Electromotive XDi-2 ignition system problem | Page 3 | FerrariChat
Discussion in '308/328' started by bill308, Jul 13, 2024.
  1. ang308
    ang308 Formula Junior
    454
    Stamford, CT
    Billy
    I had the same issue with my electromotive box. I have the tecGT which incorporates the XDI box. Car would not start at times I was getting voltage to computer. It ended up being a bad connection at the fuse box. It was intermittent. Sometimes would catch sometimes it wouldn’t. Please check that. I have not had a problem since I cut wire and put new spade connectors on there. Starts every single time now. Drove me insane
  2. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    I got my OE starter serviced. The drive was very sloppy apparently missing a bushing. We changed out the drive assembly and solenoid and tested it on the bench. Yesterday I got the starters swapped.
    My friend Tim came down to help.
    We now have a large clean signal.
    It looks like we have a 3.5 V signal and no apparent noise. There are a lot more waves on the screen so starter speed is much higher.
    The lower LED on the XDi2 now alternately blinks red and green when cranking the engine over indicating the ECU now sees the trigger signal. We have ignition.
    I let the fuel pump run for 20 seconds then easily started the car.
    What I still want to do is measure the ECU voltage supply (yellow wire). Last time it measured 10.2 V while cranking.
    In the end, I think the loose ignition ground clamp was the root cause of not starting. The geared starter motor I took out just didn't work right. I think the solenoid died, but it never really spun the engine very fast, rpm wise.
    mk e likes this.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    Congrats!
    Now it would be good it some one else with an electromotive would chime in because the signal you have looks inverted..the straight line in normally on the right and any snoopy line on the left and what you have normally means the the +/- pins sensor pins have gotten swapted. It will still work inverted but timing is less stable. Maybe try to get the missing teeth on the scope image and make sure it goes up not down after the gap.
  4. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
  5. Steve Magnusson
    26,932
    That might be a "missing teeth" feature that the system uses for a "zero" reference (and, since your trace is only about 6 teeth long, sometimes it is in your sample, but most times not).
  6. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    I got really lucky on that shot. I attenuated the voltage sensitivity for the last shot, which I presented before the last one.
    I think what this is telling us is that the trailing edge is the more verticle slope. Older data is to the right on the scope time axis. Older data means this happend before data to the left. I believe it is the ascending tooth edge that has the more distortion. The trailing edge is more verticle, therefore a better on/off trigger. Did I get this right?
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    The trace should be going left to right. I've never seen it otherwise.....but I guess anything is possible.
    That said, the missing tooth has exactly the leading edge it should with a long swoop in it negative from the last tooth going positive. The small swoop in the trailing edge means the trigger wheel teethvare just a little too wide for the sensor you're using and the steep clean neg to positive means they are a little too close together for the sensor. But it's not horrible and you've confirmed it's wired right so you're read to go drive :)
  8. DavidB_SD
    DavidB_SD Karting
    Sep 7, 2008
    65
    San Diego, CA
    David B
    Awesome news.
    Mark is correct, older data is on the left of the display usually. I’ve used some tektronix scopes from around that era and they were normal (older data left, newer data right).
  9. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    The XDi2 fires on the back side of the tooth. Is this side denoted by the more verticle edge?
    Do I have the sensor polarity correct or do I need to swap +/- leads?
    My current gap is 0.020 inches. Should I reset it to say 0.040-0.050 inches?
    Capturing the scope photos required crianking on the starter. This requires 2-people and limits how much time I can fiddle with the scope. If I tap into the sensor +/- lead when running, will I see the same wave form?
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    No, the back is sadly the swoop side
    No, i think they are right, the missing tooth for sure goe +then minus just as it should so im pretty sure its wired right.
    its working so maybe don't mess with it ;)
    Running the wave form will be basically the same, it will be higher voltage so you may need to change the voltage scale and it will be faster so you will need to change the time scale, then it will look the same as cranking.[/QUOTE]
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    Here's one I made that looks a bit like yours but worse.
