Electromotive ignition problem | FerrariChat
Discussion in '308/328' started by FasterIsBetter, Apr 27, 2008.
  1. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I had the 308 out today for an FCA rally and luncheon. Had a great time, drove the car around 150 miles, and it ran perfectly. Absolutely great day, until I was about 2 to 3 miles from home. I turned a corner, hit a bump in the road, and it was like the ignition switched off. Pulled to the side of the road and tried to diagnose it. Fuel pump was working. No fuses were blown. Timing wheel and crank sensor were in place. No evidence of damage to any of the wiring. Engine cranked with the starter, but refused to start.
    So I had the car flatbedded home. I checked the Electromotive unit with the help of a friend. The first time we tried it, the status light turned green when I put the ignition on, and then when I cranked it over, the status light blinked red once, and then nothing. Turned off the ignition, waited a moment, turned ignition on, status light went green. Then cranked it over and it flashed red twice, and then nothing. Turned ignition off, waited a moment, turned ignition on, and nothing at all happened with the status light, it stayed dark. Turned it on and off several more times, still nothing at all. And the car won't start, no spark.
    So, any ideas what could be wrong??
  2. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    Maybe the ignition unit went bad. Does the manual say anything about the red light? It's possible the blinking red light could be a fault code. If none of that works, try disconnecting the bat cable for 10-15min and try it again.
    Jim
  3. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Which Electromotive unit is it? Did you verify the timing wheel to crank sensor gap has not changed? Verified that the timing wheel has not shifted location?
  4. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    It's the XDi unit, I got it from Nick's Forza two years ago. Yes, one of the first things I checked was the timing wheel and crank sensor. They appeared to be fine, neither had shifted, moved, touched, etc. Both locked in place, as they should be.
  5. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    try to verify that you are continuously getting power at the XDI unit !
    you can check this easily with a test lamp:
    the thick yellow wire coming all the way from the battery/ ignition switch feeds your xdi unit
    (this wire originally powered your stock coils)
    take the black plug out of the xdi unit and measure power at pin 6 with ignition key "on"
    (be careful while removing the plug, see manual page 20 for pin location)
    also check the 2amp fuse / connection before the yellow wire enters the plug/unit
    very important: the black w/white stripe wire coming from pin 7 must be grounded !
    if there is power at the plug (test lamp on)...and no green light at the unit after you put the plug back in,
    you know there is a problem inside the xdi unit ;)
    if this is the case, call Nick from nicksforza or Nik from electromotive...
    both will be of great help !
    been there, done that ;)
    best regards from Germany
    Michael
  6. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Thanks Michael. I spoke with tech support at Electromotive a short time ago. They basically told me to do the same testing that you described, and if the status light is not coming on and functioning properly after verifying power supply and ground and all other connections, to send the unit back to them for testing.
    It's just very strange that this would have happened at this point. I could understand if it happened at the time of installation. But the car has run perfectly for over a year, including all day yesterday, and then POOF, 2 miles from home, she dies. Makes no sense.
    I'll let you know what my testing shows.
    Steve
  7. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    All electronic components fail at some point..... if that is indeed what happened. When it happens it never seems like the right time. It always seems odd. At what time would it make sense to fail? Just like "strange electrical problem" that people post about. It's only strange until you find the cause of the problem.
    I really hope that it's not the XDI because it certainly should last longer than that but like with everything else there are things that "die early" due to defects, enviromental conditions etc. etc.
    In what location did you have it mounted?
  8. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    The XDi unit, the relays, the fuses and the tach unit are all mounted in the rear trunk area. So they are not exposed to the weather, engine heat or any other adverse environmental issues. The wiring harness passes through a hole in the wall between the rear trunk space and the engine compartment, but is wrapped in plastic flex tubing to protect it. I'm going to check the power source and ground connections, and the crank sensor with my multi-meter before sending the unit back, just in case it's a wiring problem, not the XDi.
  9. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Sounds like a very good idea. If I recall, you installed it yourself so all of that stuff should be really easy for you to check.
  10. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Okay, I checked the voltage on the leads and found something unusual. So let's see what you guys think.
