Emission Test Failed...help with codes needed | FerrariChat
Discussion in '348/355' started by PA Charles Ferrari F355, Apr 19, 2010.
  1. PA Charles Ferrari F355
    Apr 3, 2010
    74
    Chester County
    Charles B.
    My F355 needs to pass its first Pennsylvania emissions test in order for me to be exempt for ALL future testing because I plan on putting no more than 2,500 miles a year. Great PA exemption law.
    Recently went in to a small "non Ferrai" shop to get it passed and the following codes came up after it failed:
    1. P1691
    2. P0341
    3. P0432
    4. P0422
    Facts about my vehicle:
    1. has a tubi exhaust with ferrari cats
    2. purchased from Florida and had car for only 3 weeks
    3. when doing PPI... battery was diagnosed to be bad and was replaced by the seller for me prior to my delivery
    4. I've put 510 miles on it in the past 3 weeks and the previous driver put only 900 miles on the vehicle in the previous 3 years prior to me purchasing it.
    I tried doing some internet research and not sure if codes are universal with other non Ferrari vehicles? Any help to interpret what codes are and mean. Anything to worry about? What is the road of least resistance? Please give advice. Thanks in advance!
  2. LmnsBlu355
    LmnsBlu355 Formula Junior
    Dec 28, 2009
    284
    NY
    Jordan S.
    Welcome to F-Chat. You can use the search function to answer most questions. I just did a quick search and p1691 seems to be an open circuit in your check engine light (ie. someone removed the bulb).
    P0432 & P0422 are catalyst efficiency codes (bad cats or O2 sensors). P0341 = Camshaft Position Sensor Circuit.
    Good Luck
  3. PA Charles Ferrari F355
    Apr 3, 2010
    74
    Chester County
    Charles B.
    What does it mean that someone removed the bulb? Could this mean that I have a major problem? Would driving the car do damage?
  4. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Congrats on the purchase and welcome to Fchat!
    If the check engine light was removed when you purchased it absolutely go back to the seller and ask them what's up. I had the same thing, but didn't notice until 6 months later when I went to register it. and mine actually passed a dealer PPI, goes to show what that was worth.
    Depending on where you are in PA, a great local expert shop to help is Pocono Sportscar (near NY border).
  5. f355spider
    f355spider F1 World Champ
    18,044
    #5 f355spider, Apr 19, 2010
    Sounds like the previous owner removed the Check Engine light bulb...you can easily remove the cluster and confirm. Two Phillips screws to the left and right side of the instrument housing is all that is required. Release the steering wheel height adjuster so the wheel drops down, and place a towel across it to protect.
    As previously mentioned the most likely diagnosis for your problems (which still need to be confirmed by a Ferrari Technician:
    P0341 probably a bad cam position sensor, a simple repair to swap it out for a new one. Not sure of cost, but probably less than $100 for the part plus 10 minutes labor to swap it out.
    P0422 and P0342 "low catalyst efficiency"...which invariably means the cats have failed. A VERY common problem, I have replaced four on my car alone! But again, an inspection or post cat CO/HC test will tell you for sure. New factory cats are expensive...aftermarket may be a better option. (about $2200 for the pair plus a couple hours labor)
    P1691 Not sure, that has been requested for information, but is not on the list anyone seems to have...it may go away with fixing the other stuff....maybe. ;)
    Good luck with the previous owner...he is probably going to claim ignorance...heck, maybe he was suckered himself...but there may be a duty for him to correct before selling to you...I am not an attorney.
    BTW, who did the PPI? Any shop worth their salt would have noticed the CE light not illuminating upon start up (key in "on" position, but before cranking), AND they should have scanned for codes with an OBDII code scanner as part of the inspection.
  6. LmnsBlu355
    Dec 28, 2009
    284
    NY
    Jordan S.
    Let me preface by saying I'm not a professional mechanic or a Ferrari expert but have learned alot on this and other chat rooms. I too am new to 355 ownership. Most of what we will experience as new owners has happened to others before and the search feature is a tremendous asset.
    I am assuming you do not have a Check Engine light on, correct? If so, then the bulb was probably removed by the prior owner to avoid fixing the real problem(s). The catalyst codes seem to be common when cats are changed to aftermarket or fail or when O2 sensors fail. Not sure what the implications of the cam position sensor code are.
    I'm sure other more seasoned experts will chime in here but I would get it to an experienced mechanic before putting on too many more miles.
  7. f355spider
    18,044
    I am also NOT a Ferrari technician...but don't believe it would be common to get "catalyst low efficiency" codes with a bad O2 sensor, either pre or post cat...as there are specific codes for various types of O2 sensor malfunctions and failures.
    As you stated, the "catalyst low efficiency" codes are most commonly caused by failed cats, or sometimes an incompatible aftermarket catalyst.
  8. PA Charles Ferrari F355
    Apr 3, 2010
    74
    Chester County
    Charles B.
