ECU's | FerrariChat
ECU's
Discussion in 'Technical Q&A' started by racer17, Oct 2, 2006.
  1. racer17
    racer17 Karting
    Jun 19, 2006
    139
    Calgary
    Brian
    Guys....my '97 355 always performs better after I've turned the battery switch off for a couple of hours, turn back on, fire the car up, let it relearn for the 10mins specified in the owners manual, and then go for a drive. Car is snappy, responsive and a blast to drive. However, after several hundred km;s of driving, the car starts to feel sluggish, especially at 2500-4000RPM. If I reset the ECU's as stated above the car is a rocket ship again. What could be causing the ECU's to perform/learn this way? Any help is appreciated as I am at a serious loss. I've done this twice now with the same effect. Maybe 3rd time is the charm here?
  2. racer17
    racer17 Karting
    Jun 19, 2006
    139
    Calgary
    Brian
    When the battery is disconnected on the 355, what else is reset other than the ECU? Are there any other items that go through a "full cycle" after the battery reconnected and the engine is fired up? I'm wondering if the injector(s) may be stuck open slightly causing an increasingly rich mixture......?
  3. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Clean your Mass Flow Sensor along with the eletrical connections. Maybe also need o2 sensors?
  4. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    You only need to leave the power off for a minute. The ECU's do not have any sort of battery back up or static ram, etc. Just like when you turn your desktop computer off.. when there is no power, it's done. Turning the power off to the car for even 10 seconds probably clears the ECU's, although I generally do it for 60 seconds, just in case any caps have power in them. No need to leave it for hours on end :)
    Ray
  5. racer17
    racer17 Karting
    Jun 19, 2006
    139
    Calgary
    Brian
    Got it...thanks!
  6. racer17
    racer17 Karting
    Jun 19, 2006
    139
    Calgary
    Brian
    Car is going in this weekend. Thanks for the note. I'll be sure to have these checked.
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yes this is true for resetting the ecu memory however, when the car is restarted it needs to relearn the warm up parameters of the engine. If the engine is still warm the ecus will not properly see all the temperatures. One of the things the ecu's monitor are the coolant temperatures. The ecu's uses the temp to determine weather or not to open the secondary air injection valves, among other things related to emitions. So when you reset the ecu's you do need to let the engine get cold before you let it go through the warm up/relearn process. Failure to do this can cause rough running of the engine.
  8. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I'll second that motion.
  9. EfiOz
    EfiOz Formula Junior
    Jul 26, 2005
    850
    Lago di Legana
    Lucivius Maximus
    I'll third it, especially for the O2 sensors.
  10. f355spider
    f355spider F1 World Champ
    18,055
    Interesting, if you read the 355 manual, it gets a bit confusing on this point.....it seems to imply that the engine needs to be at operating temp BEFORE you click it off and do the relearn process...I don't have the manual in front of me, but that was how I interpeted it.
  11. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    That's a very good point and I believe it may actually explain a recent [strange] problem I had on my car. When I was doing some work recently, I cut power to the car for a bit, then turned it back on. I believe the car may have still been warm, although normally when I cut the power it's been sitting over night, so I never really gave much thought to what you mentioned above (again, a very good point indeed).
    Anyway, the other week my car had a strange problem where the exhaust note was changing out of the blue. I wasn't able to isolate the problem for sure, but what I suspected was that the secondary air injection valve was opening at the wrong time for some reason. After reading your comments above, I'm wondering if perhaps I cut the power while the car was still warm and threw off the ECU with regard to when to open those valves. If that was the case, it's possible the valve could have ended up open at the wrong time or stuck or something.
    Anyway, good point on taking into consideration the temp.
    Ray
  12. f355spider
    18,055
    Whenever the battery is disconnected, or whenever power is disconnected from the ECUs, the ECUs lose all their self-learned operating parameters. The ECUs must re-learn these parameters before the car be used again.
    To re-acquire these parameters, leave the engine run for about 10 minutes under the following conditions:
    1) Car stationary, engine idling.
    2) Engine at normal operating temperature.
    3) Al electrical power users (lights, windshield wipers, etc.) switched off.
    4) Climate control switched off.
    This simple expedient enables the engine ECU to re-acquire the necessary parameters, thus preventing engine problems like stalling when idling, and flooding in nose-to-tail queues, etc..
  13. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yes this is true, but the engine runs different when it is stone cold. The secondarys are opened up until the coolant temp comes up. If I'm not mistaken, when the engine is cold the ecu's also control the fuel enrichment. This should be especially true of the OBD2 cars with the pre-cat and post-cat O2 sensors. It is all related to the emissions. They want the cats to get up to proper opperating temperature quickly. But then once up to temp, they don't want the cats to get too hot.
    So like I was saying, if the car is already at the proper opperating temperature the ecu's can't see the changes in the temperatures from cold to hot. Hence the term "warm up". You can't get an engine that is already warm.....warm. The engine needs to be cold in order to be warmed up. Plus you have the cold start valves that alter the way the engine runs. If the cold start valves are warm, well, then they have no need to adjust he way the engine is running. So the ecu's will miss all of the stuff that goes on when the engine is being WARMED from cold.
    SO if you let the car learn the parameters when it is warm, it will get all the warm parameters, but miss all the cold stuff.
    The car should be cold.
    Capiche. ;)
  14. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,974
    MD and NE
    Robbie
    very informative guys!!!!!! lesson learned if I have this problem
  15. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    That's an understatement. LOL!
    The stupid manuals are always confusing. They are soooooooo poorly written, it is really sad. That and they are missing loads of stuff.
  16. racer17
    racer17 Karting
    Jun 19, 2006
    139
    Calgary
    Brian
    Hooked car up to the scanner, and came back with a bad O2 sensor. Gonna have all 4 changed out.
    Thanks for input fellas!
  17. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Glad to hear you got it figured out.
  18. rbf41000
    rbf41000 Formula Junior
    Nov 21, 2005
    698
    Delray Beach FL
    Russell
    When talking about an engine being "cold" to reset the ecu what temp is considered cold?
    Russell
