ECU Bypass and CEL 5/8 Question? | FerrariChat
Discussion in 'Mondial' started by TampaTMM, Feb 24, 2015.
  1. TampaTMM
    TampaTMM Rookie
    Aug 9, 2014
    46
    Tampa, FL
    Terrance Maloney
    #1 TampaTMM, Feb 24, 2015
    While on a spirited drive Sunday my Check Engine 5/8 Light came on in my Mondial T. All temps and pressures were fine and I was close to home, so I limped back. During the last couple of miles I also noticed that the car did not have that eagerness to Rev, so I let the car cool overnight. The next morning fired it up noticing a rich burn and rough idle.
    After reading all of the Mondial and 348 blogs I could, I got under the hatch and disconnected each of the MAF's to see if the engine would react; it did. I crossed those off the check list and thankfully. I then went on to check the ECU's and this is where I have a question. It appears that the ECU's are now direct wired to the O2 Sensors via a small braided wire. I disconnected these and swapped them, which reset the light and the car started to idle and rev fine. I then switched them back and everything appears to be working, no lights. Great! Thank you FerrariChat friends for your guidance.
    Now, my bigger question: with the ECU's being direct wired, now having extra connects and unknown buttons on the firewall, I'd appreciate any help if you have seen this, why it may have been done and if I should be concerned about any lost functionality.
  2. TampaTMM
    TampaTMM Rookie
    Aug 9, 2014
    46
    Tampa, FL
    Terrance Maloney
    #2 TampaTMM, Mar 1, 2015
    The wire that I thought was bypassing the ECU is actually a factory wire (#29). This connects thru the firewall to the sensor. There is however the button on each side and unplugged wire into Motronik that I dont understand. Any help here is appreciated.
  3. Rapalyea
    Rapalyea Formula 3
    Jun 18, 2013
    1,511
    Georgia Mountains US
    David Rapalyea alias
    Fascinating issue. I believe the earlier Bosch units did not have O2 sensors; mixtures were simply adjusted with a simple hex screw located within the distribution unit. As time went by the margins of O2 error became legislatively more narrow.
    I remember my aftermarket suppercharger [5.0 Lincoln] would command a sudden rich condition at boost which took some time for the O2 sensor to stabilize. (That was Speed Density). The emision control device to eliminate this was to put a wooden block under the accelerator peddle so the test technician could not activate much boost.
    In normal driving the rich condition never was seen long enough to smell sulphur but the Check Engine {rich condition} would flash on and off. A short length of black electricians tape over the light was sufficient.
    My Mondi 3.2 does see rich condition from time to time and the light comes on then goes off. Never any sulphur smell. The light is where I never see it to begin with. And of course I do not have emissions checks out here in my rural area. But here is the thing!
    I actually removed the cats from my 1984 Z-28 and still passed emissions by simply splicing a plumbing T valve into the PCV line. Just introcuce some sucking sound air to the intake and bingo. Full compliance.
    It is not clear to me how many US States require a full exhaust sniffer test on older cars. My rural county in Georgia does not require any tests on any cars. Further, it is my understanding many jurisdictions simpy require a visual that nothing has been removed, and do not require an actual sniffer test on older cars.
    This all seems like common sense to me. We call it 'The Grandfather Clause'. Specifcally, it is not worth the grief and cost to police up the few aborant vehicles mostly poor people use to get about.
  4. motomike8
    motomike8 Karting
    Jan 7, 2015
    60
    Phoenix, AZ
    I have the same weird setup on my T. Someone installed aftermarket cats and some of the sensors are unplugged and I have those weird buttons as well.
    If you figure out anything more on this setup let me know. I'm getting ready to pull the cats anyway and install test pipes.
  5. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    #5 davebdave, Apr 3, 2015
    The weird buttons are for retrieving the stored ECU fault codes. Check my348.com for instructions on how they work. The green faced box on the left of your photo is the cat temp ecu. They can be disconnected but the main ECUs will not know how hot the cats are and therefore won't illuminate a slow down light in the event of an overheat. A few owners have installed aircraft style Exhaust Gas Temperature gages to monitor cat temps., a cheaper option than replacing the cat ECUs. The green face on yours indicates a replacement. Originals were black.
    Dave
  6. DavidJ
    DavidJ Formula Junior
    Feb 12, 2012
    387
    Northern NJ
    David
    I had 3 issues.
    The first time it was a dirty MAF sensor plug contact on the right bank.
    Deoxit-5 to the rescue. Cleaned the contacts, wiped off the excess. Fixed.
    The second time I had a cooked thermo sensor that is screwed into the Cat. That was replaced and all was well.
    The third time I got a slow down light which then went to a stop engine light. It was the little green ECU. They are real crap parts. Any dampness or moisture that creeps into the ECU between the plastic shell and the epoxy will cause havoc.
    If you take the ECU out and put it in the hot sun for a few hours with a couple of small screw drivers separating the plastic shell from the epoxy, the moisture will evaporate out. Then re-glue the shell to the epoxy encapsulate with silicone bathroom caulk, the good stuff that lasts 50 years. That should seal it up forever. Hopefully no more moisture will get in to that thing.
    I got tired of this crap and had the innards of the cats removed. So now there is no way I can get an over-heat condition, there is nothing to overheat.
    The car runs the best it ever has.
    DavidJ
