Electronic ignition control box mounting | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by s14kev, Jun 27, 2024.
  1. s14kev
    s14kev Rookie
    Oct 17, 2020
    26
    Kevin Au
    Just sharing a quick tip for people looking for places to mount ignition control boxes. Mine were originally upside down under the battery tray. This is a terrible location. Battery acid had leaked onto the tray and into the control boxes. Mounting them on the wheel well is unsightly for originality. I also didn't want to drill extra holes in sheet metal or the fiberglass firewall so I came up with a mount plate to place them between the battery and firewall. It mounts through the factory holes for the battery tray. Seemed to be the best solution I could find if anyone was running into the same problem. I do have 2 spare mounting plates that are laser cut to exact dimensions if anyone needs one. One is 1/8" 5052 aluminum and the other is .030" 304 Stainless. The stainless was designed to have a 10mm foam pad under it for vibration dampening.
    samsaprunoff likes this.
