Electrical headache despite battery tender | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Marcus Lam, Jan 6, 2024.
  1. Marcus Lam
    Marcus Lam Karting
    Apr 15, 2018
    72
    Las Vegas
    Marcus Lam
    Hello all, wondering if any owners have shared my bad luck with Ferrari batteries.
    My 2017 488 Spider had a 1.5 year old battery. It was always kept on an official battery tender and is driven at least every two weeks. One day when out and about, electrical system went haywire, threw up every electrical malfunction warning possible, rendered not drivable and needed a tow. Dealer replaced battery and everythibg was back to normal.
    My 2023 812 GTS battery is about a year old. Kept on a battery tender at all times and driven weekly. The other day, same electrical malfunction. Luckily, I was able to drive it slowly home with is stuck in wet mode and still throwing up the electrical failure and return to dealer warnings. Plan to take it in Monday. I am 90% sure they will just replace the battery.
    My question (and gripe) is what is the point of my religiously keeping the battery on a tender if they crap out so soon and unreliably anyway?
  2. fatbillybob
    Aug 10, 2002
    28,989
    socal
    Battery tenders never work the way they are supposed to. Your option is to skip the tender and drive the car routinely or you be the tender. That means after new battery try one or 2 week on tender one week or 2 weeks off tender rinse and repeat. I do not know why this works but it does. Only start car with full battery which is anything greater than 12.4V.
  3. Marcus Lam
    Marcus Lam Karting
    Apr 15, 2018
    72
    Las Vegas
    Marcus Lam
    That is very helpful, thank you. I’ve always thought that the battery tender worked properly. At least I know now that they do not. I will take it on and off regularly as suggested
  4. fatbillybob
    Aug 10, 2002
    28,989
    socal
    Try it you will see. But every person in the know will tell I am wrong. Electrical theory, blah blah blah. I have owned the best tenders they don't work.
  5. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    I have good luck with battery tenders on my motorcycles. I have a gel cell battery in my 328, and the tender I bought specifically for this battery is not working properly, Im not sure if its the battery or what, I tried changing to a new gel cell tender and its still not working. I think maybe we both should switch to a pure Lithium battery for our Ferraris, they seem to work and hold a charge much better than a lead acid unit. All my Ducatis have lithium batteries and I never have to use a tender on them when they sit for a long while.
    Big G
  6. jimmyb
    jimmyb Formula 3
    Dec 26, 2005
    2,180
    Charlotte, N.C.
    James Bookout
    Assuming Ferrari didn’t undersize the battery for the load needed, the question is:
    What is running in the background that is killing a battery that fast?
  7. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,782
    Weston, MA
    Paul
    It seems that Ferrari gets the bottom of the line CTEK tender to supply with their cars. I would suggest you buy a CTEK 7002. It is much more powerful and versatile.
    020147, USMCS6 and rob5819 like this.
  8. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,559
    Austin TX
    It works to "cycle" the battery because batteries do not 'like' being fully charged at all times, it quickly wears them out, they need to be cycled:
    https://www.victronenergy.com/live/drafts:battery_life
    Overcharging:
    Overcharging frequently occurs when a battery is ‘stored’ whilst still connected to a battery charger. Unable to accept any more power the water in the electrolyte decomposes into Hydrogen and Oxygen. The level of the electrolyte will fall below the level of the plates causing irreparable damage to that part of the plate – and eventually the battery will dry out completely.
    Rather than leaving a battery on a continuous float charge during storage, it is better to leave it open-circuited, and recharge it every week or two in order to replace energy lost through self-discharge.
    @Marcus Lam
    Bullfighter likes this.
  9. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    940
    San Diego
    Rob Barry
    I agree with this suggestion, I made it eight years on my 458's original battery with a CTEK 7002, 1.5 years so far with my wife's PFM. Keep our other cars on 7002s as well, ten years on one of my BMWs that I drive once or twice a year.
    Battery tender: CTEK 7002 https://www.amazon.com/CTEK-56-353-12-Volt-Battery-Charger/dp/B000FRLO9Y/ref=sr_1_5?crid=12L1Q97YCLE22&keywords=ctek+7002&qid=1671214566&sprefix=ctek+7002%2Caps%2C194&sr=8-5&ufe=app_do%3Aamzn1.fos.f5122f16-c3e8-4386-bf32-63e904010ad0
    optional extension cable: https://www.amazon.com/CTEK-56-304-Comfort-Connect-Extension/dp/B00ADIHUVG/ref=pd_bxgy_img_sccl_1/135-0256143-7726263?pd_rd_w=TuMbP&content-id=amzn1.sym.7f0cf323-50c6-49e3-b3f9-63546bb79c92&pf_rd_p=7f0cf323-50c6-49e3-b3f9-63546bb79c92&pf_rd_r=5MHR20CHVPTK489XNW6H&pd_rd_wg=RKKXi&pd_rd_r=8cfbf7e0-0ea9-4d9e-8140-8d44e3e88a75&pd_rd_i=B00ADIHUVG&psc=1
    magnetic connector: https://www.cccharger.co.uk/product-page/ctek-ferrari-magnetic-connector
    STEP 1 DESULPHATION
    Detects sulphated batteries. Pulsing current and voltage, removes sulphate from the lead plates of the battery restoring the battery capacity.
    STEP 2 SOFT START
    Tests if the battery can accept charge. This step prevents that charging proceeds with a defect battery.
    STEP 3 BULK
    Charging with maximum current until approximately 80% battery capacity.
    STEP 4 ABSORPTION
    Charging with declining current to maximize up to 100% battery capacity.
    STEP 5 ANALYSE
    Tests if the battery can hold charge. Batteries that can not hold charge may need to be replaced.
    STEP 6 RECOND
    Choose the Recond program to add the Recond step to the charging process. During the Recond step voltage increases to create controlled gassing in the battery. Gasing mixes the battery acid and gives back energy to the battery.
    STEP 7 FLOAT
    Maintaining the battery voltage at maximum level by providing a constant voltage charge.
    STEP 8 PULSE
    Maintaining the battery at 95–100% capacity. The charger monitors the battery voltage and gives a pulse when necessary to keep the battery fully charged
    020147 and Nospinzone like this.
  10. Solid State
    Solid State F1 World Champ
    10,577
    Maximus Decimus Meridius
    Never had a problem with the OEM tender or other CTEK chargers. Start with a highly spec'd aftermarket battery.
  11. 020147
    020147 F1 Rookie
    4,602
    Midwest
    X3 for the 7002, it’s been flawless on my 2017 488. I would recommend not using the recondition function on the battery without isolating the battery to protect the cars electrical system.
  12. vrsurgeon
    vrsurgeon F1 World Champ
    16,527
    Charleston, SC
    Curt
    It’s not the battery.. it’s the alternator and the maintainer. My CTEK has worked flawlessly over the last 5 years.
