Easy 328 headlight question | FerrariChat
Discussion in '308/328' started by Jeff328, Aug 23, 2022.
  1. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    Feeling kind of dumb, I've had my 328 for 16 years and don't know the answer to this. My owners manual is tucked away in a safe and not easily accessible.
    How do you get the headlights popped up but not illuminated? I've tried various combinations of switch positions but still can't figure it out. I know it has to be possible because when I replaced my headlights years ago I don't remember them being illuminated when I made the change.
    Thanks for the help!
  2. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Pop them up and unplug the battery?
    Dr Tommy Cosgrove likes this.
  3. Cennzo
    Cennzo Karting
    Jan 29, 2020
    111
    Sausalito CA
    Vince Dattoli
    Right. You turn them on and there’s a battery cable disconnect plug under the hood behind the driver’s side headlight.
  4. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    Thanks. That's probably what I did last time to replace the lights, that only takes a few minutes. But I need to have the lights up but off for a few hours for a display at a car show. I hate to have to reset the delicate clock too many times and was hoping there's another way.
  5. Dave Bertrand
    Dave Bertrand Formula Junior
    824
    Castle Rock, CO
    To reset the clock without touching it, you could keep the battery disconnected until the clock displays the correct time, then reconnect the battery. :)
  6. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    Silly as it sounds that may be what I do.
  7. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,254
    Worcester, England
    Phill J
    To have the headlights up without the bulbs being illuminated, without disconnecting the battery:
    Pop the headlight pods up by rotating the headlight column switch.
    Open the fuse box cover on the passenger's side and remove fuse No.1 - This is a 25A fuse at the far right hand side of the fuse block, for the headlight pod motors (it should be indicated on the fuse layout diagram, on the inside of the fuse box cover)
    Turn the lights of via the column switch.
    The headlight pods remain up without the bulbs being illuminated.
  8. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,807
    Australia
    Mark R
    As you've probably figured out by now there is no switch, button or stalk setting to raise the headlights without them being illuminated.
    Need to use the battery disconnect plug hack.
    My 323 Mazda had that option it but that was a Japanese car first released in 1990.
  9. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,254
    Worcester, England
    Phill J
    No need to disconnect the battery - Just raise the headlight pods by rotating the column switch, pull fuse No.1 for the headlight motors, turn the lights off via the column switch, and the headlight pods stay up with no lights on.
    Rosey likes this.
  10. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    Thanks for the tips. I've owned my 328 for 16 years and have never even looked at the fuse box.
  11. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,807
    Australia
    Mark R
    Same !!
  12. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Why start now. The stock fuse boxes can be troublesome. Unplug the battery at the disconnect switch.
    Rosey likes this.
  13. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,807
    Australia
    Mark R
    +1
