E-Z Timing Belt Swap? | Page 2 | FerrariChat
Discussion in '348/355' started by pnicholasen, Jan 14, 2020.
  1. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Well, yes and no. It's not horribly difficult to drop it out, although I've found putting it back in to be a PITA. Trying to get the cradle in, then trying to get the bolt holes lined up is no walk in the park. Getting those forward 12 bolts lined up perfectly so they will catch the threads in the bulkhead can be frustrating as h*'ll. Then there's bleeding all the fluids, getting those big computer plugs threaded through the little tunnels in the bulkhead...etc. etc.
    But I digress...my point is if you don't do-it-yourself, no matter how hard or easy you personally feel it is to do, it's damned expensive, and knowledge of that doesn't enhance the desirability of these models. My original pondering was if there was some way to lessen that bite, how much would it improve the market for these cars? Maybe not at all...I suspect we'll never know. On the other hand when the computers and display screens on the current crop of cars go bad and they are no longer replaceable or repairable, the value of our relatively simple analog cars may go go crazy.
    Sent from my VS990 using FerrariChat.com mobile app
  2. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,477
    Atlanta, GA
    Steve D.
    then i'm the luckiest SOB on the planet, because all 12, first shot. (meaning the next major in 6 years from now will be a PITA)
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Dropping a fuel tank has it's own issues. The plastic fittings on the vent hoses become brittle and frequently break. They aren't easy to get at (with the engine in the way) and are expensive to replace. Of course if the tank isn't empty, you need to deal with that.
    Once you have the tank out, you still don't have a lot of working space. I did a water pump on a 355 a while back. Here's what it looked like. Still a lot of things in the way.
    INTMD8 and Qavion like this.
  5. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    This is one of the reasons people call them "stealership"
    ernie and 2NA like this.
  6. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Nope I did not but I know you can change belts from behind the seat. Ferrari eliminated the need to drop motors. I'm not saying its better or worse, I'm simply saying it is not needed to drop motors for belts post 355 thus its cheaper to do is ALL I am claiming.
    Sent using FerrariChat.com mobile app
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    This may be true yes but its interisting. If it was the cradle its one thing but if it's that main cross member then that's a whole other problem.
  8. WATSON
    24,032
    WI
    I love threads like this.
  9. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Me too. That's why I started it. Always interesting to toss ideas around and get opinions from those with experience. Maybe we should start an Online University of 348. " Earn a degree in your spare time! "
  10. cactussed
    cactussed Formula Junior
    Mar 12, 2008
    299
    My 2c would be that a garage will generally opt for engine out as they can charge more (and see more of what's going on, so you're aiming at the DIY fan (which may or may not be a growing subset of owners as the cars age).
    For the DIY guy at home, very few will have access to a proper 4 post lift, so will be working with 2 jacks which I suspect will make dropping the cradle arguably a better option as there's not much room to drop the tank with just jacks and then not a lot of space to crawl under and do anything.
    A better idea (IMHO) would be to make a wiring harness adaptor which ran from the ECU's behind the seat to a plug at the bulkhead. I've found my biggest bugbear is threading the looms in and out of a hole that is 0.0005mm bigger than the sodding plugs. If you could simply reach down and unplug the loom from a clip in the engine bay (like Porsche do) it'd be very helpful.
    the rest is fairly straight forward (assuming its been done before and everything isn't rusted / siezed solid). I seem to recall the 2 spanners on the power steering line being difficult last time...
  11. yelcab
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
    I read that Jenni Helms, head mechanic of Scuderia Rampante can remove a 348 engine in 2 1/2 hours. At that speed, why not remove the engine?
    taz355, Wade, INTMD8 and 1 other person like this.
  12. m.stojanovic
    m.stojanovic F1 Rookie
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    Less than 2 hours:
    Wade, INTMD8 and WATSON like this.
  13. cactussed
    Mar 12, 2008
    299
    2 hours is mad. I've don 5 hours on my own being methodical.