    It is for sure wired correctly but the right side falling edge is much worse than what you have.....this one goes flat so there is really no way to know where exactly the ecu is going to trigger. Your falling edge looks like this rising edge, there is a swoop but the line crosses the 0V axis at only 1 place and has a decent slope at the crossing point. This was me not thinking the design through before building it for the millionth time. I just layed and cut a 50% high/50%low tooth pattern and used the QV's OEM bosch vr ignition sensor the was designed to work with a 6mm OD pin as the trigger, not an 8 or 10mm wide square tooth...and when the trigger core pin is narrower than the tooth you get a flat in the signal because for a moment the mass under the trigger core is not changing and no voltage is generated. I had to swap it to a hall sensor.
    Yours is no where near this bad! and should be fine. To get a perfect signal you need to eight use a sensor with a wider core pin or trigger wheel with narrower or V shaped teeth, then you would have a nice steep falling edge and you might have a spark that is +/- 0.1 deg instead of 0.2 or0.3 deg...it would be like that, a small improvement in accuracy that probably doesn't matter. Older ECUs and newer inexpensive ECUs can't do any better than about +/- 0.25 and would never know the difference but newer stuff designed to meet emissions rules is 0.1 deg worst case total error (so +/-0.05) or there about so getting the hardware right does matter. I bought a cheap hall sensor from a cheap ECU supplier and ended up throwing it out, if you look closely at the trace the time between falling edges varies (ignore the rising edge, it needed a resistor to clean that up) it was awful. but 3rd time was a charm for me......
  12. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Thanks Mark, David and Steve. Really good feedback.
    1. I think I'll go with the sensor gap I have for now and maybe come back to it later.
    Could it be that increasing the gap would make the sensor see a smaller (thinner) tooth and thereby perfect the wave form a useful amount?
    2. Does anyone know how the Electromotive systems are triggered? Does the system pick a mid-amplitude voltage and center the trigger level there or is it more likely a fixed voltage above ground?
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    no, opening the gap will only reduce the voltage peaks not change the shape in any meaningful way.
    I don't specifically knwo but I've never seen a VR setup that didn't set when it saw voltage above some small number, the trigger at 0V.
    It also apparently has a minimum rpm somewhere between 120rpm and wherever its cranking now. I worked on an open souce ECU project that used the same chip family GM, haltech, motec all use and it did all the time stuff in a coprocessor called the eTPU, enhanced Time Processing Unit. Setting that up in the code was a little tricky because it was a balance between wanting maximum resolution which meant running at a high clock speed, but then you risk timing out at the missing teeth during cranking. the eTPU was 24bit, it replace the TPU that I think was 16bit and probably what is in your electromotive, or a version of it. a 24 bit will count to 16,777,215 but a 16 can only count to 65,535 so while we could support about 50rpm to about 25krpm (same chip and code many of the F1 teams used in the crazy rpm days) and have 0.1 degree max total error, a 16 bit can not so they will need to limit both the lower and upper rpm if they want decent accuracy and I suspect that is what you ran into cranking at 120rpm.
  14. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Mark, given the current wave form and system, what do you think my timing accuracy is over the 1-8 krpm rev range?
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    I think it will be fine with the ecu itself the biggest factor. The wave form isn't perfect but it has a decent slope at 0V, I would guess the sensor won't cause more than like 0.05deg error vs 0.01deg if you fix it... yes it could be 5x less error but it's still a very small number and probably only 10% the error the ecu will create. 0.5 deg is usually right at the line of what you can be pretty sure you're seeing on the dyno and what a 16bit ecu can do....you can just pull it out of the noise. So a 32bit ecu that is 0.1deg error will always beat a 16bit (which I'm pretty sure you have) for hp, but it's 1% maybe and you'll never see the difference between 0.51 and 0.55 deg.
