Electrical ground problem on 308 | FerrariChat
Discussion in '308/328' started by BlueMax, Jun 27, 2007.
  1. BlueMax
    BlueMax Formula Junior
    Aug 6, 2006
    309
    Norfolk, VA
    JR
    I've got a faulty right front signal and parking light that traced to a bad ground connection south of the pigtail that goes to the light. It looks like that harness feeds into another larger harness that goes back to the fuse box area.
    Does anyone know where the common point is for the ground connections? (especially before I start un-doing all the wires in the fuse-box!)
    As there are no other (noticeable) ground problems, I think it may just be this one wire that has a problem....
    Thoughts...?
  2. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Go to the owner's site, download the owners manual, and there is a schematic in there.
    Birdman
  3. 330gt
    330gt Formula 3
    Nov 12, 2004
    2,106
    Seattle, WA
    Kerry Chesbro
    On the left side, the grounds for the lights all come to a stud on the chassis. This is in the hole ahead of the spare tire tub and behind the radiator. I had a similar problem and found one of the grounds was loose. I assume that the right side would be similar.
    Andreas Engesvik likes this.
  4. BlueMax
    Aug 6, 2006
    309
    Norfolk, VA
    JR
    330gt-
    Thanks that helps me from a lot of unnecessary panel removal! I will check it when I get home tomorrow.
    I was trying not to get too side-tracked on this issue as I am 1/4 of the way through my belt change!
    -Max
