Electronic Ignition 246 | FerrariChat
Discussion in '206/246' started by yakxx21, Mar 8, 2014.
  1. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    I see DINO EU ( Home: Startseite) sell a rather nice looking replacement ignition system.
    it doesnt seem to have a name ..but the code is 36...1..45 and looks exactly the same as the original distributor externally
    has anybody tried this system and any comments ..?
  2. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Interesting and looks a bargain compared to the BSM system which appears to be no longer available at the moment.
  3. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    This is a dutch 123 ignition build into a cut up S125 distributor. The igniton output is similar to a points ignition, which is not sufficient for running a Dino V6 engine. (interestingly, 123 itself advises against using their ignition for a Dino engine). The two conversions i have seen had failed due to unremoved metal chips from the milling entering the electronics board. Not recommended :/
  4. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Woo that's a pity
    What system seems to be the best one it hour breaking the bank ?
  5. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    Are you talking about an electronic trigger for the coil (which replaces the points) or something more extensive?
    If the former, I installed an Allison optical system in my car 25 yrs ago and it is still going strong. Today there are probably better solutions that are still very affordable.
  6. solly
    solly Formula 3
    Jun 2, 2001
    1,148
    Westchester NY
    Dr. Steven S.
    I installed Crane Cams XR 700 (trigger, coil, control unit) in my Dino back in 2002. Optical trigger, no more points or condenser. Has been terrific. Not one issue with it. Engine starts every time even when heat soaked. Not expensive, but the labor to install it was a few hundred. They now have a newer version.
    Be aware that many conversions (like this one) will change the ignition from a CD (Dinoplex) to an inductive system, which is not at all a bad thing. In fact the engine seems to do better with the inductive ignition than with the Dinoplex CD ignition.
  7. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    I am 99% sure that is the same thing I installed-- Crane bought Allison at some point or the parent company just changed the name
    I installed it myself and it was not difficult because the dizzy is so accessible thru the inner fender.
  8. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
  9. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Thanks for the inputs I was trying to buy a package to just instal simply without having to fabricate anything myself.
    Incidently if anybody can comment on my new thread ... Have I got this right ... I would appreciate because before I rip pit the old system I want to make sure I have the static timing point correct ref to cams and tdc on number three ?
    Great site this
  10. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Simplest installation would be an MSD 6A #6201 and a Blaster II coil setup, which (technically) is a successor of the Dinoplex ignition.
    Regarding the static timing, i usually just reinstall the dist, start the engine and then set the static advance via a timing light (wired to cyl #3) to 10°.
    If the engine won't properly idle after reinstalling the dist, gently move the dist body CW (advance) or CCW (retard) until the engine keeps running, then use the timing light for setting the timing to exactly 10°.
    good luck,
    Adrian
  11. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Thanks for your advise.
    Can you advise ref MSD 6201 ignition...I have a six lobe double points system..
    How do I connect it to the MSD system
  12. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    #12 alhbln, Mar 19, 2014
    Simply wire the MSD's white wire (Points) to the distributor terminal marked R1. You can ignore the terminal marked R2, that was just used for the ignition retardation in the emission control setup.
    Here is the wiring diagram:
    http://www.dinoplex.org/PDF/MSD_6A_Dino_Wiring_Diagram.pdf
  13. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Thanks very much
  14. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    I don't know why people buy MSD boxes-- they stop doing multiple discharges at about 4,000, no? So what good is that on a Dino?
    The guys on the Pantera forum recommend you keep a spare in the car because they have a pretty high failure rate.
  15. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    The factory fitted Dinoplex CDIs had no multiple discharge feature at all and the Dino engine runs quite well with these, so nothing really to worry about :) Multiple discharges are effective in cold starts but do not really make a big difference in driving from my experience.
    The broken MSDs i got in for repair had failed due to vibration (installations without the rubber mounts) and/or components overheating, and all of these had been installed in the engine compartment. With the Ferrari 206/246 an MSD has a comfortable life in the luggage compartment, so considerably less stress and a longer service life.
    If you wire up the MSD in the same manner as the factory Dinoplex setup, you could always change the connector for the Emergenza mode in case of an ignition failure and still be able to drive home:
    http://www.dinoplex.org/PDF/Ferrari%20Dino%20246%20Wiring,%20'70%20Europe,%20two%20terminal%20connector.pdf
    Best,
    Adrian
