Easiest DIY 3X8 to Wrench on? | FerrariChat
Discussion in '308/328' started by Schulz308, Dec 4, 2022.
  1. Schulz308
    Schulz308 Formula 3
    1,500
    STL USA
    In your opinion,
    For a home garage enthusiast whom seeks equal pleasure of tinkering and reward of driving
    Which configuration of the 308 lineage is the most dependable and simple to repair as possible and why?
    moysiuan likes this.
  2. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I think there's only three motors to chose from. 2V carbed, 2V injected, and 4V injected. I think the injected cars are easier to keep in tune and running. I don't think the number of valves maters much until you have to replace them.
    Oh, I suppose there's also points ignition and electronic ignition. So I think there's also three of those: Dual distributor, single distributor, and electronic that's also dual distributor. I vote the latter.
    And then there's smog with various number of air pumps, catalytic converts, EGR, etc. If you have to pass smog the 84-85 wins here, I think. If not, well it doesn't matter. You can pull it off and put it in a box in the attic if it's problematic.
    Other than that everything is pretty similar. The GT4 has a little tiny bit more engine room and I think it's easier to work on the motor with the lid in place than the GTS/B, but not enough that it would sway me from one to the other.
    TLDR: 84-85 QV
    EDIT: Wait, does the "308 lineage" include the 328? Because I think that would change my answer.
  3. Schulz308
    Schulz308 Formula 3
    1,500
    STL USA
    I asked moderator to edit the "308" to "3X8" when possible,
    Yes the 328 is included.
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,631
    South East
    Jimmie
    If you've owned a carb and a QV surely you have the experience already to answer your own question ?
    eskamobob1 likes this.
  5. Schulz308
    Schulz308 Formula 3
    1,500
    STL USA
    #5 Schulz308, Dec 4, 2022
    Owning a carb car and QV cars has actually caused this question.
    The variants between US and Euro with mechanical carbs vs Bosch injected differences or lambda vs non, emissions equipped or not, all has been a mixed bag so far.
    I have much to learn and Still have not owned a GT4, 328, dry sump or vetro etc.
  6. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
    I have a 1978 308 GTS…
    Jan 6, 2022
    California smog check done yesterday and passed easily for a carbed 308.
    Only changed one jet: idle mixture jet from 55 to 65. All other jets per owner’s manual. Idle jet at 55 is too small for todays gasoline.
    Idle set to 1000 rpm.
    Smog technician said my having the rear distributor triggering the rear and forward banks, so that the same advance curve is used for both banks made it very easy to get it to pass.
    Good for another 2 years.
  7. Schulz308
    Schulz308 Formula 3
    1,500
    STL USA
    Is your car cat free?
  8. Jonny Law
    Jonny Law F1 Rookie
    3,199
    Over yonder.
    IT Guy
  9. Harry-SZ
    Harry-SZ F1 Rookie
    I would go for an injected 308 and preferably the QV of course.
    Just as reliable as a 328, but still with the cool switches and gauges of the earlier cars.
  10. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    748
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    Ultimately a euro ( no smog gear ) 2V .Carbs once set are Uber reliable they are not a differentiator against .
    .Arguably the more simple more basic the easier for a DIY er .The less electrotwackery, the simpler switches etc the more Fiat , Alfa , Lancia cross parts sharing = easier to source parts .
    The more analog, less reliant on electrotwackery surly the better ?
    A garden 2 T bush whacker Vs a space shuttle , its a no brainier .
    This is a different question to which is a better driver which inevitably boils down to Hp increase and finer luxury touches like more effective semi climate control HVAC , ABS and more engine electrotwackery with sensors to aid starting and power delivery.
    All of the above = more to go wrong = more head aches from a DIY er in his garage at home with a I pad in his hand trying to figure out why his ABS light is illuminated or HVAC steams up the screen etc or worse the engine is dead .
  11. Portofino
    Sep 17, 2011
    748
    Portofino
    Agree .
    He’s not asking which is more reliable or better or more efficient etc .
    Read the Q ?
    There’s more to go wrong and increased difficulty home tinkering with those “ cool switches “ and EFI .
    An early pre 80 s heater valve is just a flap and lever connected by a kids bicycle brake cable that can be adjusted at either end with a flat screwdriver .
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,828
    Mike 996
    There is a difference between "easiest to wrench" and "requiring the least wrenching." Which is more important is a personal decision.
    IMO, easiest wrenching would be a carbed 308 because everything about it is very basic and relatively simple mechanically. OTOH, based on all the various posts for the 14 years I have been on this site, the 328 is the most reliable/requires the least wrenching.
  13. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,130
    SanFrancisco BayArea
    1983 US 308 GTS QV
    The fuel injected 308s use the Bosch K-Jetronic system which, until the 1984 model, was solely hydraulic and vacuum controlled. Most people consider it “set and forget.” Starting with the 1984 model, an oxygen sensor, electronic processing board and frequency valve were added to maintain lambda through a broader range of throttle settings.
    Eventually the 308 line changed from points-and-condenser to “electronic” spark boxes but even those required an analog vacuum input. Many people agree that spark boxes are more reliable than the points-and-condenser system.
    The 328s have improvements in bearing sizes and other important design elements but, after 30 years, the 328 has just as many things that can fail as a 308. Electric hvac switches, instead of the 308’s mechanical, is an example.
  14. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,129
    Mansfield, TX
    Ron
    Harry-SZ likes this.
  15. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,828
    Mike 996
    "after 30 years, the 328 has just as many things that can fail as a 308."
    That is correct, there are more items that COULD fail but it's important to separate routine maintenance items with items you have to repair/replace on any vehicle because they are 30+ years old.
    If you start with an "as new" car, the 328 has less NEED for repair as can be seen simply by looking at the posts on this site over the last 20 years and/or posts by folks who made a living working on these cars.
  16. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
    My 308 has original Cats. Purchased 308 with 16k miles, now 25k miles.
