Dynolicious | FerrariChat
Dynolicious
Discussion in '308/328' started by mike996, Jan 23, 2010.
  1. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,850
    Atlanta
    John!
    I used pocketdyno. Both are incredibly accurate. Pocketdyno had my rear wheel horsepower within 2bhp of the actual dyno results. Consistently
  3. Racing-Baker
    Racing-Baker Karting
    Jan 11, 2008
    217
    Beveren Leie
    Enzo Duquesnoy
    where to get this stuff??
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
  5. Ferraripilot
    May 10, 2006
    17,850
    Atlanta
    John!
    They are both $13 on the iphone. There is a free version for pocketdyno as well. The only difference is that it will not show your dyno graph and only one car can be setup.
  6. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    Now thats some cool stuff...its making me want an iPhone now.
    PDG
  7. Pantera1523
    Pantera1523 Formula Junior
    Mar 17, 2004
    432
    Virginia
    Scott Carpenter
    Does anyone know if these apps work the same on the iPod Touch? Is it only using the built in accelerometer?
    Or do these apps tap into the GPS capability that the iPhone has but the iPod Touch does not?
    I was thinking of buying one of them but haven't gotten around to it.
  8. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    It works totally with the internal accelerometer in the Iphone and Ipod touch. It does not use GPS in any way.
    I downloaded it for my iphone about an hour ago and can personally confirm that it works without GPS being on - it will measure the G force involved in rapidly moving the phone itself. Unfortunately, I don't have my Ferrari here in Mexico so I can't do any 0-60 or 1/4 mile runs in the 328 but I'll try it out in our Hyundai Santa Fe tomorrow. That should be pretty impressive! :)
  9. Davvinci
    Davvinci Karting
    Dec 11, 2009
    162
    California
    DavidoSpeedo
    #9 Davvinci, Jan 24, 2010
    So then you should be able to set it up to measure the lateral Gforce for handling and be able to tell you how much you're pulling in a corner?
    That would be very cool.
  10. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    Don't have an iphone but tempted buying one. Do I need a particular type?
  11. DriveAfterDark
    DriveAfterDark F1 Veteran
    Jan 1, 2007
    9,148
    Norway
    Nope, will work on all new iPhones.
  12. Pantera1523
    Mar 17, 2004
    432
    Virginia
    Scott Carpenter
    Cool... I will go download it now for my iPod Touch and see how it works. Thanks for the input.
  13. Ferraripilot
    May 10, 2006
    17,850
    Atlanta
    John!
    #13 Ferraripilot, Jan 24, 2010
    A note on *exactly* how it needs to be used for most accurate measurements. The Iphone needs to be mounted *dead* steady in the car. The accelerometer is measuring the performance of the car, and of course in order to do this it has to move only as the car moves. I have found that with the 308, a mount is absolutely required. One cannot hold it in their hand, have a friend hold it, or anything else that may cause it to move. I mount mine using a Iphone holder with a suction cup to the windshield and it is rock steady. There are tons of mounts out there, but the big suction cup models have some serious linkage that allows for a rock steady mount. Also, the Iphone must be recalibrated just before doing a run. Not but not least, the 'ready' button is only pushed when the car is at a dead stop. That's how it's done.
    I was told the pocketdyno uses gps in coordination to the other measuring parameters? I will check it out further.
  14. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    This thing seems to be great and one obvious value is to immediately tell you if that new exhaust system (or air filter or whatever) you installed did anything except make more noise!
    Then again...maybe getting one of these ISN"T such a good idea. :)
    Of course, to use it to evaluate changes, you would have to be sure to use the same launch procedure and same stretch of road every time to ensure the grade doesn't change and also account for wind if there is any (two way run). But you would not have to do any dump the clutch at hi RPM runs unless you wanted to - if there is a power change, it will still show up the same way as you power through the gears, regardless of how you launched the car.
