Early 308 engine lid prop retractor | FerrariChat
Discussion in 'Ad Archives' started by sowest, Mar 17, 2015.
  1. sowest
    sowest Formula Junior
    Aug 18, 2006
    899
    #1 sowest, Mar 17, 2015
  2. BigTex
    79,331
    Houston, Texas
    Bubba
    A rare piece in wonderful condition!
    GLWS!
    I need the bottom fitting of the prop rod if you run across one...I'd buy the whole thing if I have to.
  3. sowest
    Aug 18, 2006
    899
    Hi Big Tex
    Thanks for your message. I am sorry that I can not help you with the part that you are looking for.
    SALE PENDING
  4. Casino Square
    Casino Square Formula 3
    1,728
    Hong Kong / USA
    Andrew
    i'll take it if available. PM sent.
  5. sowest
    Aug 18, 2006
    899
    Hi Andrew
    I do have a sale pending. If for some reason that doesn't happen, I will contact you.
  6. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,774
    Indy
    Bill S.
    Just saw this, I guess I'm too late.
    Anyone know if a frayed cable can be replaced without replacing the whole retractor, and where to get the cable?
  7. sowest
    Aug 18, 2006
    899
    Hi Bill
    I wish I had ten of these things....;>) I have never tried to change the cable in one, but it must be doable. I think the big question would be if the two parts could be separated without doing fatal damage. I guess the amount and type of glue that was used would be the key. A suitable 1/16" cable could be found at almost any hardware, home improvement store. If you look at the picture of the bottom of the unit, it looks like there is provision for getting a blade in and prying the two pieces apart.
    The original buyer is starting to look "iffy", but "Casino Square" is next in line.
  8. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,541
    Avvocato
    Larry, check your papal again, the money should be there, check your PM box.
  9. ragtop1
    ragtop1 F1 Veteran
    5,224
    Ontario
    Larry Warren
    Verrel from Unobtainium Supply was attempting to make this part as well as the bottom fitting for the rod prop. The thread is in the 308/328 section. I'll see if I can find it or perhaps contact Verrel and see how he is making out. I sent him an old spool retractor that he could use for a pattern.
  10. 308Kelly
    308Kelly Rookie
    May 18, 2004
    22
    Hartford Area
    Edward
    I need the bottom fitting also.
  11. ragtop1
    ragtop1 F1 Veteran
    5,224
    Ontario
    Larry Warren
  12. BigTex
    79,331
    Houston, Texas
    Bubba
    Pull it out past the wear point and reconnect it!
    There's more in there than you need!
  13. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
  14. jgmblair
    jgmblair Formula Junior
    783
    Winnipeg, MB Canada
    Jeff Blair
    I was able to get this from Maranello recently and was hoping someone would be kind enough to describe or post a picture of the correct fasteners. Head type, length, size and thread pitch.
    bernardo66 likes this.
