electrical fault any ideas ? | FerrariChat
Discussion in '308/328' started by martin-uk, Mar 3, 2007.
  1. martin-uk
    martin-uk Karting
    Feb 24, 2007
    183
    uk
    martin
    hi when i switch on my side lights (mondial 1982) with the ignition off, the fuel gauge goes up and the windscreen wipers come on continuously, untill i switch the stalk on and off again,? any help would be great going to strip out the looms under the dash tomorow
  2. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Could be a bad ground or a faulty stalk.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Check all related connections (especially grounds).
  4. Javelin276
    Javelin276 Formula Junior
    Jan 16, 2005
    512
    Idaho
    Thor Zollinger
    The other electrical problems these cars have originate mainly in the main circuit board. It's delaminating on mine and causing all kinds of odd electrical problems.
  5. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    Mondi electrics are a law unto themselves, I'd find a really good auto electrician and have him go through the whole car, you would be amazed how everything suddenly seems to work OK. Grounds mainly seem to be the cause of aggro.
  6. Dino 208gt4
    Dino 208gt4 F1 World Champ
    Jun 24, 2003
    14,868
    European Union
    Roel
    100% grounds.
  7. martin-uk
    martin-uk Karting
    Feb 24, 2007
    183
    uk
    martin
    iam a uto electrician for volvo trucks, but even if i give the gauge a ground it still goes up,also the wipers only start about 4 secs after yuo turn the side lights on, but thanks anyway chaps, iam just going to have another go with my fluke, wish me luck i think i will need it
  8. martin-uk
    martin-uk Karting
    Feb 24, 2007
    183
    uk
    martin
    found a bad reair on the board,repaired that ,now i find the when switching the side lights on wipers dont go straight away (great ) until i then turned on the ignition, s--t the wipers startted again, can anyone point out the major earthing pionts please,i found the one under the wiper motor,in the pass foot well,on the upright by the battery,and a double lead on the fuse board in v plug i think,thanks
  9. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    have you got a wiring diagram? usually one up on e-bay.
  10. martin-uk
    martin-uk Karting
    Feb 24, 2007
    183
    uk
    martin
    yes i bought a workshop manual with suplement wiring, and have gone through the wiring diagrams ,and put the relay and fues allocations right
  11. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    b*gger!
    Now my car is acting up! All lights on to start, turns over, no firing. Apply liberal use of back end of screwdriver on relays and bingo! Need to have that replacement board ASAP. I wonder how long that will be?