    #8 PA Charles Ferrari F355, Apr 19, 2010
    I'm going to call the person who did my PPI tomorrow first thing, who was Omega Motorsports in Jacksonville, FL and ask if they did a scan for codes using a OBDII. I'm assuming that the bulb was taken out on purpose to hide the cat problems or could it be for something else? Very surprised this was not brought to my attention. I guess this is how "entry level" becomes no longer....... "entry level".
    Also what after market company and brand for new cats should work the best? Is this better than going the Ferrari direct route? I know I have a great non Ferrari dealer mechanic out of Kutztown, PA as I will contact him as well as my car is scheduled for him to look at it next Monday. He does not have a OBDII and I'm hoping with his ability that he can help vs going to a Ferrari dealer for repairs. This site as been priceless with all of the great knowledge and any extra advice is always appreciated!
  9. f355spider
    18,044
    #9 f355spider, Apr 20, 2010
    If your mechanic does not have an OBDII scanner , find another mechanic. You may mean he does not have and SD1 or SD2 (proprietary Ferrari), that is okay, if he has a generic OBDII scanner. Seriously, take it to a competent Ferrari tech, either dealer or independent, but do NOT take it to someone who is not intimately knowledgeable on the F355...this is not a car you want someone learning on, no matter how experienced they are with other cars. There are just way too many idiosyncrasies with these cars.
    If you don't want "check engine" lights, you are going to need to get a high quality replacement. Either recore the originals, or buy aftermarket. The oem ones will fail again in 15k to 25k...they are crap.
  10. f355spider
    18,044
    Be sure to confirm the cats are in need of replacement with a post cat emission sniffer check and physical examination. It only takes 15 minutes per side to remove and confirm their condition. I am guessing the ceramic cores have broken loose from the housings...that is the usual failure mode. Post picks when you get them off.
  11. full_garage
    full_garage Formula 3
    Feb 15, 2010
    2,241
    Sarasota Florida
    Jay
    Once your bulb is back in and working you should be able to clear all of those codes.
    It is NOT uncommon for a 355 to throw an o2 code- and it does not always mean you need to repalce your sensors or cats.
    I'd try to clear the codes first and drive the thing- You'll need about 150 miles and 4 or 5 drive cycles to get the car back to "ready" for Emissions. Anybody with a good OBDIi reader can do all of the above.
  12. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    P1691 is probably open circuit on your CEL. P1692 was short circuit on mine.
  13. f355spider
    18,044
    Seriously? I have never heard of that here, or from anyone of my friends that owns a 355. Invariably when the CE lights up, there was an actual problem that needed attention.
  14. full_garage
    Feb 15, 2010
    2,241
    Sarasota Florida
    Jay
    His CEL was either burned out or not present, so that in and of itself relates an error code that will not allow the car to pass emissions.
    In my conversations with several very well qualified Ferrari shops they have related to me stories of several codes present on cars brought in for routine service that checked out OK- they cleared the codes and the car was able to pass Massachusetts emissions tests after putting enough miles on it to be in a "ready' state.
    A CEL does not immediately mean that components need to be replaced. Obviously he'd need to get the car to a shop who can read the codes, determine whether any components are in fact bad and then clear the codes.... whether actual mechanical work is needed is not known at this time.
    Without the CEL functioning you cannot get the car ready for an emission test- with a functioning CEL you can- and then if the CEl comes on again you know you have a systematic problem that needs to be addressed.
  15. f355spider
    18,044
    #15 f355spider, Apr 21, 2010
    I understand about the light, and was not saying it did not need to be corrected. Agreed one needs to confirm the issue before replacing anything...(see my posts in the OP's various threads he has started where I stated exactly that). Granted my sample is small based on myself and three friends with 355's plus the posts I read here over the past several years. It certainly is of little consequence to clear the codes and see if they come back, but my experience is that you will likely be disappointed with the results of that method.
    I apologize for not being more clear, I was only questioning the issue of "phantom codes" not his need to replace the CE bulb and verify the other two codes. Failed catalysts and O2 sensors are probably the two most common causes of CE lights on 355's.
  16. full_garage
    Feb 15, 2010
    2,241
    Sarasota Florida
    Jay
    Yeah agreed-
    My car threw all four O2 sensor codes and a crank sensor code- After exhaustively checking everything we cleared the codes and all was well. If there's one problem with 355's it's the fairly touchy ECU programming that throws far too many CELs.
    Obviously it's important to always check out a CEL- we've all heard far too many horoor stories about deferred maintenance and it's ultimate cost.
  17. PA Charles Ferrari F355
    Apr 3, 2010
    74
    Chester County
    Charles B.
    Spoke to Steve who did my PPI and he reassured me that he checked all codes at the time and found no problem. Also, after battery needed to be replaced the following day he recleared the codes and did everything by the book. I strongly believe him in that he had nothing to do with my open curcuit on my check engine light! I'm hoping not to find a missing bulb just one that burned out? My car was going to be taken back from the PPI shop the next day and was picked up by Intercity transport 2 days after that. Very small window.