    Pretty neat but I suspect that the aftermarket "performance" parts sales may suffer a bit after the "word" gets around that the "XYZ" exhaust (or whatever) that was supposed to be good for 15 HP did nothing! ;)
    But OTOH, there's nothing to stop anyone from fibbing and CLAIMING, "Hey, my Iphone says I got 15 more HP with my new XYZ exhaust" even if it showed nothing of the sort. That is the beauty of the internet - anyone can claim anything! :)
  15. Traveler
    Traveler Rookie
    Sep 30, 2009
    46
    I was tempted for a moment, but realized that this will just make me agonize about the performance of my car. It's easier to tell myself that my Mondi is as fast as a 355 if i have no proof. The proof will certainly not be in my favor. I vote for ignorance, I've found denial to be my friend.
  16. Ferraripilot
    May 10, 2006
    17,850
    Atlanta
    John!
    I swear the Iphone is a Godsend for the Ferrari community. If ever one wants to know their performance. Bam, it's right there. If ever one wants to see ones *actual* miles per hour rather than read their somewhat off Ferrari speedo, BAM (with my best Emeril voice), a GPS app in the Iphone gives real-time mph for ya.
  17. marc.l
    marc.l Karting
    Feb 25, 2008
    78
    Mercedes
    2004 AMG E55 compressor
    25 Jan 2010 17:05
    Acceleration
    0-10 MPH: 0.93 sec
    0-20 MPH: 1.76 sec
    0-30 MPH: 2.48 sec
    0-40 MPH: 3.19 sec
    0-50 MPH: 4.06 sec
    0-60 MPH: 4.94 sec
    0-70 MPH: 5.87 sec
    Elapsed Time
    60': 2.58 sec @ 29.3 MPH
    330': 6.01 sec @ 69.8 MPH
    1/8 mi: 8.92 sec @ 77.8 MPH
    1000': 11.99 sec @ 72.3 MPH
    Miscellaneous
    Max Speed: 79.2 MPH
    Max Acceleration: 0.68 G's
    Peak Horsepower: 428 HP
    Generated by Dynolicious
    My second run in the daily driver, in the wet on a not very good road, last dyno was 480 rwhp. Hope to get 0-60 down in the low 4`s. Will have a run in the 308 when the weather is better :)
  18. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    I see there is something called Dynomaster if you happen to have a Droid phone.
    I may use something like this in my Corvette, but probably not the Ferrari, as somethings are better left unknown. I already know what my HP and ETs and stuff are in the Corvette, but the lateral g force info would be useful
    Doug
  19. Ferraripilot
    May 10, 2006
    17,850
    Atlanta
    John!
    That is some kick a$$ acceleration Marc!
  20. jgoodman
    jgoodman F1 Rookie
    3,267
    Central PA
    Jay Goodman
    Agree. And isn't sounding fast like it does fast enough? :)
  21. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    "Max Speed: 79.2 MPH
    Peak Horsepower: 428 HP "
    Uphill, downhill, or on level ground?
    Our Hyundai Santa Fe today showed 38 HP at WOT! :) But that was because we did the "run" up a steep hill so the acceleration/weight/time showed low HP since it took a long time to reach the speed. Did it on a steep downhill and it showed 165 HP.
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,742
    The twilight zone
    A buddy or mine a couple hours away just bought an older dynojet...now i just need to finish the engine and go have some fun.
  23. Racing-Baker
    Jan 11, 2008
    217
    Beveren Leie
    Enzo Duquesnoy
    i'm planning on getting one. this seems like tons of fun!! :D
    what i don't understand is how can it calculate the hp??
  24. marc.l
    marc.l Karting
    Feb 25, 2008
    78
    On the flat, I live near the Lincolnshire fens in a area call South Holland, due to the total lack of hills. Miles of nothing and the test was done on a road call `seven mile staight`.
    Will be back again in the dry.....;)
  25. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    #25 mike996, Jan 26, 2010
    "what i don't understand is how can it calculate the hp"
    It just calculates the time it takes to get to speed vs the weight (you have to input the weight of the vehicle including driver/passengers/other articles.) If the weight input is wrong, the HP will be wrong though the relative difference in HP after making changes will still be accurate as long as the weight and the road (uphill/downhill/level) remain the same.
    Just keep in mind that any external change that helps the car accelerate - tailwind or favorable grade change - will result in a higher HP reading.
