ECU | FerrariChat
ECU
Discussion in '348/355' started by cubbyman60, Jan 30, 2008.
  1. cubbyman60
    cubbyman60 Formula Junior
    Apr 24, 2004
    361
    LA
    Hey,
    A friend's ecu is frozen and always displays the check engine light. Ferrari offered him a new one for $3000, but they also suggested he could buy a used one. Does anyone know where he could find a used ecu? Thank you.
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Are you talking about the Motronic ECU? 348? 355? 2.5? 2.7? Does he know how to erase the stored codes? He has switched ECU's from left to right to confirm the ECU has a problem?
  3. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,974
    MD and NE
    Robbie
    The main computer ecu behind the passenger seat?
  4. cubbyman60
    Apr 24, 2004
    361
    LA
    Sorry I was so vague. It's a 96 355. The ECU was switched with another car and confirmed to have the same problem. The signal could not be reset.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Bosch rebuilds their ECUs for as little as $300 in some cases. A '96 355 should have a Bosch Motronic 5.2 ECU.
    ...too bad it wasn't a '95 355 with Motronic 2.7. I could probably have fixed that for you overnight for about $12.
  6. f355spider
    f355spider F1 World Champ
    18,054
    Can you confirm this for a 5.2 Motronic specifically for a Ferrari? I have not heard of Bosch offering factory rebuilt Motronic units, though there seems to be a burgoning aftermarket service.
    You need to be careful with your claims, as you can raise someone to unrealistic expectations.
  7. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    You sound as though you paid too much for an ECU!
    http://www.boschautoparts.co.uk/pcPetr3.asp?c=2&d=1
    http://www.ferrarichat.com/forum/showthread.php?p=135298259#post135298259
    http://www.bba-reman.com/content.aspx?content=electronic_fuel_injection_engine_management_units
    http://www.autocomputerexchange.com/?gclid=CNjI0-TWoJECFQVxHgodblxGuw
    http://www.ecudirect.com/index.asp
    http://www.ecmtogo.com/?gclid=CJ-ZgYPXoJECFQEaHgodi2ZvvA
    http://ecu-testing.com/ecu_testing.html
  8. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    I am always hesitant to respond to questions like this until fixes have been completely tested. In this case I can say two out of three repairs have proven completely trouble free.
    David Thursby of Ricambi has accomplished what I consider the impossible on both of the two and I suspect equal results on the third that is yet to be tested. I wont bore anyone with the ugly details of these two projects but I will go out on a limb and say I would have given David a 1 in 500 chance of sucess at best.
    I am sure that each case is unique and has its own set of problems but I will also say the repairs were no where near $3000 that David provided. Do yourself a favor and make David your first call. I have 2 customers that are delighted with the service he provided. The third untested unit is for my own project and I am strongly considering buying a plane ticket and getting him in the shop for setup on that project.
    Dave
  9. f355spider
    18,054
    This still does not confirm that Bosch offers the Ferrari ECU part numbers. The problem often times is that Ferrari is such a niche player it is not worth it for oem's like Bosch to offer remanufactured parts for them.
  10. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Um, OK, like...dude...if you're gonna spend so much time carpin' on someone else offering links to the actual sites (multiple!) that do the ECU repairs...then go do your own research and share what you've found out proactively rather than just spreading negative vibes.
    B!tc#in' is cheap. Fixin' is better.
  11. f355spider
    18,054
    I am only pointing out that you send post information that is a dead end often times, because you have not fully checked yourself...
  12. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    No, you have no idea if I've checked something out or not. You're just making random guesses, and doing so in the most negative light possible.
    That's called being part of the problem instead of being part of the solution.
    If you want something checked out better than you've seen done for you, then go do the work yourself.
    At that point you can add something positive, rather than trying to drag someone else down.
  13. f355spider
    18,054
    So Bosch offers rebuilt ECU's for which Ferrari models?
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    You don't seem to be doing your own homework. Shame...
  15. bowbells
    bowbells Formula Junior
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    Uh, like, dude
    Nothing in any of those links specifically list an exchange or rebuild unit for any late model that I read. But, I don't spend my life posting catalogue links, unless of course they really are of real use.
    B.
  16. bowbells
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    Answer the man's legitimate question about your post, don"t be so offensive/defensive.
    B.
  17. jetfixr
    jetfixr Formula 3
    Jun 14, 2007
    1,016
    northeast
    Gone
    OK,
    This sounds like "Bill and Ted's excellent adventure" not Fchat.....
    I think Helms gave the answer........Enough said.......
  18. cubbyman60
    Apr 24, 2004
    361
    LA
    David at Ricambi? I should start there?
  19. f355spider
    18,054
    Hey, if that is the suggestion of master Ferrari tech Dave Helms, you best take his advice! ;)
    Sounds like David may have a way to fix them, and since he has some experience specifically with the Ferrari application, that is a plus.
  20. bowbells
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    +1 Listen to the expert.
    B.
