Electrical system failure car won't start | FerrariChat
Discussion in '458 Italia/488/F8' started by anteekdoc, Jan 2, 2023.
  1. anteekdoc
    anteekdoc Rookie
    Jul 28, 2012
    14
    Warren Pa
    Hi guys..
    458 Italia..2013
    9500 miles
    New Ultima red top battery 3 1/2 years ago
    Car not started for almost 3 months..kept on battery tender showing full charge.
    Today car made all the usual buzzes and noises when putting the key in.
    Dash lit up and looked normal.
    As soon as key is turned the lower part of the dash goes black and engine doesn't even try to start.
    In roughly 5 seconds all goes back to normal with warnings
    "power steering malfunction" and "electrical system not programmed"
    Reviewed posts on the site and there is no clear consensus..
    I am 5 hours away from dealer..
    Would it be reasonable as a first step to change the battery out?
    Thanks in advance
  2. Kent Adams
    Kent Adams F1 Rookie
    3,019
    Yes, but then go through the resetting of the ECU's process after new battery.
    Rexcat458 likes this.
  3. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,044
    Todd
    Yes
  4. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,538
    Austin TX
    Battery no longer has sufficient cold cranking amps (CCA) to start, it must be replaced.
    And, as a side note, batteries do NOT like to be fully charged at all times, it is best to let the battery go a week between being topped off (meaning taking it off tender for 7 days and then back on), allows the battery to breath, constantly being full causes wear and tear on the battery so it will have a shorter life than alternating it on/off tender.
  5. anteekdoc
    anteekdoc Rookie
    Jul 28, 2012
    14
    Warren Pa
    OK...thank you
    Will update once done
  6. todd cloud
    Jun 21, 2019
    1,044
    Todd
    hence the float mode on most tenders to achieve this result
    Eatpies99 likes this.
  7. Tarek307
    Tarek307 Formula 3
    1,346
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    Most likely your battery, but please do update this thread and let us know what the solution was .
  8. Boiler Inspector
    Boiler Inspector Formula Junior
    Oct 14, 2017
    347
    Texas
    Brian
  9. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,248
    Mel
    #9 Melvok, Jan 3, 2023
    Are you a DIY man? I hope so, it will save you a lot of trouble and money ...
    If you let the dealer do this for you, it may cost you up to $ 750 or even higher.
    So if DIY, go to the nextdoor carshop and buy a Bosch 75 Amps battery.
    Take out the old one and install the new one. (I took the nice sticker off the oem red battery with hot airblower and stuck it on the new battery)
    Read all about that in my DIY 458 thread: https://www.ferrarichat.com/forum/threads/diy-maintenance-458-thread.595191/page-6
    Buy also a simple modern charger, they now also feature tricling. But a trickler is absolutely not a charger ...
    Let us know ...
    DefunctNeurons likes this.
  10. anteekdoc
    anteekdoc Rookie
    Jul 28, 2012
    14
    Warren Pa
    OK...time and weather finally cooperated for me to put in the new battery.
    Ultima yellow top..pretty easy job like Melvok described.
    Went through the resetting process and the car started right up.
    I think I will let the battery "breathe" now as described above.
    Thanks all for your help...
    mikey64, DefunctNeurons and Melvok like this.
  11. Melvok
    Jul 25, 2008
    14,248
    Mel
    Any photo's made ?
  12. anteekdoc
    anteekdoc Rookie
    Jul 28, 2012
    14
    Warren Pa
    No, sorry.
    The car was put away up against the wall of the garage on the passenger side so I couldn't open the passenger door.
    I had to lay over the console to do the job..pretty awkward
  13. AhmetUz
    AhmetUz Karting
    Aug 11, 2022
    151
    This is normal, if I am not mistaken there are 26 ecus for different systems in 458, they naturally need electricity. It is possible that you will get warning lights especially when low voltage is lost during the first start. As you did, especially in a car that has not been used for 3 months and gives such warnings, changing the battery will usually solve the problem.
    Have a nice day
