Electric Troubles. 348 tb. Very urgent | FerrariChat
Discussion in '348/355' started by marc556, Sep 18, 2018.
  1. marc556
    marc556 Formula Junior
    590
    Wiltz (Lux)
    Marc Foyen
    Dear all,
    I had electric troubles with the door connectors .
    I was not able to move the right door mirror or the right door windows from the left door.
    I checked the door connector that is fixed on the pilar.
    It is a circular connector with more than 20 pins.
    I found 2 wires broken, so I decied to replace all the pins.
    I did it today without too much problems except to remove the old pins.
    So I did it and now......
    All the functionalities are ok except.... The Left window !!
    Before my work, it was the only function that was ok !
    I can imagine that I made a misstake.....
    Do you know which wire on the circular connector is the ‘+’ used for the left window?
    Do you hace any idea ?
    I shall go in Germany with my car (Club trip) next friday morning..... So I have to find the solution very quickly
    Thank you so much
  2. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
  3. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    The black wire is for the left window
  4. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Hi guys,
    I probably found the solution...
    When I made the job, I cutted all the wires from the connector and went to an electrician to remove the pins from the plastic part.
    When back, I used a drawing from a friend but it seems there are 2 different ways to connect the left window switch.
    + on pin 15 And Ground on pin 13
    Or
    + on pin 9 and Ground on pin 13
    I made the first onbination but I’m 99% sure it must be the second one.
    I shall check tomorrow afternoon and keep you informed...
  5. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Qavion likes this.
  6. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
  7. Pit 348
    Pit 348 Rookie
    Dec 31, 2015
    11
    Erftstadt, Germany
    The "Méthodologie Restauration connecteurs de porte 348" from our french friends is absolutely great. But i also found some mistakes or there are probably different versions. Follwing Pins in my 348 are Different to the french scheme: 4 black, 9 white/red, 15 empty, 13 empty. You can also check teh opposite connector, but therefore you have to remove the wheel arch.
    But anyhow. If the right window works withe the switch on the drivers side, the left window should also move. please check if there is another problem... Maybe you like to visit me in germany ;-)
    Ga68_ likes this.
  8. Qavion
    Qavion F1 World Champ
    14,287
    Ian Riddell
    Yep, some cars seem to have this configuration.
    I added a note to my windows diagram showing this (earlier this year):
    F348 Window Wiring Diagram
    Pit 348 and Ga68_ like this.
  9. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
    #9 Ga68_, Sep 19, 2018
    Hello,
    Thank you Pit 348 for renting my lol tutorial.
    Having done only my left side (pilot), it is possible that my diagram, has errors despite my different controls.
    Or, there are indeed differences across the Rhine.
    I will try to add the case of you pinning on the tutorial
    Greetings
    Gaëtan (France, alsace)
    tutorial:
    http://ga68.free.fr/autre/FERRARI-348ts/Methodologie_Connecteurs_Porte_Ferrari_348-V211.pdf
    Qavion merci pour ton travail sur les schemas électrique
    Pit 348 likes this.
  10. fdekeu
    fdekeu Formula Junior
    631
    Belzium
    Frank
    Very good tutorial
    Merci
  11. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
    small precision, my 348 TS of the tutorial is from 1993.
    Possible that there is a difference with the 2.5
  12. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Dera all,
    The problem is solved... now everything works perfectely.
    I only had to change the wires 15 and 13 to 9 and 4.
    Pit 348 likes this.
  13. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    It seems youare living not so far from Luxemburg !
    We can organize a meeting, but not this weekend because my trip is organized by the Ferrari Club Luxembourg.
    Ga68_ likes this.
