Elring Head Gasket Problem | FerrariChat
Discussion in '206/246' started by racerboy9, Dec 1, 2018.
  1. racerboy9
    racerboy9 F1 Rookie
    2,514
    So I am already to reinstall my heads and the hole is too small that goes over the oil feed /restrictor dowel that stands proud of the block. The hole is 9.57 mm and the restrictor is 9.97mm. No way it will go on without messing up the gasket. Has anyone ran into this problem? They are the later style gasket with the printed red seal. Bought these years ago. I could Dremel the hole bigger but I am not real hot on that idea.
  2. racerboy9
    racerboy9 F1 Rookie
    2,514
  3. racerboy9
    racerboy9 F1 Rookie
    2,514
    Numbers are a little off as I posted and then took the pictures but the difference between the hole and the dowel is large.
  4. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    16,240
    wisconsin/chicago
    bo
    That's just a dowel, right? Not an oil passage? Can't see how opening the hole would hurt.
    Rebuilding a 930 motor right now. The new parts such as rings, bearing,etc all seem looser/less accurate compared to the original Porsche stuff. Had to actually order a lot of parts from Porsche, to get the right fitment, even though the manufacturer is the same...
  5. daviekj
    daviekj Formula Junior
    465
  6. racerboy9
    racerboy9 F1 Rookie
    2,514
    Kevin, the hole in your gasket actually looks bigger in diameter than mine. Yours runs close to the sealant whereas mine has a noticeable gap. Trying to install mine flaked the gasket material a little and that is with me being super careful. There is metal sheet sandwiched between the fibrous material and I would have to think it would deform a good bit going over that restrictor/dowel. I am running over to T-Rutland on Monday to compare my gaskets to more current Elring production. I don't see anyway this could be anything other than a production error. I bought these years ago but they are still new in the package. I am holding my breath waiting for a reply from Elring. :)
  7. daviekj
    465
  8. dgt
    dgt Formula 3
    Jan 14, 2011
    1,283
    Northeast, USA & Oz
    Andrew
    I use reinz head gaskets and these have a 10.6mm hole with a copper sealing ring.
    You can probably just enlarge the hole with a 10mm punch.
  9. racerboy9
    racerboy9 F1 Rookie
    2,514
    I may try the punch on my gasket just for fun. It is flaked around that hole so I won't use it anyway.
  10. racerboy9
    racerboy9 F1 Rookie
    2,514
    Wow! Heard back directly from Elring this morning and it seems they may send me replacment head gaskets. Fingers crossed!
  11. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,836
    Norfolk - UK
    Tony
    Elring's product support is very good so fingers crossed for you, check you don't have the fiat dino 2.0 head gaskets, I seem to recall some variation (apart from the bore dia 86mm against 92.5mm) and this may be one of them.
  12. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    Using a punch to open up the hole is going to deform the surface of the gasket around the hole. I would use a die grinder with a small cylindrical shaped stone to carefully open up the hole to the right diameter. As long as the gasket doesn't delaminate and you don't damage the sealing surfaces around the area of the hole, then it should work just fine.
  13. racerboy9
    racerboy9 F1 Rookie
    2,514
    Elring has been pretty responsive to the problem. A couple of the stud holes are off enough to bind. Way too much work involved in replacing head gaskets to take a chance on an iffy gasket. We will see if Elring replaces my three sets of gaskets all with the same problem.
  14. racerboy9
    racerboy9 F1 Rookie
    2,514
    Elring came through on replacing the head gaskets. Very nice folks to deal with. The gaskets I received have a slightly tacky film of sealant over the whole gasket. Maybe they have been this way for a while but it is new to me. Looks like a good idea.
