Easy fix for 308 power windows | Page 2 | FerrariChat
Discussion in '308/328' started by techcote, Jul 4, 2010.
  1. MarkJ
    MarkJ Formula Junior
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
    #26 MarkJ, Jul 7, 2010
    I kinda like the novel approach to fixing the slow windows. I wouldn't think of such a repair on an engine, but on a window motor, why not? Even if you have to inject some new WD every 12 months, you're still time ahead. Less time working on the car and more time driving it is a good thing in my book. When you're piloting your car through the twisties, wind in your hair, smile on your face, no one cares what grease you're using in your window motors. Although not everyone would want to use your idea, I'm glad you shared it, Chris.
  2. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Try the Wurth stuff instead. Works REALLY well.
  3. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    I did this back in the 1980's, except I didn't drill holes, i just sprayed inside the emergency crank hole and it worked.
    For a while. Maybe 2-3 months, then you had to do it again.
    And WD40 is not the thing to use, as the lighter ends evaporate, it leaves a gooey, then slowly hardening varnish, that is worse than before. WD40 is the perfect stuff to make a functioning firearm non-functional by using it to clean and lube, then sticking it in a drawer for 2 years You would be better off with some sort of spray oil, not WD40.
    Doug
  4. bill brooks
    bill brooks F1 Veteran
    5,997
    waynesburg,pa
    bill brooks
    #29 bill brooks, Jul 8, 2010
