Dyno Day | Page 8 | FerrariChat
Dyno Day
Discussion in '348/355' started by ernie, Mar 7, 2012.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    See post #169 above.
  2. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Wow! very impressive... Mine next?
  3. Andi355
    Andi355 Formula Junior
    381
    #178 Andi355, Jul 12, 2012
  4. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Very nice!
  5. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    See the machine. It's a Dynojet. That was what measured my car at 256 RWHP. The Dynopak was at 300. Imagine what this car is really putting out!
  6. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    A couple of weeks ago I did a couple pulls on a Dyno Dynamics, and it had me a roughly 260hp to the wheels (259.9). But the operator was shutting it down at only 7000/rpm. I finally had to ask him to stay in it until he heard the rev limiter. He didn't stay on the throtte because he said it had topped out, which it had, but I was after the a/f ratios. Even though my car wasn't producing any more power, it wasn't losing power either. Stayed flat all the way out. Which to me means it needs more air.
  7. Andi355
    381
    Rev-limiter is at 10300rpm at the moment. The engine produces the max power at
    about 9400 rpm. The result was reached at about 25°C outside !
    At the moment there is a non-bypass-exhaust system with 200cell catalysts installed.
    We will put the catalysts away and dyno the car at lower temperature outside. Lets see what will happen.......estimated 410 HP at the wheels (that's the F430 class)!
    I will keep you up to date.....
    Regards
    Andi
  8. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Andi, you going to do a write-up on your car? Myself and others would sure like to know the details.
  9. Andi355
    381
    #184 Andi355, Jul 13, 2012
    Okay, I will do this. But give me some time. Work will be done after the holidays, end of
    august. There is some other work to do (brakes, hydraulic oil loss, fan.....).
    Btw......car sounds fantastic, like a real aggressiv race car. I will make a vid.
    Here she is (yellow one in front): She is a orig. 96' Challenge car (one of 72cars). Weight about 1280kgs.
  10. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,947
    Atlanta
    John!
    #185 Ferraripilot, Jul 31, 2012
    Ernie, this is for you as I know you wanted to see it.
    I had a little bit of Tuesday madness today so I decided to get the car on the dyno.
    I did not do any tuning on the dyno and I am very pleased with the preliminary results. 253bhp with 216lbs torque, and it's a wonderful flat torque curve. Some yahoos said I could not get a perfectly flat torque curve with these wild cams :) This is somewhere north of 300bhp at the flywheel.
    Anyway, the engine runs too lean above 5k rpm running between 14.1:1 and 14:1 which is where peak power is starting to come in so I'm definitely missing a solid 10bhp+ from that alone. These dyno runs were also done with a conservative amount of ignition timing. I did not want to push the timing too much with it running lean like this. I'll dial back the air corrector jets to richen things up a bit up north, dial in some more timing, and then really make some power. I know it's on the table which is all that matters now.
    The dyno a/f ratio meter could not read off my exhaust correctly for some reason so I just datalogged the results on my meter.
    I have no doubt once I iron out the a/f ratio and dial in a bit more timing I will see something north of 270bhp at the wheels. And the car weighs 2800lbs :)
    As a side note, the 3.2L NSX there was in for a destroyed gearbox. It makes 247bhp at the wheels. Not nearly as pretty as the Pininfarina lines
  11. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    ROCK ON!
    Thanks for posting up your results, and nice numbers. You are making solid 348 power. Richen up your a/f ratios to 12.5-12.8 and you'll make even more power.
  12. Ferraripilot
    May 10, 2006
    17,947
    Atlanta
    John!
    Yup, there is way more in there. 270 and I'll be happy.
  13. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    nice numbers.... interesting how different your simulation puts the torque peak at compared to your actual dyno curve here on post #303
    http://www.ferrarichat.com/forum/showthread.php?t=339674&page=16
    the car must be hoot to drive with the extra torque
  14. Ferraripilot
    May 10, 2006
    17,947
    Atlanta
    John!
    I'm sure of I hooked the flywheel directly to the dyno we would see torque at an rpm nearer to that of the sim. Drivetrain loss is increasing as rpm increases. Regardless, it's going to make numbers that the sim suggested with a bit more tuning. No doubt
  15. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    ..................... what a great thread ......... :D ............... I am just about ready to get to the dyno for my 355 baseline ........ :)
  16. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Don't forget to post up your numbers and graphs Oz.
  17. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    #192 ernie, Aug 16, 2012
  18. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    will do ...... though may be doing it in a different thread ..... as it will be the first in a chronicle planned mod results ..... :)
    Yeah, if I recall correctly, Pap's dyno chart was a good illustration of removing the twin can for a single hi flow exhaust ...
  19. TexFerrari
    TexFerrari Formula 3
    Sep 11, 2004
    1,194
    Texas of course!
    I contacted one of the sponsoring shops on here, they regularly dyno cars after major service it seems, and they told me the 355 doesn't dyno a lot higher than 348, not as much as you would expect looking at their HP ratings. Maybe we can get them to share some more details.
  20. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    That would be interesting.
    Maybe the next time we do another dyno day, we could get some 355 guys to show up and see what they put down. I was hoping for that this last one, but didn't turn out that way. Next time, next time.
  21. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I would say before this month is out, I should have my 355 baseline run on this same 'dyno day' dyno .......... I located the final drive ratios for every gear in the owners manual ........ will post charts on this thread soon after that .... :)
  22. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Suweeet, looking forward to it Oz-meister.
  23. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Hey Ernie...
    Oz and I pulled my cats today for some replacement 200-cell versions. I'm gonna pull my pink chips too for the dyno. MAybe next week we will see just who's car is making the most power, eh? :p
  24. fatbillybob
    Aug 10, 2002
    29,355
    socal
    whatever happened to the piggyback fuel controler idea? Lots of guys have done nice exhausts but not much in regards to intake or a brain that says "drink"!
  25. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Hahahahahaaa!!!
    You are too funny.
    Let me know when you guys are gonna go do the pull and I'll see if I can make it.
