Emblem | FerrariChat
Emblem
Discussion in '360/430' started by anedom, Apr 24, 2016.
  1. anedom
    anedom Rookie
    Jul 20, 2008
    33
    The Ferrari emblem is coming off on the port side of my 360. How do I repair it. Is it an adhesive?
  2. FerrariCountach
    Jul 30, 2020
    21
    I suggest taking it off completely and using adhesive to put it back on for a good fit
  3. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Are you talking about shield, item 15? If so, you can see it’s secured from behind by nuts. If it’s coming unglued, it’s an aftermarket piece, likely held by double-sided tape. Repair is by removing, cleaning off all old tape and using new 3M 5952 VHB tape. It’s very thin, but strong when applied correctly. Be sure to mark the exact location before you remove it because there is no location recess to show the location unless your car came with the OEM shields.
  4. rudkinjc
    rudkinjc Rookie
    Apr 27, 2019
    45
    Jacksonville Fl
    Joe C Rudkin II
    It sound like you have an aftermarket stick on. The original are metal shields embossed into the metal fenders. Here is a close up of mine.
  5. rudkinjc
    rudkinjc Rookie
    Apr 27, 2019
    45
    Jacksonville Fl
    Joe C Rudkin II
    This was a factory option. Not all 360s have the shields.
