Emissions inspections - CA and others | FerrariChat
Discussion in '308/328' started by mike996, Jan 13, 2010.
  1. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    #1 mike996, Jan 13, 2010
    I am curious re emissions testing. There is a post here about a car for sale in CA that can't be sold there because it can't pass emissions requirements. It has always been my understanding that a vehicle only has to pass the emissions requirements that were in effect the year it was manufactured.
    In other words, if you have a 1980 Ferrari, or ford, or fiat, or whatever, it has to be able to pass the 1980 emissions standards, NOT the standards for a 2010 car. Isn't that the case or does CA and possible others require that the car have additional emissions equipment or whatever to meet 2010 standards to be sold there in 2010? Seems an absolutely impossible requirement. What's the real deal?
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,852
    Atlanta
    John!
    California has some pretty aggregious laws when it comes to emissions testing. Take a '76 308 for instance. A '76 308 had no cats, two air pumps, and a set of retarded points for idle. This setup was designed to yield less than 500 hydrocarbons, which it can do without with some fiddling and of course killing performance. California testing at the time was right around that standard. Current California standards require a '76 model year car to pass with less than 120 hydrocarbons, so about 4 times less. This can be done with a healthy engine and proper tuning, but it's a !@#!%!
    In Nevada, they require testing every year but the standards are a bit easier. '73-'77 cars need to pass with under 500 hydrocarbons while '78-'82 cars need to pass with less than 300. The standard obviously gets more strict as they progress to more modern equipment. The only thing that is rough with Nevada is the idle test. The idle and timing really needs to be spot-on to get it to pass. Last time I did the NV test I got by under 100 hydrocarbons at idle and around 80 at the 2500rpm hold test. At least in California they use rolling road which can really lean out the mixture with the throttle plate open a bit more under load.
    -john
  3. Gerry328
    Gerry328 Formula 3
    2,441
    Home
    Gerry
    IL test only OBDII cars.
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    Wow - I had no idea that any state mandated stricter requirements for cars than whatever they originally had to meet. I can certainly understand requiring a car of whatever year to meet or exceed the standards for that year but to require a car to do better than it was designed to do is pretty rough. Obviously such rules are designed to get older cars off the road, regardless of their pedigree...
    How does this work with a car that was manufactured before there were any emissions requirements at all?
    In MD, if you have a "historic plate" no emissions testing is required. I have regular plates on my 328 at the moment because it didn't qualify when I registered since it wasn't 20 years old but I will go to historic when it is time to renew. It's actually unnecessary in MD because they didn't emissions test the car anyway, just gave me a "pass" sticker because the car is too low to roll onto the "dyno."
  5. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,338
    Encino, Ca
    Carl T
    In California all cars with a year of manufacture of 1975 or earlier are smog emissions exempt. This includes all Euro versions as well.
  6. Rifledriver
    37,106
    In Ca pre 75 cars are not tested. Historic plated cars do not require biannual testing.
    Test standards are drawn from a hat by a bureaucrat and have no basis in reality or the standards the cars were designed to pass when new. That isn't legal but the law has never stopped a piece of legislation or regulation. As a result many cars are difficult to pass legally here. This is all based on politcal whim and political expediency and no one should ever assume, make automotive decisions, or modifications, based on the belief that these rules are set in stone.
    Ca is not the only one. There are other states with emission laws nearly as capricious.
  7. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,703
    wisconsin/chicago
    bo
    Wisconsin just changed its laws. Any car OVER 10 years old isn't tested :).
    I have no idea how that became the criteria...but thats what it is. Nirvana :).
    Part of the rational was that "very few cars over 10 years old are on the road for any significant mileage." The other criteria? They ran out of money in the budget to "test every car."
  8. Dr Tommy Cosgrove
    36,437
    Birmingham, AL
    Tommy
    We have no emission laws here.
    Thank god
  9. klatu
    klatu Formula Junior
    Apr 13, 2009
    277
    San Diego
    Rob Mckinney
    I spent some time one winter in Detroit and was amazed at the number of cars that were rusting away because of using salt on the streets. Maybe the cars don't last more than 10 years.
    Rob
  10. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,599
    Gates Mills, Ohio
    Jon
    I was going to say... I lived in Cleveland and Chicago, and we had 11 year old cars in museums so we could remember "the classics".
  11. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    In WA state there's no visual inspection however there is a sniff test for all cars (historic plates exempted however) in urban areas. Some of the more rural counties don't emissions test. I don't know for sure but it seems to me that the sniff test passing threshold depends on the year of the car ie. older cars can pollute more, but again, not positive on that point. Cars with historic plates are exempt from testing and pay no license fees (rolling 30 year old requirement for historic plates). I'll be registering my '82 gtsi for historic plates in 2012 (assuming the law doesn't change!).
  12. furnacerepair
    furnacerepair Formula Junior
    Feb 9, 2009
    744
    Wisconsin
    Martini
    Quite right on this. I had mine tested three times before I got collector plates. No more yearly fee. : ) Then they changed the laws. Would not need to pass smog test any more anyway.
  13. maestro8
    maestro8 Formula 3
    2,054
    Nor Cal
    Jason
    I just looked at the CA DMV rules & regs for getting historic plates. Said the car needs to be 25 yrs. or older, and the car may only be "driven in historical exhibitions, parades or historic club activities".