    With the ignition off, I measured 12.3 to 12.4 volts across the battery terminals. I also measured 12.3 at the two fuses in the hot leads to the coils that is connected to the terminal on the starter. I disconnected the XDi plug with the wiring harness and measured pin 6, the power lead that runs from the ignition switch, to ground and got 0, as it should be with the switch off.
    Now, I turned the ignition switch on to the run position. I got 12.3 across the battery terminals. Pin 6 to ground showed 9.1 volts (that would explain why the XDi was not working, it needs at least 10.5 volts to operate). Now here's the really odd part -- I measured the hot lead to the coils from the starter, and it measured 9.3 volts also.
    So what's going on? Could I have a short somewhere? But if so, wouldn't a fuse have blown if I had a dead short? Doesn't make a whole lot of sense. Any suggestions welcome.
  11. Steve Magnusson
    26,766
    Not a short -- you have a small unwanted resistance somewhere across which the voltage drops by I*R (i.e. a few~5 amps to run your ignition system flowing across a 0.5~1 ohm resistance results in a voltage drop of a couple~few volts -- so the 12V becomes 9V). You need to make the same voltage measurement at the starter connections (when things are "on") to see if the drop is between the battery and the starter or between the starter and your downstream connections.
    When you make the voltage measurement at the coils when things are "off", it seems OK because the current draw is zero -- i.e., the unwanted voltage drop is zero (even though the unwanted small resistance is still present) because I*R = 0 when I = 0 regardless of R.
  12. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I agree, you've got a high resistance connection somewhere. I would be looking for some connection that got jarred loose since you said the problem occured after hitting a bump.
    Make sure your ground connection(s) are tight and on bare metal (scrap away paint if you have to) and use a star washer on all the ground connections (the washers with the raised "teeth" that dig into the metal) if not already being used.
    You should also check the voltage at your rear lamps etc. If they are also showing 9.3 volts I would check connections at the battery, alternator, starter etc. before bothering with the wiring you did for the Electromotive install.
    Also, many people don't realize there is a quick disconnect on the positive battery cable similar or identical to the one for the battery ground cable near the spare tire. The + quick disconnect is under the car hidden in a little cable tray in the area of the fuel pump and shift shaft. I would locate this, disconnect it and make sure the spring tension on the contacts is not weak and that there is no corrosion or signs of overheating.
  13. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Any update?
  14. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Okay, problem solved!!
    It was NOT a problem with the Electromotive unit. The XDi is working perfectly. Not a problem with relays, battery, fuses, coil packs, etc. All of that stuff is working perfectly.
    So, the problem?? -- THE GROUND WIRE!! When I hit that bump, it must have caused the engine to shift enough that it partially pulled the ground wire out of its connector, enough so that it could not handle the load of all of the wiring to the XDi system that was running through it. It was not a total break, which would have been easy to diagnose. Instead, under load there was enough resistance that it was dropping the voltage in the XDi circuits down to between 8 and 9 volts, not enough for the XDi to fire the system. When we hooked up an alternate ground wire, the car fired right up.
    Now I just have to rewire the ground. I spoke to Nick at Forza Ferrari and he suggested doubling up the ground wires. I'm going to do that, one to the engine, one to the chassis to avoid future problems like this. Just glad it was an easy fix.
    While my friend Paul and I were trying to figure this out, we called another friend of ours who is great with this stuff. He said "Check the ground wires. It's almost always the ground wires." Well, he was exactly right. Good lesson that I'd actually learned a long time ago, but forgot -- 99% of all electrical problems are bad grounds. So tomorrow, I'm picking up some wire and new connectors and I'll be running new grounds for the system.
  15. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Glad to hear it wasn't a failed XDI.
  16. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Thanks Eulk. BTW, while we are checking things out, I noticed that the old grounding strap from the engine to the chassis was looking kind of fraid. Since I have the car up anyway, I'm going to change that too.
  17. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Can't hurt and don't forget to make sure any paint underneath is scrapped away. Might not have been done at the factory. Star washers would be good also if not already installed. And check out that hidden quick disconnect for the + battery cable while you're under there.
  18. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I've heard about the ellusive sucker but don't know where it is. Where exactly can I find it hiding?
    Thanks,
    Steve
  19. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    She's back up and running!! Hooray! Sweet sound of the Ferrari. I love it.
