ebay turbo kit for 348/ 355 | FerrariChat
Discussion in 'Technical Q&A' started by spider348, Mar 28, 2005.
  1. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    May be of interest to many of you seeking more hp from your 348/ 355. ebay item 7964518213
    Lists a complete intake and exhaust turbo assembly claiming 400 RW hp! Buy it now price is $1999.99. I have no idea regarding quality, completeness etc. Looked darn interesting though!
  2. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    My gut feeling is this is a really bad idea. What's the comp. ratio of these cars? Too high for a turbo I bet. Then you'll be stressing parts in a way that they weren't designed for. Sounds like an expensive experiment....
    Ken
  3. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    I saw that earlyer on, the kit does not look complete. I have no probs in buying a complete kit. What i dont want to do is start searching for parts.
    And i think its more for the 348s.
  4. jjstecher
    jjstecher Formula Junior
    Jan 21, 2002
    962
    Rochester Minnesota
    John Stecher
    Damn them for making this available on eBay just when I had settled on only trying to make more hp with a new set of cams. This is a very interesting kit at an interesting price. I am trying to find out how complete everything really is.
  5. TURBOQV
    TURBOQV Formula Junior
    Mar 6, 2003
    838
    NV and Utah
    it usre is.
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,733
    The twilight zone
    For big stuff, your going to need injectors and a motec M48 or M8, maybe $4k for that stuff. It looks like all the other big stuff is there....of couse an intercooler or 2 would be nice too.
  7. f355spider
    f355spider F1 World Champ
    18,044
    I would be curious to know why it was removed from the 348.
  8. vincent355
    vincent355 F1 Veteran
    6,516
    Wine Country
    Vincent
    Who would want that much horsepower? ;)
    the ad says it was taken off to sell the car. I know some people who would rather buy it with that stuff on there. ????
  9. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    I bet ya that the car seller never tells the new buyer about the car having turbos.
  10. Etcetera
    Etcetera Two Time F1 World Champ
    23,972
    C6H14O5
    He mentions that it is a Norwood product. It doesn't look like a Bob Norwood product. Maybe Bubba Norwood.
  11. Etcetera
    23,972
    C6H14O5
    #12 Etcetera, Mar 29, 2005
  12. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Agree - something is missing from the story. Interesting that he kept the Motec system, although photos look like the Motronic box is still there.
  13. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    59,757
    Australia
    read the first few pages of this :
    http://www.ferrarichat.com/forum/showthread.php?t=29754
    it may change your mind about the "fragility" of these engines
    Warning : it drifts off after a few pages into stupidity
  14. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    #15 348 Turbo, Mar 29, 2005
    I am familiar with this setup.
    This was removed from the only other car done by Norwood that was still on the street in the US. There were three done for US customers, the other was totaled on the track, I have # three. There is a forth Norwood 348 Turbo in Spain, (last I heard).
    I've previously contacted this owner. He is an engineer who was laid off quite a while ago and had to sell the car for $$$ reasons. He guessed he'd get more for it he parted it out, (I'd agree). Perhaps this is why he sold the MOTEC separately.
    As far as I know, it is genuine Norwood. If you put it on your car, it'll be a kit, NOT a Norwood conversion. The two are not to be confused. As far as I know, he, (either Bob or James), used copper head gaskets, chemically coated the pistons and valves, changed the injectors, changed the fuel pressure, and tuned the engine to run properly, "pressurized". Probably some other mods as well. Not all Norwood cars were intercooled; it depends on how the customer ordered it.
    For lower boost levels, stock compression hasn't posed a problem.
    THIS is a Norowood car:
  15. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
  16. FIAutoSports
    FIAutoSports Formula Junior
    Nov 13, 2004
    620
    Baltimore, MD, US
    John Ritenour
    Here is a less cluttered post with pictures:
    http://ferrarichat.com/forum/showthread.php?t=42376
    If you think that you will be able to run more than 5-6 psi off the stock ECU and fuel system, you would be wrong. Significant amounts of boost have massive fuel requirements and running upwards of 10-13psi will typically require injectors that are 110-150% larger than stock, depending on tune, engine, efficiency, altitude, etc.
    And I think the Norwood kit also replaced the pistons, but I am not sure.
  17. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    I'm not sure if the Norwood "conversion", (I shy away from calling it a kit, that I think makes it sound like it is an "add-on"), changes the pistons in all of their cars. In my car, yes, the pistons were changd to a custom designed, JE racing piston. Also, it has matching JE rings.
  18. Etcetera
    23,972
    C6H14O5
    Whatever. The guys at Norwood will have the final say. I've NEVER seen rubber elbows used even in low boost applications. My SAAB had alu elbows that were bolted together and still blew apart...even at low boost.
    But whatever.
  19. TURBOQV
    Mar 6, 2003
    838
    NV and Utah
    That is James Patterson on Top who purchased Norwood Performance.
    Bob usually like to tinker with them on the dyno tuning them to perfection.
  20. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    Hummm.
    sounds like the plumbing on your Saab was inadequate. It is common for pressurized plumbing to have "rubber elbows". Ever read "turbo magazine"? Norwood, (whom by the way, set multiple records at the Bonneville salt flats in turbo charged Ferraris). They have been using them on much higher boost engines than your SAAB. I don't intend to start an internet argument, but you might want to do some interesting reading:
    http://www.bobnorwood.com/Norwood%20Accomplishments.htm
    enjoy!
  21. TURBOQV
    Mar 6, 2003
    838
    NV and Utah
    Don't waste your breath Jeff. Could be futile?
    Paul
