dyno-tunning...is it worth it? | FerrariChat
Discussion in 'Technical Q&A' started by parkerfe, Aug 11, 2004.
  1. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    An ex-FAF mechanic friend of mine is now working at a high performance dyno tunning shop. He says he can dyno-tune my BB512i in less than two hours at a cost of $150.00 per hour. Does it really make that much difference? Is it worth the almost $300.00 it will end up costing?
  2. f355spider
    f355spider F1 World Champ
    17,939
    Not sure on a FI car, but on my carb 308, I spent $600 for dyno and tech time and recovered about 30hp that was caused by a miss (incorrect plug gap) and lean jetting. Well worth it in my book.
    The only way to know if your car is running at optimum is through a dyno test and exhaust analysis....Gary Reed discovered on his BB that one of his distributors was not advancing properly during a dyno test.
  3. henryk
    henryk Formula Junior
    Dec 9, 2003
    479
    Door County, WI
    With the multitude of adjustments possible, on a carb version, I would think a dyno could pay off.
    The BBi has minimal adjustments, and someone with a CO meter can easily adjust the fuel ratio.
    The dyno may show bad advance, but so can a timing light. If the advance is off, the distributor has to be removed and completely dissassembled, just to get to the weights. I just went through with this on my BBi. EACH change in the springs, and/or shims, requires the complete removal, dissassembly, adjustment, re-assembly, and installation.........just to test the change done. I feel this could take many hours to get it right.
    In short, I don't think the dyno would offer anything more than tuning the car in the tradition ways.
  4. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    Run the dyno for the usual 2-3 times at @$75 and see how the graphs look. All dynos have variables so don't look only at the numbers, unless they are way off. Look at the curves compared to factory and if there is a difference as well as the A/F ratio. If it appears that there are problems, then pay the extra for the time to tune. If not, you are only out the $75 but have some neat graphs and a piece of mind that your car is running well.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    12,911
    The twilight zone
    The Butcher
    The only thing I would add is that the price does vary a bit, it's $125 out this way.
    If the car is all stock, then is should be pretty close to right with just a few tweaks required due to age. The dyno real is most helpful when the car has been modified, like a new exhaust or in my case a supercharger and an EFI system. For me the 4 hours I spent on the dyno were pretty helpful because I had to make all new fuel maps and ignition curves.
  6. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,618
    Pittsburgh, PA
    Matt F
    What exactly is he going to tune?
    If it were a carb car, I'd say yes, it would be worth it.
