Eliminating residual fuel smell | FerrariChat
Discussion in '456/550/575' started by uberlink, May 29, 2016.
  1. uberlink
    uberlink Formula Junior
    Apr 23, 2012
    777
    Twin Cities, MN
    Mark Johnson
    My dear friend and mechanic 2NA recently replaced the plastic fuel pump caps with the improved aftermarket jobs. The fuel smell in the car all but disappeared...but there's still some residual smell in the trunk that will saturate parcels left in there and that can waft into the cabin.
    Anyone got a magic trick for eliminating that, other than burning off the back end of the car?
  2. vee12
    vee12 Formula Junior Silver Subscribed
    Nov 2, 2008
    361
    Atlanta
    Les
  3. uberlink
    Apr 23, 2012
    777
    Twin Cities, MN
    Mark Johnson
    Thanks. Will check those out.
  4. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
  5. uberlink
    Apr 23, 2012
    777
    Twin Cities, MN
    Mark Johnson
    Guessing I'm going to be putting activated charcoal back there...that and maybe leaving the trunk open while the car is parked in the garage for a while.
  6. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
  7. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,175
    Probably still some residual gasoline left in the carpeting back there. You might try removing them and drying them in the sun. Then use a good carpet cleaner to finish the job. Resolve has worked well on carpets for us, even on coffee stains. If the carpets are too much of a pain to remove, just the Resolve and leaving the trunk open probably will work.
  8. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Burradoo... Actually
    Graeme
    Terry this is exactly what I did. A decent auto carpet shampoo also helps. You can leave the boot/trunk ajar to help vent the area.
    The trunk/boot switch doesn't operate until it is more than 1/4 open, you can hear the ball klunk as the contacts are made.