  14. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
  15. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    He has better technique than me. I have to go inside the interior, remove the panel behind the seats, unplug the computer harneses as well as some other wire connectors and use 4 letter words trying to stuff it all through the bulkhead. The video guy never even had to open the doors. Must be an obstetrician...used to removing things through small orifices.
  16. yelcab
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
    If I had a large work space, the car is prepped on a 2 post lift, all the tools laid out in sequential use on a table, a rig for the engine to rest on, and I was trying to set a record, I can probably blast through 3-4 hours. But slower is better. You have to stop for a beer, you know.
    WATSON and steved033 like this.
  17. m.stojanovic
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    He probably spent 3 hours or so dealing with the ECU harnesses and what not but did not show in the video. What I like is that it can be done without a workshop lift.
  18. steved033
    Apr 12, 2017
    10,477
    Atlanta, GA
    Steve D.
    it's even easier if you can get the entire car up about 15"-18" off the ground.
    sjd
  19. yelcab
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
    I watch that video several times and to be frank, I don't get anything out of it other than …
    1. You can do it wearing flip flops
    2. You can do it in a garage without opening the door
    3. You can do it with two jacks
    4. He also has a Ducati 998.
    It really does not tell me much more
  20. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    When I was 18 I had a 1988 Ford Mustang. It needed a new serpentine belt. Ford wanted to charge me 45 minutes. I took it to an independent, it took the guy about 20 seconds and it was so quick I didn't even get a chance to get to the waiting room, I stood right there and watched him. And, he didn't charge me anything.
  21. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Ah yes...the dreaded dealer flat labor charge based on the "book" estimated time needed. Of course that is based on throwing instructions and a few tools into a room with the car and a few chimpanzees and timing the whole thing.
    That raises a question. The original premise of this thread was how to drop the cost of a "major" to make ownership a little easier. I don't know what a quote for a 348 major from a Ferrari dealer would be, but I'm guessing somewhere between $5 - 7K. But you can be sure that's based on the book charge. One wonders how many hours it actually takes an experienced technician to do it, and what the cost would be if they charged hourly rate. If they could drop the engine in 2.5 hours and get it back in in 3.5 hours, then allow 4 hours for belt change, valve clearance check etc I suspect the bill wouldn't be quite so scary.
    Problem solved!!
  22. yelcab
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
    Book rate is 40 hours for a 348 engine out tune up. At $245 per hour, that is close to $10K labor. Add $2000 for parts and you are at 12K$ before any while you are in there stuff adds up. This is dealer pricing, of course, but if you are taking it to a dealer for this job then you get what you get.
    We DIYers keep forgetting that we are the minority of owners who actually work on their cars, and even fewer of us who would remove engines to work on a car. The majority of Ferrari owners who are quite well-to-do have much better things to do and would just write a check. The trick is to know whom to write a check for.
  23. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,631
    The Brickyard
    The Bad Guy
    And like I said,
    The cars where designed to make perpetual revenue in my opinion. $10,000 labor to change a $100 belt, it has to be on purpose.
  24. ernie
    Nov 19, 2001
    22,631
    The Brickyard
    The Bad Guy
    Maybe just for kicks I do an engine in belt change the next go around?
    Muuuaaahahahahaaaaa!!!!! :D
  25. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,832
    Lake Villa IL
    #50 INTMD8, Jan 16, 2020
    Zero.
    The amount of work to drop the tank, engine then cut out the the main bulkhead after properly bracing it, fabricate end pieces and welding them in with perfect fitment then re-installing..... You are already at one major service, plus fuel tank, plus a ton of labor and some parts and you have a cut car with a main structural component now bolted together.
    Would have to from that point on remove the fuel tank and crossmember to squish yourself up in front of the engine in order work on it and I for one would not want to be setting up dial indicators and degree wheels from that position. (how much time have you saved at that point)
    If somehow it ended up saving you money over the course of several services (couple hours here and there?) you're probably 15 to 20 plus years into it with the best of luck and no one would want the car with the question of possible loss of structural integrity.
    There is no way enough effort involved in properly removing the driveline to warrant this.
    phrogs and 2NA like this.
