Electromotive XDi-2 ignition system problem | Page 2 | FerrariChat
Discussion in '308/328' started by bill308, Jul 13, 2024.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    Everything David said....500mV above 0 is a every common trigger number. The shape of the signal is okish, it definitely shouldn't be a square wave, this is a typical signal google found me and its very close to what you'd see on the flywheel triggers on the 1980 and up cars:
    it goes + to - very fast so its a very accurate trigger signal.
    This is what it looks like when you mismatch the sensor to the tooth (from my car), the 0V flat is in the wrong place so it looks wired backwards and is completely unusable. The way these work is when it goes positive past some threshold around 500mV the ECU is set ready, then when 0V is seen it trigger. The faster the +/1 transition, the more accurate the trigger location so the googled image is great, the image below is not usable because spark could trigger anywhere on the flat which would be about +/-2 deg on this particular setup.
    I say your signal is okish because it its wired right the rising edge is steeper than the falling edge so more accurate but with VR the falling edge is the trigger and it looks like you're starting to see the flat that is in my image. Maybe look for the 2 tooth gap on the scope and make sure it goes + after the gap, that will tell you the sensor is wired right then we can talk about what's wrong with the trigger wheel or you might just have the leads reversed as the rising side looks fine.
    The problem though is likely your cranking rpm is just a little you low to get the sensor voltage high enough for the ECU to accept it. As David said adjust the sensor gap a bit tighter and it should work as it did.
    In general, a hall sensor makes a square wave and wants a square tooth wheel. A vr sensor make a V wave and wants a V tooth wheel....which I learned the hard way and had to switch from vr to hall to fix the problems with my setup. I just didn't think it through before I built it.
  2. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    It looks to me like I have two problems and a couple of ideas to mitigate them.
    1. The ECU wants a wants a higher amplitude trigger signal- Go to a smaller pickup gap say 0.020 inches.
    2. Noise spikes could screw up timing - Rerout pickup lead away from the alternator as much as possible.
    Do you think the 1/2 inch diameter sensor would give a taller amplitude?
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    yes and yes, also have a look to make sure the shield is grounded back at the ECU, just put a meter on it and check resistance to chassis ground.
    It might help, it might make it worse you would need to install it and scope it. My fear is that a larger OD would make the shape of the trace worse but it might make it better.....I just don't have enough experience to know. I think you want the core in the sensor at least as wide as the tooth on the wheel but not so big that if can ever have 2 teeth under it. A V shaped wheel tooth kind of guarantees that requirement is met, with square tooth wheels you need to be pretty careful when you use a vr sensor with it. VR sensors are very accurate and very reliable, but they are much more sensitive about setup than hall but are less accurate so you see both used and OEMs even switch back and forth depending on what issue they are fighting on what day. If there is any way you could temporarily mount the new sensor to see what it does before making a real mount that would probably be best....a clap or 3d print something maybe?
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    You know, a new battery or cleaning the connections will probably fit your issue. I'm guessing it was marginal but functional and as the battery has gotten older its just not quite spinning the engine fast enough to get the sensor voltage high enough to trigger the ECU. You should still reduce the air gap to make it more robust but its probably the battery that caused this to show.
    I have a gear reduction starter and looking now see right around 230 rpm cranking in my logs. 120 is pretty slow
  5. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Yesterday I closed the sensor gap to 0.020 inches. I then rerouted the pickup lead to provide about a 1.5 inch gap to the alternator housing. I also changed out the batteries but saw no improvement, so reinstalled the original one. I did find the battery terminal ground clamp connection untightened, so remedied this.
    The following photo shows the new pickup mounted and the increased distance between the alternator housing and sensor lead.
    The next photo shows the resulting wave form.
    The sighal is now about 1.5 V , Noise spikes remain about 0.2 V.
    I measured the pin 9 voltage at about 10.2 V when cranking. Worse than last time.
    My starter quit on me. The wire to the starter solenid shows voltage when the key is in the crank position.but the solenoid does not click.
    The plan is to remove the geared starter. Can anyone recommend a replacement geared starter that will spin my motor faster?
    I do have the original starter and will look at getting someone to go through it before I consider putting it back on,
    Do you think the starter motor could be the source of the noise?
    I pulled the number 4-cylinder plug to check for spark with the improved wave form. No spark and no acknowledge by the two XDi2's of seeing the trigger signal.
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    I don't see any issue with the signal now. That should be plenty of voltage and signal shape looks right. So why oh why is it not working?????????
    You pulled the ecu from another car.....can you check that trigger signal for comparison? Or plug the 308 unit into that car to confirm all it well?
    No help on the starter, I converted a chevy starter to fit my v12.
  7. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    I pulled the second XDi2 from my 26R build. It's not far enough along to run in the car, only on the dyno, so not in a position to test.
    I took my Bosch starter to a local specialist. He found a sloppy drive gear so that at least will have to be sorted. It did turn over well on the bench.
  8. DavidB_SD
    DavidB_SD Karting
    Sep 7, 2008
    65
    San Diego, CA
    David B
    I thought for sure that was it.
