ECU not resetting | FerrariChat
ECU not resetting
Discussion in '360/430' started by Black360, Mar 1, 2025.
  1. Black360
    Black360 Formula Junior
    Oct 11, 2010
    437
    East of Eden
    Steve
    Working to resolve P1125 on my 360.
    Tried to reset ECUs with my scanner.
    Long Term Fuel Trim (LTFT) for Bank 1 resets to ~ zero. Bank 2 LTFT resets to 8.6
    Before reset LTFT Bank 2 ranges from ~ 15 to 18.
    Have repeated this several times; always the same result.
    The shop executed reset with a Leonardo; same result.
    Upon restart, you can guess that a full reset has not occurred because the idle is only slightly rougher than normal, as opposed to sounding like it’s barely running.
    Thinking of swapping ECUs, side-to-side, but thought I’d see if anyone else has had something similar.
    Thanks.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    Did you remove power source for an hour and then see if that worked
  3. Black360
    Oct 11, 2010
    437
    East of Eden
    Steve
    Thanks for your response.
    They are supposed to try a power off reset Monday.
    Note that Bank 1 resets with no problems, and Bank 2 LTFT resets, but doesn’t zero.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    Have you tried another car ..not sure if it does the same thing with a diag tool on this model
    Black360 likes this.
  5. Black360
    Oct 11, 2010
    437
    East of Eden
    Steve
    Wondering if it makes sense to disconnect the upstream O2s and check voltage on the downstreams?
  6. Black360
    Oct 11, 2010
    437
    East of Eden
    Steve
    Did you mean try another 360?
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    Yes
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    The battery reset should wipe it out
    Then a 10 min idle at operating temperature with stabilize the trims ..unless you have an issue ..e.g vacuum leaks, MAF , upstream 02 sensors etc
  9. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    If your lucky your ECUs haven't been put into someone else car before or one swapped out from a breaker at some point. In this case you should be able to swap the LHS with the RHS. At this point your CEL of P1125, LR adaption, additive should be P1124 if the ECU is bad.
    If it continues to be P1125 then you have an actual problem, all the common things. So a gasket leak allowing the mixture to be lean that's seen by the primary O2 sensors and the ECU is trying to compensate but it's too much beyond acceptable so you get the CEL.
  10. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Sorry I meant P1123 should be the opposing side code for P1125. Sorry for confusion, I need a coffee ☕ haha
