Emission valve in the air box | FerrariChat
Discussion in '206/246' started by simonc, Feb 6, 2011.
  1. simonc
    simonc Formula Junior
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    #1 simonc, Feb 6, 2011
    There is a connector on the underside of the air box of my 73 euro-spec Dino. It has a 20mm pipe running to it from the blow-by cannister, and two 8mm smaller pipes connected to the carbs. On my car this is just a hollow connector but looking at the parts manual it seems that some form of valve should be inside this.
    Can anyone shed any light on this? Is the valve necessary, and what does it do? Or is it just a gauze to stop any blow back?
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It's a PCV valve. It allows blowby to escape the crankcase and enter the intake system without having a continuous vacuum leak. If you don't have the valve, and have trouble setting the idle mixture, you might try plugging the two smaller ports and just have the big one into the air cleaner.
  3. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    I believe that there is just a copper disk on top of the hole- the copper cage just keeps it from falling off. The vacuum pulls the disk down and seals it. I turned one out of aluminum that is more like an inverted top hat when I could not find mine.
  4. racerboy9
    racerboy9 F1 Rookie
    2,650
    I believe the disc is phenolic.
  5. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    I was totally unaware of this disc as the car I am working on has it missing. If anyone can post more photos or information on how I can replace this missing part it would be most appreciated.
  6. Nickrry
    Nickrry Karting
    Jan 4, 2009
    156
    I had the remains of a phnolic disc in mine but it was too damaged to function as anything. I have run without it, but the question remains is it worth having?
  7. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    #7 jselevan, Feb 22, 2011
    The disk is a "snorkel" device. It allows pressure in the crankcase (oil vapor) to enter the intake manifold, but prevents atmospheric air from bypassing the carbs. Stated differently, when crankcase pressure exceeds plenum pressure, the disk opens, spilling oil vapor into the throttle intakes. When plenum pressure exceeds crankcase pressure (closed butterfly's - trailing throttle or idle), the disk prevents air from entering the crankcase.
    If the disk is removed or missing, and the two small fittings to the intake manifold are not plugged, then plenum air will enter below the carbs directly into the intake manifold. This will alter mixture and make tuning the carbs difficult....if not impossible. The engine will run lean.
    Jim S.