    Stepping back a little, going to when it originally stopped working… did it fail while running and never restart or did it run fine, you shut it off, and it never restarted the next time you went to drive it?
    mk e likes this.
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    Now I'm really wondering what that trigger light actually means...like maybe it's more a system active light and many things could cause it not to light? A bad or weak ground comes to mind
  10. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    David,
    The car never started after being turned off and sitting a bit if I recall correctly. I was synching the carbs with a multibank manometer system, shut it off, and it did not start the next time I tried it. To be fair, I turned the motor over with baggies over the Webers. Effectivly a full choke condition. Eventually discovered no spark. The engine seemed generally hard to start since being installed in the car. I thought it was somehow tied to the new fuel pump in some way. Maybe it needed a one way valve somewhere?
    Mark,
    From the XDi2 manual:
    7.0 Diagnostics Wiring mistakes cause a very high percentage of problems. The first step to diagnosing a problem is to check all the wiring. Also, remove the connector from the XDI-2 and make sure the pins are fully inserted. You may see a pin that is not inserted all the way to the edge of the connector. See Appendix A for more information regarding the 23-pin connector. Keep in mind that the engine will need the appropriate air/fuel mixture to operate correctly. Read your spark plugs to determine if the problem may be related to your fuel system instead of the ignition system. A simple timing light will let you verify if the XDI-2 is generating spark. The XDI-2 has a pair of status lights located next to the communication port. These lights must be visible while trying to diagnose a problem. The UPPER light will be known as the Check Engine Light. This light will be red with the ignition on (engine off). Otherwise this light will turn red when sensor failures are detected. The upper light is also used during firmware upgrade procedures. The following possible problems pertain only to the LOWER of the 2 LED’s : Problem: When I turn on the XDI-2 the lower status light is red and the car won’t start. Possible Cause: This will occur when the configuration (i.e. 4-cylinder) is not set in the software and the program file has not been downloaded to the unit. Refer to Wintec software users manual for engine settings configuration. Problem: When I crank the engine the lower status light stays solid green and the car will not start. Possible Cause: This problem is crank sensor related. The XDI-2 will flash red and green while the engine is starting. If the lower status light does not flash, the XDI-2 does not “see” the trigger wheel. The sensor could be bad. Measure the resistance between the signal wire and the ground wire of the sensor. The resistance should be approximately 620 ohms. The XDI-2 may intermittently see the sensor if the sensor wires are backwards. Refer to Section 4.3 for crank sensor wiring. A weak or non-existent crank signal will occur if you are using a 3/8” chisel point sensor with the incorrect sensor alignment. Refer to Section 5.3.2 for the appropriate alignment. Problem: The lower status light blinks during cranking but there is no spark. Possible Cause: In this situation, the coils are not getting power. Verify that the red with white stripe wire connected to pin D of the DFU connector is connected to +12V. Refer to Section 4.4 for power and ground connections. Problem: The lower status light does not turn on with the key. Possible Cause: The XDI-2 is not getting +12V and ground. Remove the connector on the XDI-2 and measure the voltage at pin 6 (+12V) relative to the main ground wire. If there is 12V at pin 6 and the unit does not turn XDI-2 Manual Version 1.3 Page 33  2015 Electromotive, Inc. on, there may be a problem with the unit. Contact your dealer. If there is not 12V on pin 6, refer to Section 4.4 for proper power wiring
    The pin-out for the 23-pin AMP connector. I need to map what pins are populated.
    Pin Description Wire Color
    1 Coil A White
    2 GPO 1 White/Black stripe
    3 Magnetic Sensor Shield Bare
    4 GPO 2 White/Red
    5 GP I/O 3 White/Green
    6 +12V Switched Ignition Yellow
    7 Knock Black
    8 DFU 2 Coil A White
    9 DFU 1 Coil B Red
    10 Magnetic Sensor Ground Black
    11 Magnetic Sensor Signal Red
    12 GP I/O 4 White/Blue
    13 External Retard Control Orange
    14 Sensor Ground Black/White
    15 DFU 2 Coil B Red
    16 Shield for DFU 1 Bare
    17 DFU 1 Coil C Black
    18 Tachometer Brown
    19 +5V Output Gray/Red stripe
    20 MAP Signal Dark Green
    21 Aux. Rev. Limiter Pink
    22 DFU 2 Coil C Black
    23 DFU 2 Shield Bare
  11. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Today I found someone to rebuild my OE Bosch starter. He's says about $100 compete but parts are about 4-5 days out. The drive gear is sloppy on its shaft. This is what we last used on the chassis dyno. I brought the whole ignition system to the dyno room and broke the engine in with it and did about 20 power pulls. Then I took my time and installed it on the car. All the movement broke the mag sensor shield wire at the end of the sensor.
    Tomorrow I need to get the car higher in the rear and pull the port side rear wheel and liner. Then, pull geared starter bolts and starter. I wonder if anything came loose?
    I need to take a hard look at the grounds. I run I think 8 AWG wire in shrink tubing for dedicated +12 V and ground wires direct to one relay that feeds a distribution block. This block supplies separate circuits for ecu (2 A), DFU1(10A), DFU2(10A), spare. The thing is I think I also tie in to chassis ground by hard bolting the DFU's and ground leads.
