Electromotive DIS tach output voltage? | FerrariChat
Discussion in 'Technical Q&A' started by dan the man, May 17, 2005.
  1. dan the man
    dan the man Karting
    Nov 5, 2003
    146
    Alabama
    Daniel
    wanted:
    I need to know the Tach output voltage on the Electromotive DIS system.
    I have one for a V8 that I use on my 308 and I am building a divider to use it with my tach.
    Daniel
  2. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Don't know the voltage, but when I did mine I used an adapter that can be bought directly from MSD. Without the adapter the tach would read twice the actual RPM. It was kind of cool to see it rev so quickly though. If you need the p/n let me know and I'll see if I can dig it up.
    Henry
  3. dan the man
    dan the man Karting
    Nov 5, 2003
    146
    Alabama
    Daniel
    I would really like a P/N for that if you can find one.
    thanks
    Daniel
  4. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Dan
    Tach output is a 12v square wave. Older tachs use voltage. There is an amplifier. If you check the Electromotive site, you can download hte manual or call Nick (sponsor), he sells the tach corrector.
    Philip
  5. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    I got an MSD amplifyer from summit racing--all is fine on my TEC3 now
  6. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    I'm trying to fix this problem also . . . P/N?
    Thanks,
    Sean
  7. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Dakotadigital.com has what I need! Found it mentioned in another thread after some searching.
    Sean
  8. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Sean,
    So you are good to go?
  9. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Some chatters had problems with this unit . . . I couldn't find an MSD product that seemed correct so I was going to give it a try . . . be nice to have another alternative if I have problems.
    Thanks,
    Sean
  10. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Sorry, I just went through my old receipts and all it says is "tach adapter". I know it is a MSD unit.
  11. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Thanks for checking . . . I've got a direct number for a decent tech at MSD so he should know what it is.
    Sean
  12. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    The tach adapter I have fitted to the HPV-1 on my 1978 GTS is MSD PN 8920 (at least that's what it says on the cover). This adapter is really an amplifier that conditions the DIS tach output for the car's tach. Works great.
    Bill
  13. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Bill,
    Was your tach reading double rpm from the DIS output before you put the adapter on?
    Thanks,
    Sean
  14. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    Sean,
    No, my tach was not reading at all when I initially installed the system.
    It is my understanding the MSD tach adapter only changes amplitude of the tack signal from the DIS so that the tack can read and understand the resulting signal.
    The double reading of rpm is a different issue. It means there are too many pulses reaching your tach. Electromotive makes an internal change to their DIS during manufacturing for the twin distributor Ferrari 308 series, effectively halving the number of pulses sent out on the tach circuit. As I recall, the tach takes it signal from only one coil in the OEM installation. I ordered my system directly from Electromotive some years ago and told them it was for a US spec 308. You may want to contact them directly to see if they can rework your system to give the appropriate pulse count. I suspect the system you are using was meant for a standard V8 where only one distributor was originally used.
    Alternatively, maybe someone can provide a divide by two circuit that can be wired in?
    I hope this helps.
    Bill
  15. Nick
    Nick Formula Junior
    Sponsor Professional Ferrari Technician
    Oct 31, 2003
    506
    Nick Scianna
    If you have an 8 cylinder HPV-1 or HPX-1 that was not purchased for a Ferrari application, it will not send out the correct tach pulse, the Ferrari tach is a 4-cylinder tach, thus you need a 4-cylinder tach output on your direct coil ignition. The kits that we sold for the Ferrari application were all modified for a 4-cylinder output. You can also send your unit to Electromotive & they can modify it for a 4-cylinder tach output.
    If you are having a problem with the signal coming out of a TEC3 or HPX or HPV-1, you can use a MSD 8920 TAC amp. It will work with your OEM tach.
  16. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Yep, that's what I did. I sent the unit back to Electromotive and they modified it. It cost abour $35, but that was over 10 years ago.
  17. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Thanks all . . . that clarifies it.
    I'm using a Haltech ECU so I'll give the Dakota digital tach box a try. Supposedly it conditions the signal from any engine for a 4 cylinder tach.
    Sean
