E8 code on climate control display 348 | FerrariChat
Discussion in 'Technical Q&A' started by RAYMAN, Apr 11, 2004.
  1. RAYMAN
    RAYMAN Formula Junior BANNED
    Mar 10, 2004
    315
    Oklahoma
    Raymond Santilli
    Anybody know what this means? Came on while I had the heater running, then none of the buttons would respond.
  2. GeorgW
    GeorgW Karting
    Jan 31, 2004
    103
    Germany
    Georg
    Hi,
    the same happens to me with my 1993 348 ts same days ago: after around 30 minutes of driving the "E8" code appears insteat of the temperature and the heater stops working.
    At the next day it has self repaired overnight and everything was normaly and operating as usual.
    The workshop manual says, code "E8" means "electric water pump for heating" , but maybe it was just a disfunction of the heater control unit, because it happend only one time ?
    Good luck & regards from germany, Georg
  3. Chuck550
    Chuck550 Karting
    May 15, 2001
    210
    Mechanicsburg, PA
    "E8" is an electrical gremlin in the 348's rather crappy climate control system electronics. I used to get it occasionally on my 93 348, and the fan would start blowing unheated air. Turning the car off and restarting would sometimes reset it, sometimes not. I believe there are some posts on the old board about this, having something to do with poorly soldered connections on the circuit board for the climate control. This circuit board can be accessed by removing the center console, and I think there are also instructions for this on the old board. I remember the late Jens Haller, a great guy who loved his 348 and wanted to share everything he knew about it, had all of the connections on his climate board resoldered and it solved his "E8" problem. I would suggest that you search the old board for this issue.
  4. RAYMAN
    Mar 10, 2004
    315
    Oklahoma
    Raymond Santilli
    Very helpful thank you!
  5. Triple Black
    Triple Black Karting
    Feb 8, 2014
    217
    Millington TN
    David S
    I've got the same code a few times now and it is not listed on My348. Does anyone have any more ideas about this , or do I need to start re-soldering the control boards and checking all the grounds.
    Any ideas would be much appreciated.
  6. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,554
    Jeff
  7. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Before doing anything crazy, first access the plug in the back of the climate control unit and wiggle it around, or unplug it and plug it back in to see if that helps. 9 times out of ten that seems to be the problem. When you see the plug its a bunch of teeny tiny connector pins. One wonders how any electrons can pass through there at all.
  8. Triple Black
    Feb 8, 2014
    217
    Millington TN
    David S
    Much appreciation, Easter took all my time this weekend. I will check the electrical socket, put some Stablant 22 ( or however you spell it) on the connectors and see what happens next weekend. If I have to dig further, so be it, I hate having codes show up. I'll update as this plays out.