    Thank you for the help.
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    What are the 2 LED lights doing
    Key off?
    key on?
    Cranking?
    I'm thinking about the noise on the trigger line that really shouldn't be there. Did I read you extended the sensor wires? If so, how did you handle the shield?
    It looks like pin3 is for the shield at the ecu, is it connected? What is going on with the shield out at the sensor?
  13. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Key off: No illumination of either LED
    Key on: Top LED ( basically a check engine light) solid red; Bottom LED solid green.
    Cranking: Top LED solid red; Bottom LED solid green.
    Yes, I had to fabricate about a 2.5-ft extention to reach the ECU in the trunk.
    Yes, I had to repin the extension side of the ECU connector as the shield (22 AWG) wire broke. Three new pins.
    I mounted a new connector on the other end. It was provided by the sensor supplier for this purpose.
    We wrapped the connector gap with aluminum foil with an overlap of at least a couple of inches on the either side of the connectors, then grounded the foil to a cam cover bolt with allegator clips and 16 AWG wire. I did'n see any benefit on the scope, so discarded the foil shield.
    The ECU side of the mag sensor shield is presumably grounded inside the ECU. I show continuity to the ECU housing. The sensor end floats. No continuity to ground. I believe this is best practice where only one end is grounded.
    What do you think about a second layer sensor ground shield covering the wire near the alternator. Maybe ground this outer layer to the sensor body at engine ground?
    I'm wondering if the my starting difficulty can be attributed to a defective starter motor? Could the noise also be attributed to the starter motor? I guess I'll have to wait about a week to find out.
    Got car up in the air, ass high and took the driver side wheel and liner out. Now need get the failed geared starter out.
  14. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    1 Coil A White
    4 GPO 2 White/Red
    7 Knock Black
    9 DFU 1 Coil B Red
    15 DFU 2 Coil B Red
    18 Tachometer Brown
    Pins in red text are not populated
    Pins in green text are not used and likely should be removed.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    I guess you're holding on a starter but when that is sorted, any way to temporarily move the ecu or sensor wire so you don't need the extension?
    Also maybe look at the ecu power and ground with the scope and see it they look clean?
  16. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    The new sensor appears nicely made. They use a shielded twisted pair, grounded on the plug end. I do have a 1/2 sensor with long lead but I'd have to drill or or change out the sensor pinch clamp. Do they make twisted pair with double shield conductor.
    What about a simple low pass filter on the mag sensor line. Back in the day we shorted the input terminals of an A/D channel with a 1-2k resister to quite each thermocouple signal.
    I counted about 15-16 noise spikes across 1 tooth cycle.
    The electric fuel pump is disabled (pulled fuse)
    I determined my cranking speed by:
    (60 teeth/rev) X (2 rev/S) =120 teeth/S and generates a 120 Hz (DMM measured) saw tooth wave form.
    2 rev/S =120 rpm
    After I pull the starter I'll start looking at grounding and power distribution. I use only one relay for main power and distribute from there. A quick check appears to show a single point ground.
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
  18. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    I don't believe we used an alternator, but not sure.
    The wire you buy looks like what I should use. Twisted pair, shielded, high temp insulation. I suspect it's what is used on my new sensor.
    I believe I may have found the cause of my difficulty. In disconnecting the ground lead from the battery, I noticed one of the cable clamp bolts, securing the main ignition ground, was loose and the lug could be easily rotated.
    In the above photo the large (8 AWG?) gauge black wire's lug was not tightly clamped.
    The small red wire on the + terminal clamp was also loose. Not sure what this one does.
    Luckily, I haven't taken much apart yet. Won't know for sure till I get the starters swapped out. I guess I should retry the existing starter before I take it out.
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    I usual order from prowireusa, and I get the shield terminators i posted in your other thread from them too. You slip it on and heat with a hot air gun an it seals and solder's itself on, really nice
    https://www.prowireusa.com/
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    I was thinking you could disconnect the alternator wires just like it almost certainly was on the dyno and see if that fixes your issue, then you know for sure it's a noise issue and can focus on that.
    The loose ground you found sounds like a promising repair too.
  21. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Mark,
    What other thread for the shield terminators?
    I really don't like the extention Weather Tech connectors. These connectors are too bulky for the light (20-22 AWG) wires. What if I just use the pin pairs as 3-connectors then shield and seal locally? I did get a supply of Weather Tech pins from Custom Connectors.
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
  23. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    I should get some of those terminators. Do I need one with and one without terminator to bridge a but connection?
    I did get my geared starter out.
  24. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    I meant to write, I should get some of those terminators. Do I need one terminator with a lead wire and one terminator without a lead wire to bridge a butt connection?
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    I don't bother with them on the non-grounded end. I just trim the shield braid back clean and heat shrink, ...I like the stuff will glue inside to seal it all. They do make heat temp FEP heat shrink which goes nice with the high temp tefzel wires (again, I think prowireusa has it), but I haven't been using it, just the lower temp polyolefin stuff.
    The little slder ends you heat until the red band turns silver, that means the solder melted. Also best to hold of tape the ground lead, it can fall out until the joint cools.
