out to be a waste of time.
    Tvjake2 and ferrariowner like this.
  12. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,247
    Gold Coast, Aust.
    Patrick
    That's very interesting, Iain. I have my evaporator out right now (see separate thread), and there's a lot of room for a sub under the foot plate. I have also cut out the leather over the speakers (from behind, and easily glued back in) and put normal speaker grilles over to get clearer sound - didn't seem to make much difference. I was thinking of putting the old perforated leather covers back in and running tweeters over the emergency window crank holes, so your opinion gives me pause. The thing is just too noisy
  13. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Every time I consider spending the time and money to make the stereo acceptable, I wonder if the result is sort of pointless in the end... as you say, it's a very noisy car. Good to read this; thanks for sharing your experience there.
  14. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,338
    That's been my experience of it. I listen to music a lot on the daily - almost never in the Ferrari. When I get some time I am planning to take some of it out (specifically the sub & amp).
  15. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I didn't buy a Ferrari to listen to music:)
  16. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I installed Dynamat Extremen on the floorpan, central tunnel and doors of my '83 GTS. Dynamat substantially reduced the higher frequency sounds coming from the car; that is the noises that sound like gravel being thrown up by the wheels. Also the doors now close with a solid sounding whump. Both are improvements and I therefore like Dynamat. It is not a heat insulation whatsoever.
    At the same time, I stripped out wiring from what must have been 3 prior stereo installations, removed a subwoofer from the passenger footwell, removed power and subwoofer amps from the trunk, and installed new component speakers in the stock location with tweeters in the door crank holes. Modern high-displacement door speakers (I used Infinity brand) output just as much bass as did the old subwoofer. The systems sounds fine, but car noise and simple speaker configuration mean that it ain't no Bentley sound-wise. Its a personal judgement. It turns out I basically just use my system for Google maps (my head unit does Bluetooth) and seldom play music in the car.
    Tvjake2 likes this.
  17. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
  18. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    629
    Massachusetts
    Joe
    Totally agree. I did the same on my 78 308 GTS. It definitely quieted things down in the interior.
    Heat Insulation (primarily to keep heat out of the cabin and help the AC)
    Basically, heat gets into the cabin from three areas, the front windshield, the two coolant pipes running under the console and from the radiator and heater box heat from the front compartment entering the front panel.
    1. If you want to insulate for heat, you actually have to use a different material and it will be thicker. When I had my interior and rugs out and after I installed the Dynamite, I used Reflectix (sp), the bubble wrap with foil on both sides. I installed it along the center console tunnel. This helped insulate the heat from the two central cooling pipes that run the length of the interior. I also lined the inside of the console with the Reflectix. This was really effective in keeping the coolant heat out.
    2. The other area that heat enters is through the front wall where the pedals are. There are several holes. Pay attention to these when you Dynamat the front.
    3. The front of the car where the spare tire stows also lets a lot of heat into the cabin. On either side there are two heater boxes that contain coolant and are fed by a large rubber heater hose. This hose can be insulated to keep the heat in. There should be some foam rubber around the hose where it goes through an opening as it passes from the fender area to the spare tire area to the heater box. If this is open it allows heat from the heater box to come into that area and warm the front panel. Also, there are several heater hoses underneath the spare tire housing. These can be insulated to keep the heat in also. Don't forget to close the temperature lever when the heat is not used.
    4. Underneath the front of the car there is an access panel. I modified mine with louvers to let the heat out. There are several threads on this.
  19. Banzairacer
    486
    San Diego, CA
    Sanjeev Thohan
    Coool. Thanks.
    Will keep your suggestions in mind when planning the interior. No it will never be a Bentley - but some reduction may be good to better hear the exhaust rumble. Am putting a Panasonic head unit in with Apple car play as a single DIN. It’s more of a melding of old and new tech, but keep the single DIN look.
    I’ve also seen some crystal tint (???) - am going to find out the exact name at the shop here in San Diego. I saw a demo of it with a heat lamp and it does stop a lot of heat - a 5% tint will cut glare and prevent a lot of passive heat from the windshield. Generally recommended for cars in Vegas, AZ, TX and other triple digit places. Was also thinking of tinting the side - rear not so sure. May just for completion sake.
  20. Banzairacer
    486
    San Diego, CA
    Sanjeev Thohan
    Hi Joe.
    I used to live in Southie.
    Regarding 2 and 4 any direction or links to threads would be awesome.
    Thanks. Sanjeev
  21. jmaienza
    Jan 8, 2009
    629
    Massachusetts
    Joe
    2. Front panel holes
    On the driver's side you have the brake pedal connector going to the master cylinder, the clutch pedal cable and the steering column. If your car is apart, you can remove the the spare tire panel which exposes the heater hoses, brake booster and some other parts. Get a flashlight or another light source and put it in there, then go inside the car and look at the pedal and passenger footwell area to see the light.
    4. Access Panel
    Excess heat from the radiator is exhausted through the louvers behind the headlights and in later models a set of louvers in the front of the front lid. Underneath the car is an access panel, which is solid metal with a hole for the AC drain. By adding some louvers, the heat can also be exhausted underneath the car. The louvers should point toward the back. I had a hot rod shop fabricate the panel for me. Below is an example of this panel.
  22. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Do you have the vent openings pointing towards the front or the back of the car? (In other words, do the vents have fresh air pushing into them, or exhausting the hot air towards the back)
  23. jmaienza
    Jan 8, 2009
    629
    Massachusetts
    Joe
    Toward the back to exhaust hot air.
    thorn likes this.
  24. Dr Tommy Cosgrove
    36,538
    Birmingham, AL
    Tommy
    Component systems pretty much always sound better. It is what I have in mine.
  25. Dr Tommy Cosgrove
    36,538
    Birmingham, AL
    Tommy
    All you need ia a 100W per channel amp to hear it. They hook up just like a ****ty one. No more effort needed to do it right.
    I have a Tubi and I can hear the stereo in mine just fine at 80 mph on the highway with the top off. Not a problem and it makes those 200 mile trips back and forth to Road Atlanta a bit more enjoyable.