    Steve stated that he strongly feels that the cats are still in working order and has advised me to purchase fuel additive from Chevron called Textron(sp) and since the vehicle only had 900 miles put on her in the last 3 years he feels the failed emissions could be carbon deposits affecting my emissions. I purchased two bottles and will run the cycle 2 times as per his advice, with each of my next two fill ups and see if Ferrari lady luck is on my side.
    I also talked to Joseph from www.fabspeed.com and he is advising me to remove the O2 sensor (lambda sensor) and wipe it down. He states that this fix works 95% of the time.
    What are your thoughts on cats bypass pipes....or Loreni test pipes.... or hyperflows with my tubi exhaust.... if I can get emissions to test out? My concern is that with a tubi which by itself is loud, it may be too loud with any of my add on choices? Any thoughts?
    I'm lucky that in Pennsylvania once you get your emissions set up for the first time with passing grades all future testing is exempt with putting less than 5,000 miles a year on your car. That surely allows me some options.
    My previous posted "error".... as my mechanic in Kutztown does have an OBII, but does not have an SD3, but he is very Ferrari savy and knowledgeable.
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,767
    Lake Villa IL
    I think wiping off the o2's would do just about nothing. If you're going to the trouble of removing them, just replace them. Mine were working fine on a scanner but they were original so I knew a new set would switch faster. (and there was sometimes a very slight surge sensation at steady cruise and low throttle openings)
    With new o2's in the car it runs perfectly smooth.
    My stock cats were fine but I went ahead and replaced them with metallic as the consensus seems to be that if they havn't failed they will.
    I don't like test pipes on these cars as I don't like to smell like unburned hydrocarbons.
    I did remove the secondary cats on mine. (which only operate when the bypass valve opens so I don't get any smell in the cabin). After looking at them I don't think it's really worth the effort in terms of flow.
  19. f355spider
    18,044
    +1. And remember, you (Charles) don't have O2 sensor codes, you have low catalyst efficiency codes. The Motronic monitors O2 function and will throw a separate code if they are bad. I agree that a "lazy" switching O2 sensor can get past the Motronic and not set a code, that has been seen here before.
    Bottom line on the Techron fuel additive is "good luck". Won't hurt to try. It is a bit early for cats, they usually last to 17 to 20k miles.....but there is always the exception. Let us know what happens. And what about the code for the bad cam position sensor? That still needs to be address, and I doubt even more that fuel additive is going to help there either. ;)
  20. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    Charles, I can only communicate my own experience. My 355 has those Cat below efficiency codes, both sides when I picked it up. I cleared the codes, put 800 miles on the car with 4 tanks of gas. With each tank of gas, I added a bottle of Chevron Techroline bought at the gas station and drove the snot out of the car until the next fill up.
    So far, the codes have not returned. I cannot say that they won't return, just that they have not returned. Good luck to you with this. Remember to drive the snot out of it.
  21. f355spider
    18,044
    Good to know it worked for someone, I stand corrected!
  22. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,326
    Palos Verdes
    Vince V
    #22 vvassallo, Apr 22, 2010
    Long live the Italian tune up!!!
    Once the smogging is done, cat bypasses will be worthwhile in your state, you lucky dog! If you want new cats, look for hi flow metallic core versions - check with gothspeed here since he has some pretty cool ones at a very reasonable cost for fellow gel heads. :) Tubi is way to screechy for my sensitive ears; Larini is just loud. You might be happy with just the cat bypasses. Try them and see. You might save some cash.
  23. PA Charles Ferrari F355
    Apr 3, 2010
    74
    Chester County
    Charles B.
    My car is going into the shop next week and I will let you know the outcome. I know the bad cam position sensor has to be addressed as I'm sure this is the reason for my poor performance.
    Having been a Ferrari owner for slightly over a month, I believe I'm getting the gist of some of the common problems/fixes associated with certain models like the F355 thanks to all the knowledge that exists on the Ferrari Chat.
    I will check into gothspeed and see what they have as I know living in PA I have some viable options unlike California and or other states.
  24. PeterVan
    PeterVan Rookie
    May 17, 2010
    31
    Santa Maria. ca.
    Peter Van
    After spending the day at the dealer yesterday, they did the fuel block update and also a obdII connector update (adding a additional grounding pin) that would allow communication to calif smog machines.
    I should have not taken for granted that they would not check there work. Had they hooked to a machine, knowing i needed a smog they would have cleared and diaged the code. From reading the Fab Forum I am understanding a open circuit, Bulb, Connection or Cable on the Check engine light. I have never seen it lite up, I will search further for a procedure to extract the bulb and make available the circuit for testing. hope to meet some of you soon in cali next month.
  25. f355spider
    18,044
    Peter, there are several threads on removing the instrument cluster and replacing the various bulbs. It is very easy, two Phillips screws on each side, at the bottom of the cluster. Lower the steering wheel first, and drap a towel across the steering column to protect from scratches. All the instruments can be simply unplugged, then you can take the cluster into the house to work on it.
    You may wish to buy new bulbs for the illumination "while you are in there" and replace them all. Pm me via email if you need any help or suggestions.
