Engine and gearbox drain plug washers | FerrariChat
Discussion in '308/328' started by Yoric, Dec 1, 2024.
  1. Yoric
    Yoric Formula Junior
    383
    Yoric
    The NAPA # 704 1356 copper washer is a perfect fit for the early (carbureted) 308 gearbox drain plug. Is there a corresponding copper washer for the engine sump drain plug available from NAPA or other local parts houses?
  2. GT4:13432
    GT4:13432 Rookie
    Feb 20, 2020
    38
    Australia
    Dave
    On my 1977 308 GT4 they're all the same. Engine sump, gearbox drain, gearbox overflow / fill, transfer case drain and transfer case fill. 22mmx27mmx1.5mm.
  3. Steve Magnusson
    26,806
    Is this a trick question? AFAIK, the 308 can use the same copper washer for both (22mm ID) -- although F specs different part numbers in various places for a 28 mm OD versus a 27mm OD IIRC.
    If you've got something very different than those sizes, maybe you had some sort of "repair"?
  4. Yoric
    383
    Yoric
    Thank you both for replying. And, no, Steve, it's not a trick question--I apologize if it sounded that way. I just wanted to make sure that the gearbox washers I have on hand also fit the engine drain plug. Now I know not only that but the other plugs GT4 points out. Already got plenty on hand.
  5. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    You can use the old again if you annealed them to red hot w blowing torch
    bernieb and Nuvolari like this.
  6. bernieb
    bernieb Karting
    Apr 16, 2007
    215
    Alberta Canada
    Bernard J Bonertz
    I've been re-annealing for 15 years or so on my 3 F-cars. Works like a damn.
