electrical corrosion question | FerrariChat
Discussion in 'Boxers/TR/M' started by silvergts1998, Mar 26, 2013.
  1. silvergts1998
    silvergts1998 Formula 3
    Apr 10, 2005
    2,426
    ky
    Adam
    Hi, I was wondering what you can use for electrical connector corrosion? I have a connection I will clean off and everything is fine, but give it about 6 or 7 months and it seems like the corrosion comes back enough prevent a good electrical connection. I changed out the connector to a gold connector and also put die electric grease on it too. Still having this small minor issue. Any idea how to fix? I almost want to solder the connection.
  2. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    Which connector Adam (and where is it located); what is the (wrong) result then ?
  3. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    I have had good luck with a paste made by Thomas-Betts call maybe Kor-shield. The same bottle lasts about 20 Years. It has lots of copper and you use a "pin Head" amount. And ofcourse, there is dielectric grease whch works by sealing out the mosture. Sorry, I can't spell today. FWIW.
    Jeff Pintler
    89 348tb, 86tr, 99 360 3-pedal
  4. DavidSB
    DavidSB Karting
    Jan 11, 2008
    54
    Try a squirt of Boeshield B-7 periodically on the cleaned up connector. I use it on many parts including electrical connectors with good results. BTW, check out it’s development history and uses at Boeing.
  5. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    try some stuff called ''salt-x'',,weve used it on 100+ flood cars and it cleans the wiring/computers/aluminum parts great[use it straight-no dilution]