    So, as long as the local club wants to drive with me to lunch a couple times a week... we're good, no? :)
  14. Davvinci
    Davvinci Karting
    Dec 11, 2009
    162
    California
    DavidoSpeedo
    I have really loved seeing the posts on this subject. The specs are posted on each automobile as to the emissions equipment needed to pass smog. I just failed mine and am trying to figure out a way to make sure I don't spend unnecessary bucks on cat converters that don't need replacing. I started a thread about not starting hot in this forum and everyone has been fantastic but to my knowledge, no car has had stricter emissions imposed on it than the original specs that the care was designed for. At that time, we had two types. 49 state and California emissions. Since then, they have put mandatory additives in gasoline (which is why we pay a higher price for gas) but the standards remain the same. Tomorrow I go to re-test the car and will quiz the tech about standards. We are not Einsteins. A car doesn't make less emissions better as it gets older or wears out.
    I'm not feeling that California love out there.
  15. Rifledriver
    37,106
    #15 Rifledriver, Jan 13, 2010
    Tail pipe numbers are not posted on most cars. The law on that changed while carbed cars where still in production. The state does not require more equipment on any car but they have changed tail pipe standards in the middle of the game. Additionally no car was required to pass standards on a chassis dyno prior to a few years ago. In 1976 they never heard of such a thing. You have to do it now. On some cars it makes it easier to pass but on others the inverse is true.
    308 carbed cars are required to pass a considerably lower spec than when new. Also all carbed 308s have the same spec to pass whether they have cats or not.
  16. Dr Tommy Cosgrove
    36,437
    Birmingham, AL
    Tommy
    I think it is just cute as can be that older cars that pullute are given a pass and brand new cars that actually (depending on where they are running ) clean the air when turned on are required to be checked.
  17. furnacerepair
    Feb 9, 2009
    744
    Wisconsin
    Martini
    So true. What are we missing here? I don't get it. It is to my advantage though. I just wish this would have come about years ago. I would have been able to sell my cars for alot more $$$. Ever try to get a Jag V12 with no cats or any smog stuff to pass. NO way. Gave that one away. Could not register it anywhere in WI.
  18. Davvinci
    Davvinci Karting
    Dec 11, 2009
    162
    California
    DavidoSpeedo
    Well, I would like to know what has changed that could make the car cleaner than what was required of the manufacturer. If we all have to re-engineer our cars, I guess we'll only be driving them in parades with historical plates and limited mileage per year. Not my idea of living, for sure.
  19. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    Brian,
    1978 GTS carb. I had another car of mine getting smog, and i looked through the smog book at the emissions shop that lists what smog equipment the car came with. it said teh car should have come with cats. is that true? i thought the 78's came with cats.
  20. Ferraripilot
    May 10, 2006
    17,852
    Atlanta
    John!
    ya. US '78 and '79 cars had cats, detuned cams, and air pumps.
  21. eurogt4
    eurogt4 Karting
    Apr 15, 2006
    243
    Sacramento, CA
    On the subject of California smog and historic license plates, I called the California DMV to ask about the historic plates, and I was told that even with historic plates, if the car was newer than 1975, it would still have to be smogged. There didn't seem to be much advantage to historic plates, except possibly slightly lower registration costs and limited occasions to drive
  22. MechEng
    MechEng Rookie
    Oct 5, 2009
    2
    Saskatoon, SK. CAN.
    L. Neil LaBine
    From what I know of California, it has tons of custom auto shops. How do they get away with some of the cars they create?
    Things like putting a LS1 engine in a 1980's Ford. Do you have to license it as a "kit car" or something? Does it still have to pass emissions standards? For what car then, the Corvette it came out of or the Ford it went into?
    And California won't allow a supercharged 308 to be licensed on it's roads. Oh no, put that air pump back on.
    It's so confusing.
    Cheers,
    Neil
  23. Davvinci
    Davvinci Karting
    Dec 11, 2009
    162
    California
    DavidoSpeedo
    #23 Davvinci, Jan 14, 2010
    Not to be to contrarian but if they hold me to tighter standards than the "tailpipe numbers" on my windshield (I didn't know they were there till you brought it up, I appreciate that), we'll have to find out the leagality of "making" a car unpassable or unreasonably tough to pass the test. I know it's not arguable with a state agency but when you got the time, it's good to test the system. That's how i learn, anyway.
    BTW I was only talking about the label in the engine compartment diagramming the needed smog "parts" but in seeing your post, I started looking and found this label.
    The dyno is simply a better way of testing the emissions in a real world situation. Yah, more expense for the business' but we got to keep up with the times.
    All learning is good; even if it's about a bad thing.
    I might be a dinosaur but I don't see myself turning to oil yet.http://www.ferrarichat.com/forum/attachment.php?attachmentid=1072093&stc=1&d=1263492240
    First time I've uploaded. Hope it comes out. Pic is of tailpipe specs
  24. Davvinci
    Davvinci Karting
    Dec 11, 2009
    162
    California
    DavidoSpeedo
    Hey, I'm sure it can be done. After talking to the people here, I truly think anything is possible. What i know from my friends, the car is either registered as the year of the chassis year and that years smog laws are enforceable or they list it as experimental and a custom registration (like a kit car).I haven't heard back from a buddy but this is California. for every rule they make, there is a "work-around" for it. Naturally, it's a pain in the rear but if it was easy we'd have our sisters out there doing it (sorry about the sexist attitude; my sister constantly outdrives me on the golf course and then says "Does your sister golf?") She's also a lawyer which helps with the legality issues I bring up (but it's a pain in the rear for her too). Sorry for the log posts. I will be less berbose in the future if possible.
    It's so confusing.
  25. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    that is what i believe as well, but the book i was looking at with the smog tech clearly showed the 78 gts has not having the cat box checked as required equipment...
