EFI for 328 | FerrariChat
EFI for 328
Discussion in 'Technical Q&A' started by smg2, Jun 10, 2008.
  1. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,463
    Dumpster Fire #31
    SMG
    #1 smg2, Jun 10, 2008
    I've been working an another project, this one is a 328 with many mods. more to be released later on the request of the owner. I just wanted to share with the group a new non-invasive EFI conversion. instead of the usual fuel log, this setup utilizes a single ported fuel distribution block and individual runners much like the original CIS. some may have concerns over frequency pulsations in the lines but none are present. the injectors are retained by a very neat aluminum cir-clip retained boss. of course there is more but I cant give away all the tricks. enjoy
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,810
    The twilight zone
    Nice.
    Be very careful about denonation when you start tuning. The rumor is (and I can confirm it due to an injector failure) that the fire rings on QV/328 type head gaskets fail under even mild detonation.
  3. JEC_31
    JEC_31 Karting
    Mar 20, 2008
    86
    Grand Rapids, Mich.
    Josh
    I hereby humbly request more pics of the tricks.
  4. JCR
    JCR F1 World Champ
    11,029
    H-Town, Tejas
    Which ECU are you using? Is the "non-invasive" to fly below the CARB smog tech radar?
  5. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,463
    Dumpster Fire #31
    SMG
    given the lack of general knowledge of most smog stations it shouldn't be a visual problem, it'll pass the sniffer though easily since it's far superior to the CIS. the system i'm using here is the Haltech Ev11. I also have used the BIgstuff3 and Electromotive.
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,463
    Dumpster Fire #31
    SMG
    the goal was to keep it as stock looking as possible, I think it has succeeded.
  7. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    how do you know? . .. shouldn't be a problem with solid steel lines but you'll know once you're on the dyno . .. pulsations should only be a problem with steel braid/rubber hose.
    only way to really know is with a data logger and quality pressure transducer and the problems don't start happening until you're way up on the duty cycle making power . .. full sequential helps which you can do with the E11.
    looks excellent . . . post hp numbers when you get 'em.
    cheers,
    Sean
  8. blu328gts
    blu328gts Formula 3
    May 26, 2004
    1,152
    SF Bay Area, CA
    //Rick
    So I wonder: What's with the funny lookin' round thingie on the right side? Looks like some kinda fan, eh? That setup is looking really sweet and clean, Scott! (Looking for some kleenex to catch the drool...) :)
  9. Night life
    Night life F1 Veteran
    7,309
    The city that rhymes with fun in Canada
    Roberto
    How many HP are you hoping to gain?
    Nice work by the way..:cool:
  10. Grahame
    Grahame Formula Junior
    Nov 9, 2005
    520
    Grahame
    Nice clean look to the work you have done there. More info please! HP?
  11. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Having seen Scott's stuff, he always does a nice installation. My bet would be not so much HP (although a bit by removing the Kjet 'barn door') but a lot more responsive, flexible and long term reliable induction.
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,810
    The twilight zone
    Removing the CIS and keeping the stock manifold should gain about 25 hp....and then there is the blower........
  13. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Looks like the next step in evolution above the magic you did to my 308QV! We had a track day last weekend... what a BLAST these cars are with more power! :p
  14. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    #14 atlantaman, Jun 20, 2008
    What is see here looks like injector electric leads going to the standard locations of the CIS locations. One of the biggest issues here is that a standard EFI injector is shorted than a CIS injector. My intake manifold injector bungs had to be machined down a full 1/2" so that the injector tip could reach the air stream. If the injector tip is not in the air stream, the fuel collects on the passage sides and drips onto the valves--very bad scenario there....