    Now that its working, I would just drive it and be happy :)
  16. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Thanks again Mark. I should be fine. I think I'm running 34 degrees BTDC all in, so very conservative. We backed off from 36 degrees BTDC all in as there was no real benefit power and troque wise.
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    There is no replacement for dyno tuning to get stuff right. Do you have higher compression in the build?
  18. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    I asked for and got a broken-in engine, coarsly tuned for max safe power. I'll do the on-road tuning because I know what I want. My engine builder, MWE of Ronkonkoma, NY, says we ended up at about 10.5:1 CR.
    I posted my engine build here: https://www.ferrarichat.com/forum/threads/bills-308-engine-project.580304/
    I took the car for it's 3rd road test this afternoon. This time, there was no ignition failure. After the plugs cleared, I did about a 1/2-throttle accelleration to about 5 krpm. It felt strong. I got in about 6-miles total.
    Most importantly, I was able to select 2nd gear, on the move, for the first time with my new drive train setup, a 328 transaxle with a changable drop gear system. My initial ratio is very tall, maybe too tall, especially for easy reverse operation. Engine was stable but rough at times below about 2.5 krpm. Torque above 2.5 krpm is really nice. Clutch engagement might need an adjustment. Clutch pedal return spring needs new geometry on the pedal per 328 application where the return spring tensions the clutch cable through the pedal
    I have to resynch the carbs with the now good ignition system, then take a look at the idle mixtures. It's going in for some paint work next week so I need to button up some remaining issues like a small area in the trunk that I'll have to scotch brite and treat with rust converter. Looks like the result of sloppy coolant filling.
    Maybe I should start a new thread, bills308 special, concerning teething problems and development?
  19. murzy
    murzy Rookie
    Jun 7, 2011
    4
    mk e:
    do you have any recommendations for an XDI replacement. I am experiencing an occasional loss of spark which has left me stranded. Now it seems to be fine so until the problem arises it's a bit hard to reliably fix. i am leery of taking it out since no spark is pretty fatal. This is on my '78 308 GTB. I've had the system for over 15 years with no problems until now (though I don't drive it very much). Any dvice would be greatly appreciated. Thanks.
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,458
    Dumpster Fire #31
    SMG
    We've got a replacement in the works. Looking at ease of switching out repin etc.
    Since electromotive went away we've been trying to sort this.
    I do know there's no similar dip switch control option. So any new ECU will be a programmable via PC/Android with more depth of control.
    Just a heads up
    ME308 and ZikZak like this.
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    makes me think its worth having a look at the wiring for something line that
    As for replacing it....literally ANY ECU you can buy today will do at least as good a job. At the cheap end a rusefi uaefi for under $200 or any link or haltech or whatever probably starting around $1200-$1500. for the controller, you can probably keep the coils and sensor you have. You should add a MAP sensor if you don't have one. Or it sounds like Scott is putting a kit together that I'm sure will work well.
  22. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,458
    Dumpster Fire #31
    SMG
    That's what we're trying to do. The xdi was great because it was just ignition, simple and clean. Everything now is EFI. No stand alone ignition.
    Nick picked up another EFI company and I want to test and check them out. Ideally putting something together for those with XDI that need to switch up.
  23. murzy
    murzy Rookie
    Jun 7, 2011
    4
    Thanks for the input mk e. I'm going through the entire XDI system now and will look into your potential replacements. I suspected wiring and when I started looking around something might have gotten re-positioned/reconnected so it's working fine now. I need to replicate the problem so I can be confident it is remedied or I might need to get towed again.If I can't replicate the problem I may have to go with the nuclear option (replacing it).
  24. JCR
    JCR F1 World Champ
    11,029
    H-Town, Tejas
    pshoejberg likes this.
  25. murzy
    murzy Rookie
    Jun 7, 2011
    4
    I'll check them out. Thanks for your help here, JCR.
