Easy Volt Meter Project | FerrariChat
Discussion in '348/355' started by marcov, Oct 28, 2017.
  1. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    My alternator fail a few weeks ago. The alternator light never come ON and left me stranded!
    So i got a modern alternator (generating 90A at idle) and modify the alternator bracket to mount the new alternator. Now I have a modern reliable charging system that will handle both fans coming ON at the same time for less than $150.00.
    However I still did not trust the alternator warning light, so I got a mini voltmeter/display unit of Ebay:
    (http://www.ebay.ca/itm/LED-Digital-Voltage-Voltmeter-DC-2-4-30V-2-Wire-LED-Display-Panel-Car-Motorcycle/162336765007?ssPageName=STRK%3AMEBIDX%3AIT&var=461359023815&_trksid=p2060353.m2749.l2649).
    Installed it in the dash in an empty slot in the lower right hand side and now i have piece of mind.
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    #2 SoCal1, Oct 28, 2017
    Nice Marco.
    What alternator did you use? A denso
    Ahh heck I just checked a toy alt I have here, looks like a winner same pully also
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Nice work - that's very clever ;)
  4. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    The alternator is for a newer Ford Mustang. It was the closest to the original AC DELCO.
  5. watkinsgt
    watkinsgt Karting
    Feb 4, 2008
    215
    Marco, would you be willing to expound on your ingenious mini volt meter/display unit install?
  6. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
    hello and thank you for sharing. I find the result very discreet. do you have a photo tutorial of your assembly, as well as your fixing procedure. again, top
  7. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    Sorry, i did not take any additional photos. What I did was buy a LED Digital Voltage Voltmeter (as per the Ebay link). These are a small form factor 3 segment digit LCD with a integrated circuit to measure voltage. I epoxied the back to protect the exposed circuit and strengthen the two wires. I also trimmed the two mounting tabs on either side of the device with a Dremel.
    I then removed the instrument cluster (very simple by removing the two Philips screws at the bottom). I then disconnected the five connectors at the back of the instrument cluster to remove from the car.
    Once removed, gently pry the bottom indicator lens (running across the bottom of the instrument cluster). I then removed the plastic with the indicator symbols and trimmed the right most spot. On the instrument cluster cell there is no light but there is a removable bulb cap. I removed the bulb cap and ran the wires of the volt meter in the hole left by removing the bulb cap. I then inserted the voltmeter in the free cell and reassembled the indicator lens.
    I then found a source of 12 volts from the instrument cluster (+12 directly from the tack, and -12V from the oil gauge.).
    I then reassembled everything!
    Qavion and Ga68_ like this.
  8. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
    Merci Marcov
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I did not see the dimensions of the led gauge.
    Did I miss them or do you have them
  10. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    It is about .3" x 0.85" It fits perfectly in the free slot with no drilling.
  11. krazykarguy
    krazykarguy Formula Junior
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    I did the very same thing on my motorcycle (which has a history of charging issues).
    Be aware that you should measure the voltage at the battery and then using the new meter itself, just to be certain that the readings are the same. My dash meter reads exactly 1v lower than across the battery terminals of the bike. In other words, if I have 14.4 at the battery, my dash meter reads 13.4. Once you get accustomed to the 'normal' reading, it's fine for monitoring the health of the charging system.
    For what it's worth, the meter is getting it's voltage from the dash illumination (always on with a motorcycle, key 'on') 12v+ and grounded to a common ground on the cluster.
  12. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    Over the years, i fixed a few grounding issues with the 348. My voltage reading from the dash 12V source is less that 0.1Volts off.
    Ga68_ likes this.
  13. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
    [QUOTE = "marcov, poste: 145651160, membre: 57655"] Au fil des ans, j'ai corrigé quelques problèmes de mise à la terre avec le 348. Ma tension de la source 12V du tableau de bord est inférieure à 0,1Volts. [/ QUOTE]
    Bonjour, avez-vous des conseils à nous donner suite à votre expérience sur les masses à améliorer.
