Electrochromic Mirror Retrofit | FerrariChat
Discussion in '612/599' started by dodad198, Dec 6, 2009.
  1. dodad198
    dodad198 Rookie
    May 24, 2009
    1
    First post here....
    I came into possession of an '08 599. It has the manual day/night mirror and I was wondering if anyone here has had the electrochromic mirror added to their car and knew what it takes to do it. I have the electrochromic mirror now and I can tell that the mating parts are all the same but I would like to know if the wiring is already in the headliner for the mirror or if I need to come up with some wiring changes.
    Has anyone here done this and know what is necessary?
    BTW, I gave up an F430 Spyder and so far I couldn't be happier with my choice.
    Thanks,
    David
  2. k-diddy
    k-diddy Formula Junior
    Oct 29, 2004
    530
    #2 k-diddy, Dec 6, 2009
    You have to check for the harness/plug in the headliner. Some will have in and some will not. I have some factory 599 mirrors in stock that I have removed during radar/laser installs. Let me know if you need one.
  3. k-diddy
    Oct 29, 2004
    530
  4. caspian575
    caspian575 Karting
    Jun 12, 2007
    154
    Cheshire UK
    Roger Hayes
    K-diddy
    Which laser detector system did you fit that meant you removed the interior mirror? The Cheetah mirror clips over the original mirror I was wondering if there is a system that replaces the mirror that way you don't end up with a 2" thick interior mirror set up
    Caspian
