Emblem Installation | FerrariChat
Emblem Installation
Discussion in '308/328' started by tinterow, Mar 26, 2016.
  1. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    I removed all emblems for a little paint work and detailing on my '80 GTSi. My question is...Did the emblems come with the double stick tape? I have seen examples both ways. Any thoughts on the subject? Thanks!
  2. John M
    John M Formula Junior
    Nov 18, 2004
    888
    Kentucky
    No. Perhaps broken retainer pins on your emblems.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,834
    Cerritos, CA.
    On the QV, the emblem "quatrovalvole" is on the car by a double side rubber tape but the "308" has the stud with nuts behind it.
  4. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    All my pins are intact...an example would be the Pinanfarina badge behind the driver door. There are pins but no way to get to them behind the quarter panel. When I took it off there was double stick tape...
  5. John M
    Nov 18, 2004
    888
    Kentucky
    3m double sided emblem tape works fine for those. Probably better if the tape seals out water entering the panel. I think all mine had pins with little retainers that pressed on. The nose badge had studs with tiny nuts and washers. The Pininfarina badge....I cannot recall what we did on it now. But just trim it so you can't see it. If this is following a repaint, give the paint some time to cure before applying.
  6. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Thanks, John!
