Easier engine cleaning | FerrariChat
Discussion in '348/355' started by barstool, May 12, 2020.
  1. barstool
    barstool Rookie
    Apr 11, 2018
    7
    New York
    Nick Muir
    Hello all, I got bored during the COVID lockdown, so I'm rebuilding my spare 355 engine in my home office :)
    I also got a 3D printer, so figured I would combine the two hobbies and make port blanking plugs so I can clean and polish without having to worry about gunk falling in through the intake holes.
    -Nick
    MikeeB355, jqpd99, Julia and 4 others like this.
  2. PaulK
    PaulK F1 Rookie Silver Subscribed
    Apr 24, 2004
    4,788
    Michigan
    Paul
    Very cool. If you could make a complete set with covers for the air intakes after the air filter and covers for the lines when you disconnect everything, it would be perfect for people who want covers when they do their own majors. :)
  3. barstool
    barstool Rookie
    Apr 11, 2018
    7
    New York
    Nick Muir
    That's the plan. For lines, I can just use standard caps or plugs, this is more the the oddly shaped bits.
  4. PaulK
    Apr 24, 2004
    4,788
    Michigan
    Paul
    I'd love to buy a set if the price is reasonable. Please keep me posted.
  5. watkinsgt
    watkinsgt Karting
    Feb 4, 2008
    215
    Barstool. Gorgeous. Would you make me plugs to seal the fresh air intake hood vents to keep water out when pressure washing?
  6. taz355
    taz355 F1 Veteran Owner Silver Subscribed
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Looks really good what is the trick to making them fit so nice, tapered maybe?
  7. barstool
    barstool Rookie
    Apr 11, 2018
    7
    New York
    Nick Muir
    These still need a lot of work, as of now they just sit flat, so they pop out easily, so I'm going to redesign with some tabs that go into the ports to get a better seal. The left bank ports were all nice and uniform, but the right bank had been ported a bit, so I added some material to fill the hole. I took a photo of the ports, brought that into my modelling software (Rhino 3D) and adjusted the design accordingly. Measurements were done with a Neiko 01407A Digital Caliper
  8. barstool
    barstool Rookie
    Apr 11, 2018
    7
    New York
    Nick Muir
    What part are you looking to block off specifically? I was going to make some simple intake plenum ports that would seal up the engine after removing the air sensors.
  9. PaulK
    Apr 24, 2004
    4,788
    Michigan
    Paul
    He might be talking about the vent on the hood for the cabin air.
  10. watkinsgt
    watkinsgt Karting
    Feb 4, 2008
    215
    Barstool, Paul K is correct - the vents on the hood for cabin air. It would be nice to wash the 355 without getting the cabin air receptacle under the hood wet. Rags and tape don't cut it. I've been using short lengths of vinyl tubing. Works ok but if you can fab pop in/out plugs that would be great.
  11. barstool
    barstool Rookie
    Apr 11, 2018
    7
    New York
    Nick Muir
    Sorry, my printer can only do 15cm wide prints, so a wide plug like that seems unlikely.
